Tension Force between two rotating masses on strings
1 reply · 3K views · last reply
NarcolepticPig
Two balls with masses m1=0.3 kg and m2=0.7 kg are connected by massless strings with lengths L1=0.2 m and L2=0.26 m, as shown. The arrangement of strings and masses rotates at constant angular frequency ω=57.6 radians/s around a fixed pivot point. Find the two tensions, T1 and T2. There is no gravity in this problem.
So, here are equations I believe are relevant.
F=ma
A=V^2/r
ω=rad*r
So, I'm struggling trying to find the different tensions between the two strings. I think that the radius will change depending on which ball you are looking at and therefore the tensions will be different.
Any tips?
Hi NarcolepticPig and welcome to PF.:welcome:
Can you find the tension in one string? If so, then you can find the tension in the other string the same way. Use the equations that you have posted. I am not sure what the third equation ω = rad*r means.
