Tension on a string while an elevator is moving
The discussion revolves around determining the greatest tension in a string held by a girl in an elevator with a weight hanging from it, under various elevator motion scenarios. The participants analyze the effects of acceleration on tension, concluding that tension increases when the elevator accelerates upward and decreases when it accelerates downward. The mathematical approach using F=ma clarifies that tension is greatest when the elevator is moving upward and slowing down, contradicting initial assumptions about feeling lighter or heavier. Misunderstandings about forces and accelerations are addressed, emphasizing the importance of correctly applying the equations. Ultimately, the correct answer is identified as the scenario where the elevator moves upward while slowing down.
iJamJL
A girl in an elevator is holding one end of a string, and a weight hangs from the other end. In which of the following cases is the magnitude of the tension in the string greatest?
(a) while the elevator moving downward and it is slowing down
(b) while the elevator moves upward at constant speed
(c) while the elevator is moving upward at it is slowing down
(d) while the elevator moves downward with constant speed
(e) while the elevator is at rest
F=ma
F=mg
This is an online homework problem. I thought the answer was simple, but I actually got it wrong. I'm trying to figure out why, and here's what I thought as I solved the problem.
When the elevator is at constant speed, that means that there is no acceleration, and gravity is the only resulting force that pushes the weight down. This is the same for when the elevator is at rest. Therefore, choices B, D, and E are all of equal value. In choice A, the elevator is moving downward, and slowing down. That means the hanging weight is being exposed to a changing velocity, or acceleration, in the downward direction. The acceleration causes the weight to become heavier as it slows down. In choice C, the elevator is moving upward and slowing down. The acceleration is already causing the weight to be heavy, and it is becoming lighter.
The way I thought of it was that choices B, D, and E are all incorrect because they have the same values. Choice A means that the tension has some value but has not reached its heaviest yet, whereas choice C means that the tension is decreasing FROM a heavier weight. I thought choice C was the correct answer.
hi iJamJL! :smile:
… choice C means that the tension is decreasing FROM a heavier weight. I thought choice C was the correct answer.
i don't see the sense of your own reasoning …
you say that (with C) "it is becoming lighter", and "the tension is decreasing" …
then why do you say that (with C) the tension is greatest?? :confused:
anyway, that's a confusing way to do it
use F = ma … there are only two forces that make up F, and one of them (the weight) is constant …
so if a (measured upward) increases, that can only be because the other force (tension) increases …
T = ma + mg
so just find the one with the greatest acceleration (upward), and forget about "heavier" and "lighter"​
Hi again, tiny-tim :biggrin:
Thanks for your reply. Now, I understand how to solve it mathematically. However, when we think about it in real life, it doesn't seem so true..
If I'm in an elevator, and the elevator is already in motion going up toward the 5th floor, I will feel like I am getting lighter as the elevator stops. Wouldn't that mean tension has gone from a stronger force to a weaker force? The same should apply when going down from the 5th floor to the main floor: the second the elevator begins to accelerate downward, I feel as though I am extremely light. As the elevator begins to stop, I feel as though my body is becoming heavier, thus the tension on my body is increasing.
That is what I was thinking when I first read this problem, and that's what I was trying to explain in my original post. However, mathematically, the values are this:
Accelerating down, where g is negative.
F = ma + mg
F = m(-a) + m(-g)
F = -m*(a+g)
Accelerating up:
F = ma + mg
F = ma + m(-g)
F = m*(a-g)
Thank you for helping with the solution. :-p
hi iJamJL! :biggrin:
yes, all this is correct :smile:
(case C: the tension is less)
Accelerating up:
F = ma + mg
F = ma + m(-g)
ah, stop there!
that's where your're going wrong …
mg is not an acceleration, it's a force!
it has to go on the left:
T - mg = ma
then you can shove mg over to the right …
T = ma + mg :wink:
(btw, can't you see that writing these two lines …
F = ma + mg
F = ma + m(-g)​
… is asking for trouble? :redface:)
12K
  • · Replies 35 ·
  • · Replies 33 ·
