The Acidity of the Hydrated Ferric Ion
  • Thread starter Thread starter Qube
    Ion
The discussion centers on the acidity of the hydrated ferric ion, Fe(OH2)63+, exploring various factors that contribute to its acidic properties. Participants examine theoretical aspects, including coordination chemistry and oxidation states, as well as implications for chemical behavior.
  • Some participants propose that the induction effect from coordinated water molecules stabilizes the negative charge generated when a proton is lost, enhancing acidity.
  • Others argue that the size of the ferric ion, which can coordinate six water molecules, contributes to its stability and acidity, although there is some disagreement about the relative sizes of ferric and ferrous ions.
  • Participants discuss the significance of the ferric ion's oxidation state, noting that a higher oxidation state increases ionic character in coordination bonds, making the hydrogens more electrophilic.
  • There is mention of positive charge density affecting the ability of the ferric ion to leech hydroxyl groups from water, thereby producing protons and increasing acidity.
  • Some participants express uncertainty about the application of inductive effects in evaluating the acidity of metal complexes compared to organic cations and anions.
Participants generally agree on the importance of oxidation state and charge density in influencing acidity, but there is disagreement regarding the size comparison between ferric and ferrous ions and how that affects their stability and acidity. The discussion remains unresolved on certain aspects, particularly the application of inductive effects to metal complexes.
Some limitations are noted regarding the assumptions made about the sizes of ions and the definitions of acidity in the context of metal complexes versus organic compounds. The discussion reflects varying levels of familiarity with the concepts involved.
This discussion may be useful for students and practitioners interested in coordination chemistry, acid-base theory, and the behavior of metal ions in aqueous solutions.
Qube
Why is Fe(OH_{2})_{6}^{3+} fairly acidic? This iron has six water molecules coordinated to it.
In other words, water itself is a very weak acid. But when water is coordinated to iron, it becomes more acidic. I can think of a few reasons; can you think of more?
1) Induction. The negative charge generated through loss of the hydrogen proton is stabilized by the coordinated water molecules. Plus the center of the square planar molecule is greatly positively charged (and therefore can handle the negative charge, despite the fact that iron itself is actually electropositive rather than electronegative - at least in iron's ground state).
2) Size of the ferric ion. The ferric ion is rather big (it is, after all, able to coordinate six water molecules, as opposed to only four for some other metal ions). So whatever positive charge it has after being ionized once is spread out over a large surface area and that makes entire compound relatively stable. This is an assessment of conjugate stability.
3) Oxidation state of the central ferric ion - positive 3. This indicates a high degree of ionic character in the coordination bonds. Withdrawal of electron density from the water molecules makes the hydrogens even more positively charged and thus even more electrophilic.
4) Positive charge density of the central ferric atom. Coulomb's law is in (significant) effect here. Positive and positive. Like charges repel. Kicking off a hydrogen proton - no problem.
Try to look the acidity of Ferric ion in terms of Lewis Acid. It is striped of 3 electrons, so it can accept electron.
1) I don't know what to say here, except try to evaluate the acidic strength of the ferric ion in terms of ferric ion alone.
2) Size of ferric ion is quite less than ferrous ion, yet it is far more acidic than the latter. Hence you need to reverse your statement here.
3) Higher oxidation states do help, no doubt.
4) Positive charge density is a valid point, causing it to leech out hydroxyl group from water and thus producing protons and thus acidity.
True, I should have been more clear in my original statement rather than have simply tacked on a sentence at the end that I am assessing conjugate stability there.
I was trying to say that the conjugate base of the hydrated ferric ion, the ferrous ion, is bigger than the ferric ion. Cations get progressively smaller with increasing positive charge because the stripping of the electrons increases Z_{eff}, thereby causing the nucleus to pull the electron cloud closer and making the atom smaller.
By nature of the ferrous ion being bigger and having less positive charge, the ferrous ion has to be more stable - we have both an increase in size and a decrease in charge - leading to a definite decrease in positive charge density - and therefore a definite increase in stability. The more stable the conjugate base, the stronger the acid.
True that. We can determine the direction of the reaction (Acid to conjugate base in the example) by roughly judging the stability of the products in the test condition.
Sweet. Thank you again for helping me, a new to organic chem student. I feel well prepared thanks to you and my gen chem teacher (I think I got my gen chem basically down).
This was what I was getting at; did you cover it in your chem classes? Just curious.
http://en.wikipedia.org/wiki/Inductive_effect
We used that series to determine the acidic strength of organic cations/anions/radicals, but I never once used it to test the strength of complexes. For me, these two things were covered in a very different ways.
Ah. Okay. My gen chem teacher actually didn't use induction to characterize the acidity of hydrated metal ions but I think it would be valid; after all, the water molecules are bound somewhat together.
My general chemistry teacher emphasized on the induction effect. My chemistry level is unfortunately not high enough to go any further.
