- 42,978
- 10,571
Strictly speaking, it will depend on the prior. But suppose your prior is 1000:1 against. What posterior likelihood do you get?alan_longor said:thank you , so what would the probability be ?
well one of the conditions was that we know nothing about the light , the only thing we know is that it came up for one billion nights . now when i asked weather or not we can set a probability for it coming up the next day , that means weather or not the information we have is enough to set a probability . if something else has to be known then we cannot set it . in either cases logically the probability must be a number very close to 1 .haruspex said:Strictly speaking, it will depend on the prior. But suppose your prior is 1000:1 against. What posterior likelihood do you get?
I assume you have been introduced to Bayes' theorem. This tells you that you cannot estimate the probability of anything from observations unless you start with a prior estimate.alan_longor said:well one of the conditions was that we know nothing about the light , the only thing we know is that it came up for one billion nights . now when i asked weather or not we can set a probability for it coming up the next day , that means weather or not the information we have is enough to set a probability . if something else has to be known then we cannot set it . in either cases logically the probability must be a number very close to 1 .
ok , then in this case we cannot set a probability for the appearance of the light on the next night .haruspex said:I assume you have been introduced to Bayes' theorem. This tells you that you cannot estimate the probability of anything from observations unless you start with a prior estimate.
alan_longor said:so if i ask you on day number one billion what's the probability that the light will come up tomorrow to ... is that a meaningful question ?
Sure, solipsism is a sound philosophy from a logical perspective, but it doesn't get you very far. In the real world, we function quite effectively by subconsciously assigning reasonable a priori probabilities.alan_longor said:ok , then in this case we cannot set a probability for the appearance of the light on the next night .
i am sorry for being unable to understand that exact case , and please allow me to ask you a question even though i was unable to answer yours . so what if someone says he has a real number generator that would generate a random number between 1 and 100 . and that there is no pattern and there is no way to predict what that machine gives . is it correct to assume that the probability for the number given by the machine to be between 90 and 100 is 1/10 ? since all the numbers seem to have an equal probability here . thank you very much .haruspex said:Sure, solipsism is a sound philosophy from a logical perspective, but it doesn't get you very far. In the real world, we function quite effectively by subconsciously assigning reasonable a priori probabilities.
Your rising sun model is insufficiently divorced from real experience to think about in a detached manner. How about, you notice that on three consecutive occasions the winning lottery number ends in a five. What is the probability that there is a flaw in the randomisation? What probability would you have assigned to that beforehand... one in 100? Too high. One in 10,000? Let's say one in a million. How many consecutive occasions of a final digit 5 will push that estimate to greater than half?
If you completely trust that information, yes. But complete trust also constitutes a prior distribution.alan_longor said:i am sorry for being unable to understand that exact case , and please allow me to ask you a question even though i was unable to answer yours . so what if someone says he has a real number generator that would generate a random number between 1 and 100 . and that there is no pattern and there is no way to predict what that machine gives . is it correct to assume that the probability for the number given by the machine to be between 90 and 100 is 1/10 ? since all the numbers seem to have an equal probability here . thank you very much .
But complete trust also constitutes a prior distribution.haruspex said:If you completely trust that information, yes. But complete trust also constitutes a prior distribution.
Maybe it's a matter of philosophy, but I take a different view.FactChecker said:The most that Bayesian methods can do is to assign an initial standard distribution ( uniform ) with no justification.
That is a good point. I was influenced by this example that doesn't give any glue for the initial distribution.haruspex said:Maybe it's a matter of philosophy, but I take a different view.
Bayesian methods require you to supply a prior distribution, but that does not provide an excuse to set it to uniform without justification. In normal practice, it will be some gut feel based on experience. The fundamental point is that the choice should not be that crucial provided it is reasonable.
That assumes the uniform distribution is closer to the true distribution than is the chosen prior. As I posted, a good approach is to consider some range of priors that you feel encompass the answer and run the trials until sufficiently confident.FactChecker said:If you use an initial distribution that is not uniform, that might make it harder to correct
"closer to" is tricky to define. In an iterative process, if stage 1 resulted in a distribution with a small standard deviation, it might be difficult to move the mean in stage 2. So it might be better to increase the standard deviation for the stage 2 prior distribution -- perhaps even to a uniform distribution. But we never investigated it while I was there, so I don't know.haruspex said:That assumes the uniform distribution is closer to the true distribution than is the chosen prior.
FactChecker said:That is a good point. I was influenced by this example that doesn't give any glue for the initial distribution.
That brings up another question (I don't want to hijack this thread, though):
If you use an initial distribution that is not uniform, that might make it harder to correct. I have no experience with this, but the question has come up before at work where it was being applied iteratively.
