Can You Turn a CUBE on a LATHE?
  • Thread starter Thread starter OCR
Turning a cube on a lathe is possible but requires multiple setups, typically six for each face. The cube can be held in a 4-jaw chuck or clamped to the cross slide for facing, though the latter is more complex for achieving accurate angles. Videos demonstrate the process, showing that while it can be done, it may not be the most efficient method compared to other machines like milling machines. The discussion also touches on the similarities between machining a cube and a sphere, noting that both require careful handling and multiple setups. Ultimately, the feasibility of turning a cube on a lathe is confirmed, albeit with some caveats regarding convenience and setup complexity.
OCR
  • Haha
Likes sophiecentaur, phinds and jedishrfu
I guess this is a late April Fools Day joke.
Likes OCR
OCR said:
Yes.
But it will require mounting six times, once for each face.
1. You can hold the cube in a 4 jaw chuck, then face the end with a tool in the cross slide. Since the centre is not important, depending on what shape you start with, you might hold the work in a 3 jaw chuck.
2. You could clamp the cube to the cross slide, then face it with a cutter held in the chuck. But that would be more difficult to set up for accurate angled corners.
The example shown in the video shows multiple passes of a fly cutter. That suggests it was clamped to the cross slide, but more probably faced in a small milling machine.
  • Haha
Likes jedishrfu
Baluncore said:
Yes.
But...
Not sure if Baluncore is deadpan riffing on joke, or
What I saw was: A lathe. With a cube on it. Being turned.
  • Haha
Likes jedishrfu, phinds and DaveE
Repeatably, again and again.
The example cube that turned up on the lathe was not turned up in the lathe.
How could I miss the opportunity to deliver deadpan, a couple of other obtuse ways it could be done, but in, not on the lathe. Can a lathe have obtuse ways, or is it only me ?
  • Haha
Likes jedishrfu
Thought so.
  • Haha
Likes jedishrfu
Yes, it is possible. See "machining a cube on a lathe" by machiningmomentsbrad on youtube.
Yes, we know.
It’s not as convenient to produce a ball on a vertical milling machine.
  • Haha
Likes jedishrfu and DaveC426913
But it is very easy to turn a ball on the bed of a vertical milling machine.
A ball or a cube can be produced pretty much anywhere a magician turns up to remove the cover.
  • Haha
Likes jedishrfu
Machining a ball on a milling machine is functionally identical to machining a cube on a milling machine, except the number of remountings required is somewhat larger.
Here's a video on making a jig that can move the cutting tool in a circular manner.
A tow ball can be made in one setting.
At most, only one remount is needed for a full sphere.
Mount the workpiece in an indexed head, with axis at a slope to the bed, or head tilted.
A single point cutter, offset by slightly less than the ball radius is mounted in the spindle to cut a circle on the ball surface.
While spindle turns cutter, slowly rotate the index head until you have a sphere.
Likes DaveC426913
Pictures help explain the geometry of generating a sphere in a milling machine.
https://www.ctemag.com/news/articles/generating-spherical-surfaces
In actual practice, you can’t cut a full sphere in one setup. You still have to hold the part and rotate it somehow. To produce a full sphere, you must use two separate holding setups.
Some interesting (and typically PF) responses here. :wink: I hope you all enjoyed that bit of nonsense.
It's largely a matter for definition, imo. If you put a morse 3 taper lathe chuck into the spindle of my toy vertical milling machine (and lay it on its side?), you've got yourself a lathe, afair. It could be argued that the workpiece rotates in a lathe and the cutters rotate in a mill - hence my use of the word "convenient".
