The Schwarzschild Metric - A Simple Case
177 replies · 29K views
pervect said:
Let me expand on my previous remark just bit
The relativistic differential equation for the falling object r(tau) is(dr/tau)^2 = 2GM(1/r - 1/R_max)
If we consider a Newtonian object falling radially from some height R_max, conservation of energy gives us the same equation
.5*m*v^2 = GmM(1/r - 1/R_max)
but v = dr/dt and the m of the falling object cancels out so
dr/dt = 2GM(1/r - 1/R_max)So - except for replacing the Newtonian time t with the proper time tau, using Schwarzschild coordinates makes the equation for the falling object and the expression for the tidal forces similar to the Newtonian case.
yuiop said:
Small correction. That last equation should be (dr/dt)^2 = 2GM(1/r - 1/R_max).
Here Pervect effectively said:
0.5*m*(dr/dt)^2 = GmM(1/r - 1/R_max) [itex]\Rightarrow[/itex] dr/dt = 2GM(1/r - 1/R_max)
which by simple algebra should have been:
0.5*m*(dr/dt)^2 = GmM(1/r - 1/R_max) [itex]\Rightarrow[/itex] (dr/dt)^2 = 2GM(1/r - 1/R_max)
O.K. It was just a small typo on his part and I was fixing it to avoid confusion to future readers. To which your response was:
starthaus said:
Err, no, it is much more complicated than that:
[tex]\frac{dr}{dt}=(1-r_s/r)\sqrt{1-\frac{1-r_s/r}{1-r_s/r_0}}[/tex]
You gave the relativistic equation, when Pervect was talking about the Newtonian version. I had already pointed this out to you when I said:
yuiop said:
If you had read Pervect's post carefully (the one I was responding to), you would have noticed that he was talking about the Newtonian analogue of the correct relativistic differential equation:
Obviously you have still not read Pervect's post carefully because you next response was:
starthaus said:
You may have wanted to write [tex]\frac{dr}{d\tau}[/tex] but you put down [tex]\frac{dr}{dt}[/tex]. so your attempt at correcting his post is incorrect.
I put dr/dt instead of dr/dtau because I was talking about Pervect's Newtonian equation which was in terms of dr/dt. There is no distinction between coordinate time dt and proper time dtau in Newtonian equations, only universal time. Surely you know this? Pervect and I were talking about NEWTONIAN equations, not relativistic equations, so no, I did not mean to write and nor should I have written dr/dtau.
So for the second time, READ PERVECT'S POST CAREFULLY.
Your responses are bordering on illogical.
starthaus said:
I suggest that you start with a perfectly rigid rod , one that exhibits constant proper length, like the ones used by SR.
Passionflower said:
That is an option, but it seems to me that you need to operationally define how this is obtained...
This simple case can be dealt with. The correct starting formula is:
[tex]\frac{dr}{ds}=\sqrt{r_s/r-r_s/r_0}[/tex]
yuiop said:
You have completely missed the point of passionflower's question.
I simply corrected your incorrect "guesses", that's all.
Again, an illogical response, because the posts you were responding to were nothing to do with any equations (correct or otherwise) I have posted.
Passionflower asked you how to operationally define the proper length of a falling rod to which your response was to quote some formulas for the velocity of a falling particle.
Are you now going to try and answer the question that Passionflower actually asked?
yuiop said:
[tex] \frac{dr}{ds}=\sqrt{r_s/r}[/tex]
starthaus said:
This is correct (I just showed that in post 54).
..and I just showed that in post 6.
yuiop said:
[tex]dL' = dL\sqrt{(1-r_s/r)(1-(dr/ds)^2)} = dL \sqrt{(1-r_s/r)(1-r_s/r)} = dL(1-r_s/r)[/tex]
where dL' is the length according to the Schwarzschild observer when the object is falling past Schwarzschild radial coordinate r?
starthaus said:
Are you guessing the above? Because there is no derivation (again).
I did not show a derivation, because it is (almost) self evident.
In SR the coordinate length L' of moving object with proper length L and relative velocity v is [itex]L' = L_o \sqrt{(1-v^2/c^2)}[/itex]. Locally, even in GR, the equations of SR apply and so the coordinate length of an object moving with local velocity v' = dr'/dt' according to a local static observer (LSO) is also simply [itex]L' = L_o \sqrt{(1-v'^2/c^2)}[/itex]. The velocity of an object that was initially at rest and dropped from infinity according to the LSO is [itex]v'/c =\ sqrt{(r_s/r)}[/itex] so we can rewrite the last equation in this special case as [itex]L' = L_o \sqrt{(1-r_s/r)}[/itex]. Now the transformation from local length L' to Schwarzschild coordinate length L is [itex]L = L'\sqrt{(1-r_s/r)}[/itex] so we can now write [itex]L = L_o (1-r_s/r)[/itex] and this is valid for very short (infinitesimal) lengths.
Q.E.D.
Just incase you are wondering, for the special case of a initially stationary object dropped from infinity:
[tex]\frac{dr}{dtau}=\sqrt{\frac{r_s}{r}} = \frac{dr'}{dt'}[/tex]
where dtau is the proper time rate of a co-falling clock and dr' and dt' are measurements made by the LSO.
You are guessing again.
Err, no. It doesn't work this way. You can get the equations of SR as a limiting case from the equations of GR (for the case of null-curvature). You can't do yet another hack "derivation" of the equations of GR by plugging in GR-derived (aka [tex]dr/ds=\sqrt{r_s/r}[/tex]) equations into the equations of SR. There is no concept of [tex]r_s[/tex] in SR to begin with.
The same way you can't derive new equations of SR by plugging in SR equations into Newtonian mechanics. You need to learn that physics is not a collection of hacks and "guesses".
Passionflower said:
Actually as I explained with 'time to ultimate doom' the fall from infinity is not a problem at all. We can pick any starting coordinate we want and assume both the front and the back came from infinity. This approach I think has several advantages, not it the least that once we have the right formula we can then express it in terms of proper time left and take it down past the event horizon as well.
The problem is that the equations you gave for "time till doom" do not give the coordinate falling time.
Well that is encouraging, so say we start from R=10 (but they come free falling from infinity - I would not like the inattentive reader to claim I make yet another mistake), and then take it down a coordinate time of 5 and then all we need to do is take the back down from R=11 with the same coordinate time. And that would be our falling two coffee grind particles including a tidal stretching freebie?
As I said before, it is probably easier to relax the fall from infinity requirement (although we might try that later) and assume a drop from initially at rest from a finite height.
After a coordinate time of 5 the leading clock will have fallen to 9.99437 and in the same coordinate time the trailing clock will have fallen to 10.953 and the coordinate gap will have increased from 1 to 1.009 if both particles were initially at rest and released at the same coordinate time from heights 10 Rs and 11 Rs.
It is a bit more interesting if you let the particles fall further.
If we start with the same release heights and let the leading particle fall to height 2 Rs then the coordinate fall time is 2.64 and trailing clock is at 4.64 Rs.
I am using the equations given in post 48 to obtain these results, but I have to numerically solve them as the mathematical software I use is unable to find a symbolic solution for r when t is know.
Here is a list of results for various initial and final heights for the trailing clock, all with the leading clock starting one coordinate unit lower and end point determined by the leading clock arriving at 2 Rs.
11 : 4.64
101 : 9.81
1001 : 21.86
10001 : 48.42
100001 : 105.987
1000001 : 230.22
10000001 : 498.02
100000001 : 1075.06
1000000001 : 2318.31
Very approximately, each tenfold increase in the initial drop height results in a two fold increase in the coordinate separation at the end point.
Is everybody absolutely sure it is really that simple? If so then if we take the proper distance pre and post we can simply subtract the pre proper length from the post proper length and voila we have a difference in length in terms of R coordinate distance and coordinate time (and then of course we can also calculate proper distance and proper time for each grind perspective as well).
No, it is not that simple. All we have done is determined the coordinate separation of the unconnected free falling particles. We have still not determined the proper separation of the freely falling particles in the rest frame of the particles and I not even sure at this point if it is possible to define what that is. It is as you probably already aware, very difficult to operationally define the proper length of the falling particles for non infinitesimal separations. It does however give an indication of the tidal stretching in coordinate terms.
The attached diagram is a graph in Schwarzschild coordinates of the objects falling from 10 Rs and 11 Rs.
[tex]\sqrt{\frac{r_s}{r}} = \frac{dr'}{dt'}[/tex]
Err, this is incorrect. You might want to check your facts. Instead of making up formulas that are wrong, it would be good if you tried consulting a good book or doing your own derivations,
You really don't "get it".
You better have a word with Pervect too about these "crimes" against physics:
pervect said:
If you make the subdivisions small, you can use radar, or the notion of distance in the local Lorentz frame, to determine the distance between the subdivision. I think it's already been noted in previous threads that the radar distance back-front and front-back varies for a long accelerating ruler, hence the importance of "dividing it up" in this manner.
pervect said:
While the space-time of the Schwarzschild metric is curved, if you have a small enough ruler, you can ignore the curvature. Then you simply have the problem of a ruler with a known proper length, falling past you at some velocity. You already know how to solve this problem from SR, the problem is not essentially different
pervect said:
So - except for replacing the Newtonian time t with the proper time tau, using Schwarzschild coordinates makes the equation for the falling object and the expression for the tidal forces similar to the Newtonian case. Unfortunately, it's still rather messy...
pervect said:
Basically, the equations of motion - and also the equations for the tidal forces - are the same as the Newtonian equations, except that we replace t by tau
pervect said:
You've got a number of choices: you can select one of the two bodies, and a particular time point on it, and do a simple linear projection from it to the second body, using the notion that the bodies are close enough together that you are in a sufficiently flat space-time. This is the easiest approach.
Ah yeah, I forgot. The only person you continually attack on this forum is me. Silly me.
11 : 4.64
101 : 9.81
1001 : 21.86
10001 : 48.42
100001 : 105.987
1000001 : 230.22
10000001 : 498.02
100000001 : 1075.06
So, according to the above, the distance between particles increases. In the previous post (#62), you were arguing that the distance decreases. Which one is correct?
You might want to check this paper http://arxiv.org/PS_cache/gr-qc/pdf/0111/0111073v1.pdf referenced by Pervect.
It defines the velocity in Eq2 as:
Following along the same lines, Frolov and Novikov recently [3, pp.19,20] add that
“The physical velocity v measured by an observer who is at rest in the Schwarzschild
reference frame
situated in the neighborhood of the freely moving body is:
Eq 2 resolves to [tex]v = \left(\frac{2m}{r}\right)^{1/2}[/tex] when the particle is initally at rest and released from infinity.
It also defines the velocity in Eq 27 as:
where v was earlier defined (near Eq 17) as:
where (v) is, accordingly to Eq.(8), the velocity of the particle with respect to a static observer (r = constant); i.e. while the particle travels a proper distance α−1/2dr the observer measure a proper time given by α1/2dt.
So there are some fact to stuff in your pipe and smoke.
Come on folks let's focus on the problem and the solution!
On point though we are looking for a solution in the Schwazschild metric. So approaching the problem from Newton is no problem but we do have to get it eventually expressed correctly using the Schwarzschild solution, that is the whole point of this topic.
What I think will help for the next step is the answer to this, seemingly simple, question
What is the formula for getting the proper distance to the Schwarzschild radius for a given R coordinate and coordinate velocity?
Anyone know this formula?
Eq 2 resolves to [tex]v = \left(\frac{2m}{r}\right)[/tex] when the particle is initally at rest and released from infinity.
You are compounding your mistakes.
"proper distance to the Schwarzschild radius"? You sure about the question?
Yes very sure. What seems to be the problem?
The nice thing about this formula is that we do not care if the particle fell from apogee or from infinity since it is expressed in coordinate velocity and r coordinate which should be sufficient to determine the proper distance to the Schwarzschild radius.
The coordinate distance between unconnected particles does indeed increase*. In the previous post I was referring to the coordinate length being shorter than the proper length of a rigid falling rod. Please note the subtle difference between a rigid rod and a series of unconnected particles. You really are not paying attention but just jumping at every seeming opportunity to attack me and getting it wrong most of the time.
Even in the case of the coordinate distance between unconnected particles increasing as they fall, the proper distance between the particles is greater than the coordinate distance between the particles.
* The coordinate distance between the particles increases in the particular case of the end point being at 2 Rs. If the end point was lower nearer 1 Rs, then the effective slow down in coordinate velocity as the event horizon is approached, means the trailing particles start to catch up with the leading particles in coordinate terms and the coordinate distance starts to decrease. This can be seen in the diagram I uploaded in a recent post. In all cases the coordinate separation of the particles is always shorter than the proper separation and the coordinate length of a rigid falling rod is always shorter than the proper length of the rigid rod.
Got it now?
The problem is that it makes no sense.
I think it makes perfect sense. Could you explain why you think that it makes no sense?
For instance if the coordinate velocity is zero it is simple, when we assume RS=1 we get:
[tex] \sqrt {r}\sqrt {r-1}+\ln \left( \sqrt {r}+\sqrt {r-1} \right)[/tex]
Don't take it personally, I am not attacking you, I am just pointing out the unsupported hacks that contradict each other from post to post.
But you failed to establish this relationship. Hacking the GR equation for terminal velocity back into the SR length contraction formula does not count as a valid derivation.
You can calculate proper distances only locally, in a small vicinity of the observer co-moving with the rod. What you are asking for is , in effect, [tex]r-r_s[/tex], which is not a proper distance.
But you failed to establish this relationship. Hacking GR equations back into SR length contraction formula does not count as a valid derivation.
It is valid, because locally over very short distances (infinitesimal) space is flat (Minkowskian) even in the curved space near a massive body and the equations of SR apply. If you do not know that, then you better learn it fast. It is fundamental. Pervect has explained that in greater detail and more formally in several posts in this thread and the related thread and you would do well to read his posts carefully and learn.
Problem is, the SR length contraction has been derived for inertial frames.You can't write it blindly for accelerated frames.
Doesn't make your derivation valid. Quite the opposite.
To his credit, pervect did not advocate the kind of ugly hack that you are attempting. Quite the opposite.
starthaus said:
You can calculate proper distances only locally, in a small vicinity of the observer comoving with the rod. What you are asking for is , in effect [tex]r-r_s[/tex], which is not a proper distance.
So let's take the simplest case (we assume Rs=1 to make it even simpler) of an observer with zero coordinate velocity the proper distance to the Schwarzschild radius is not generally:
[tex] <br /> \sqrt {r}\sqrt {r-1}+\ln \left( \sqrt {r}+\sqrt {r-1} \right)<br /> [/tex]
It works, as you claim, only in a small region?
All I am asking for is a simple formula that works also in case the coordinate velocity is not zero.
Passionflower said:
So let's take the simplest case (we assume Rs=1 to make it even simpler) of an observer with zero coordinate velocity the proper distance to the Schwarzschild radius is not:
How did you arrive to the above?
The radar distance as measured from r2, to the event horizon is:
[tex] (rS*LN\left( \frac{r2-rS}{r1-rS}\right) +r2 - r1)*\sqrt{1-\frac{rS}{r2}} [/tex]
When r1=rS the radar distance is infinite, which we sort of expect.
The integrated or ruler distance is given by:
[tex] \sqrt{r2*(r2-rS)} - \sqrt{r1*(r1-rS)}<br /> + rS*\left(LN\left(\sqrt{r2} + \sqrt{(r2-rS)}\right)- LN\left(\sqrt{r1} + \sqrt{(r1-rS)}\right)\right)[/tex]
and the really weird aspect of the above equation is that the answer is real and finite even when r1=rS. That always seemed strange to me. Since it presumably physically impossible to have one end of a stationary ruler located exactly at the event horizon, you might think the equation would spit out a complex number or something in that situation.
Unfortunately, neither of the above equations tell us about the proper distance to the event horizon according to a moving observer and I am not sure if that can be defined. The last equation is the closest thing to a notion of proper distance to the event horizon but it applies to a stationary ruler.
[EDIT] I see you have already worked out the stationary case for the above formula, in the post you made while I was posting this:
P.S. That formula works over extended distances. It is the distance measured a physical ruler (or lots of very short ideal measuring rods laid end to end) extending from r2 to r1. When the rod is stationary with respect to r1 and r2 then the rest frame of the rod is well defined. If the r1 end of the ruler is located at the event horizon (stationary) and the other end of the rod is attached to a moving observer at r2, then which frame is the rod at rest in? At rest in the frame of the moving observer or at rest with respect to Shwarzschild coordinates?
In order to define proper distances over extended regions for a falling observer, you need (as Pervect mentioned) a notion of simultaneity over extended distances and a suitable coordinate system. One such coordinate system which may provide a way forward in resolving the problems posed in this tread is Kruskal-Szekeres coordinates. Observers that are stationary in KS coordinates are not exactly free-falling, but falling in such a way that they maintain constant separation. They would therefore experience some proper acceleration as they fall and naturally free falling particles tend to fall faster.
In the above KS diagram, the curved line from F to F' represents the path of a freely falling particle with apogee at F. Observers that are stationary in KS coordinates have paths that are vertical and remain a constant KS coordinate distance apart. Light paths are at 45 degrees in KS coordinates, so it easy to see that the radar distance between the "stationary observers" is constant in terms of KS coordinate time. Since the free falling geodesic is curved, the "falling" KS observers moving on vertical lines are not true free falling inertial observers. Wikipedia gives the equations for KS coordinates and how to transform them to Schwarzschild coordinates so it might be interesting to see how a pair of KS falling observers that maintain a constant KS coordinate separation look like in Schwarzschild coordinates.
That would be really odd.
If it is that hard we should perhaps take it in steps, the next step should be we assume the given coordinate velocity is constant which will work all the way up to but not including the EH.
Another approach is perhaps that we work the other way around, e.g. by formulating the proper time it takes to reach the EH for a given coordinate velocity.
That is what I think as well, I was simply asking Starthaus the question, let's wait what Starthaus has to say about it.
You integrate (1-1/r)-1/2 dr between 1 and r.
How did you arrive to this? Give me some physical context, please.
That is at least doable, and it should also be fairly easy to determine how far apart two freefalling clocks/observers are at any given equal proper time. I am not sure what the physical significance of that would be, but it may throw out something interesting.
Another approach that might simulate a falling rigid rod it to assume all parts of the rod have the same velocity as the front or middle of the rod. At least with a clearly defined velocity for all parts of the rod it should be easy to obtain its integrated length.
You can't do that since it is contradicted by the physics of the problem.
Indeed, the coordinate speed of a particle is :
[tex]v=\frac{dr}{dt}=(1-r_s/r)\sqrt{r_s/r}[/tex]
It is easy to show that the above speed increases as r decreases up to the point [tex]r=3r_s[/tex]
Indeed:
[tex]\frac{dv}{dr}=1/2(3r_s/r-1)\sqrt{r_s/r^3}[/tex]
This means that the front of the rod passes has a higher speed than the tail at any given moment.
It also means that the distance between the front and the tail increases as r decreases, i.e. the rod is getting "spagettified" (extruded). Indeed:
[tex]v(r)-v(r+\Delta r)=\Delta r*\frac{dv}{dr}[/tex]
For [tex]\Delta r[/tex] fixed, the above difference between two points on the rod increases as r decreases by virtue of the fact that [tex]\frac{dv}{dr}[/tex] is also increasing as it can be easily established.
To make matters even more complicated, the internal (electromagnetic) forces are fighting the "spagettifaction". What is happening to the rod is not treatable as a simple kinematics problem and, even less, as a hack on the SR length contraction.
Well let's start with a point instead of a rod, as so far nobody has come and showed the proper distance to rs with respect to r and vc(r).
Starthaus, could you tell me what the point is of your question, do you disagree with the formula? In that case I suggest to open a separate topic on this as I think this is standard textbook stuff. Or do you want to derive it from the Gaussian curvature? If that is the case I would also suggest you open a separate topic on this as it is not relevant to this topic. Or perhaps you want to illustrate that I am wrong by assuming we can have a proper distance when that distance is changing over coordinate time? In that case please come to the point, why would you think that a proper distance when that distance changes over coordinate time cannot be mathematically defined? I think an approach could be to start by keeping the second derivative = 0 so that the velocity remains constant, you can do this all the up to, but not including, the EH. Then we can address the general case where the second derivative is not 0.
I suspect that the formula is most likely incorrect. Without a complete derivation , I cannot be sure. Can you show me how you arrived to the integrand?
Which textbook did you get it from?
Indeed:
What you call my "hack on the SR length contraction" was an equation that applied to an infinitesimal particle where "spagettification" does not occur. Infinitesimal is very small, even smaller than an atom and is in fact as small is required to make the local spacetime flat (so negligable tidal forces). For a non infinitesimal rod some form of integrated length is required and I am aware as you are, as to how non trivial that is.
Now all the equations you give are for free falling particles. For a rigid rod parts of the rod are not free falling. By definition the rigidity of the rod prevents that. You said "front of the rod passes has a higher speed than the tail at any given moment", but Passionf has specified in the OP that we can use rockets to accelerate parts of the rod to ensure that its proper length remains constant by whatever means necessary. So while natural free fall might mean that the rear clock is moving slower than the front clock at any given moment (and here you should define "moment" according to what reference frame) we can attach a rocket to the rear clock to make sure it goes at the same speed (insert according to what observer here) as the front clock if that is convenient to us.
It is not unlike Born rigid acceleration, where all parts of a system are individually accelerated by the exact required amount to ensure constant proper length is obtained in the accelerating system. We are just trying to make the GR analogue of that.
DrGreg derives that equation in this thread. https://www.physicsforums.com/showthread.php?t=248015 There is no need to spend any more time on this diversion.
