starthaus said:
No, your formula is wrong because:
1. you are using an inappropriate formula to begin with (the worst mistake)
starthaus said:
...which are both equally incorrect since they have a common incorrect starting point, the integrand:
[tex]ds=\frac{dr}{\sqrt{1-r_s/r}}[/tex]
starthaus said:
I asked you where the integrand
[tex]\frac{dr}{\sqrt{1-r_s/r}}[/tex]
was coming from. I told you that it was most likely incorrect (turns out that it is, thus making the integral and all your and yuoip's calculations useless).
You have stated at least 3 times that the starting integrand used by myself, Passionflower and DrGreg, specifically:
is incorrect, but now finally you have contradicted yourself and admitted it was correct all along, in your last post on the subject:
starthaus said:
...which is just as wrong since, in this case, the correct integrand is:
[tex]ds=\frac{dr}{\sqrt{1-r_s/r}}=(1+r_s/(2r))dr[/tex]
(see Rindler 11.5)
Since you used the wrong integrand, you also obtained the incorrect integral. If you did it right, you would have obtained a much nicer formula:
[tex]\Delta S=r_2-r_1+r_s/2(ln(r_2)-ln(r_1))[/tex]
The expression on the end of the Rindler equation in chapter 11.5 is an approximation and what Rindler actually said was:
[tex]dl = \left(1-\frac{2m}{r}\right)^{-1/2}\, dr \, \approx \, \left(1+\frac{m}{r}\right)\, dr[/tex]
which in terms of the forms and variables you are using can be written as:
[tex]ds=\frac{dr}{\sqrt{1-r_s/r}}\, \approx \, (1+r_s/(2r)) \, dr[/tex]
DO you see the wriggly equals sign? That means "approximately equal" and is not an exact expression. These approximations get increasingly inaccurate near the event horizon (the region the OP is interested in). Pervect has demonstrated this with a numerical example:
pervect said:
I don't have Rindler, but the left side of this equation is obviously not equal to the right. What gives?
i.e if r_s=1 and r=2, the left side is dr/sqrt(.5) , the right side is 1.25dr;
As I said before, you almost never check equations numerically so you often fail to spot when when different looking expressions are in fact the same and you fail to spot when an equality is in fact an approximation. So take a tip from Pervect and carry out a numerical check in future, before jumping in (or look for the wriggly "approximately equal" symbol).
So if we discard the approximate expression and your derived integrations from it, because they useless near the event horizon and because the OP has several times expressed an interest in exact solutions, we end up the correct initial integrand as given by Rindler and DrGreg is:
Now I know from past experience you never admit your are wrong, even when it is proven you are wrong and you never apologise to others when you falsely accuse them of being wrong, so I won't hold my breath waiting.
starthaus said:
The "rocket" bit is over the top, especially since the OP was about a free-falling rod.
Let me remind of you part of the OP with a direct quote:
Passionflower said:
Let's assume that the clocks, by having little rockets or a super rigid cable (I know this can't be the case but we have to start somewhere if we want to make any calculations), at all times maintain a ruler distance of 1.
