This bigger than grahams number?
  • Context: Graduate
  • Thread starter Thread starter fat f...
The discussion revolves around the comparison of a proposed number, derived from a specific exponentiation process, to Graham's number. Participants explore the mathematical structure of the proposed number and its potential size relative to Graham's number, while addressing notation and calculation ambiguities.
  • One participant proposes a number based on the expression 2^3^4^5^6^7^8^9, suggesting it could be compared to Graham's number.
  • Another participant questions whether the intended comparison is between (2^3^4^5^6^7^8^9)^(2^3^4^5^6^7^8^9) and Graham's number, asserting that Graham's number is significantly larger.
  • Concerns are raised about the notation used in the original post, with some participants suggesting that the expression should include grouping symbols to clarify the intended order of operations.
  • There is a discussion about the order of operations in exponentiation, with some participants asserting that exponent towers should be evaluated from the top down.
  • A participant introduces the concept of Tier(n), which is defined as n raised to itself n times, suggesting it as a potential candidate for comparison against Graham's number.
  • Another participant expresses uncertainty about the size of a proposed number involving a googleplex raised to itself multiple times, indicating that it might be smaller than Graham's number.
  • One participant shares personal motivations for exploring these numbers, including a desire to understand the nature of large numbers and their representations.
  • There is a discussion about the implications of using 9s in the context of the proposed number and how it relates to concepts of infinity and mathematical representation.
Participants do not reach a consensus on whether the proposed number is larger than Graham's number. Multiple competing views remain regarding the interpretation of the expressions and their respective sizes.
Participants acknowledge ambiguities in notation and the need for clarity in mathematical expressions. There are unresolved questions about the proper evaluation of exponentiation and the implications of using different bases and operations.
fat f...
is this bigger than grahams number, i again "accidentaly" checked grahams number out and felt dumb then lost/forgot innovation for classical progressive/ progressive progressive versions of this model
when somebody takes a sum of 2^3^4^5^6^7^8^9 and then this sum will "^" itself, so much times as the sum's value is, is it at the end greater than grahams number? and if, then why?(if graham loses then because it ends on g64?)
i knew i shouldn't let myself influence myself by infesting my mind again with grahams number to "show off" that my number is bigger, now i can't think anything because I am also mentally in hard times where i also forget vocabulary from foreign languages and to confirm something like this isn't what I am now 100% capable of
i won't say why its concepted as it is, i only need confirmation
here is original script
classical
2^3^4^5^6^7^8^9
i0 (basis value number)
i0^i0
i1
i1^i1
i2
result of highest value of procedures in i0^result of highest value of procedures in i0
. number (classical)
progressive
9^9^9^9^9^9^9^9^9
in9 (basis value number)
in9^in9
in91
in91^in91
in92
result of highest value of procedures in in9^result of highest value of procedures in in9
number (progressive)
Do you mean is (2^3^4^5^6^7^8^9)^(2^3^4^5^6^7^8^9) greater than grahams number? I don't have a proof, but I know what Grahams number is and your number is so much smaller that there is no word to compare them... Grahams number is so huge, it's crazy.
fat f... said:
when somebody takes a > > sum < < of 2^3^4^5^6^7^8^9
and then this > > sum < < will "^" itself, so much times as the
> > sum's < < value is, ...
Those are not sums.
And your notation is ambiguous.
For instance, if you mean 2^3^4 to be [tex]2^{3^4},[/tex]
then you would use grouping symbols, such as in:
2^(3^4) = 2^(81).
On my graphics TI-83 Plus calculator, 2^3^4 is evaluated as 4096,
or equivalently, it treats it as (2^3)^4.
So, your expression should be typed as (or similar to):
[2^(3^(4^(5^(6^(7^(8^9))))))]^[2^(3^(4^(5^(6^(7^(8^9))))))].
I always though with exponent towers you start at the top, not the bottom, I'm rather sure that's how you work with those... Regardless, your number is less than Grahams number.
SumThePrimes said:
1) I always though with exponent towers you start at the top, not the bottom,
2)Regardless, your number is less than Grahams number.
1) The Order of Operations would dictate work from left to right.
The use is inconsistent. For another example,
the TI-30XIIS with the display of "2^3^2" returns "64."
Therefore, to avoid any ambiguities, use grouping
symbols as I did.
2) It's not "my" number. It's a clarification of the OP's
intended number.
I'll give you a number to beat Graham's number:
Let Tier(n) = n raised to itself n times (n tiers)
Examples:
Tier(2) = [tex]2^2[/tex]
Tier(3) = 3^(3^3) [tex]\ = \ 3^{3^3} \ = \ 3^{27}[/tex]
Look at Tier(a googleplex**) to be Graham's number
____________________________________________
** where a googol = [tex]10^{100}[/tex]
And a googleplex = [tex]10^{a \ googol}[/tex]
When I said your number I was referring to the original posts number, not necessarily your clarification of it. I thought I knew the syntax with these towers, I know tetration starts at the top, it probably is best to use grouping symbols, as you say. Although I am rather sure in general you start from the top... With grouping symbols you can't go wrong, though. Also, the new number, a googleplex to the googleplex a googleplex times, I think that might be smaller, although I can't do that in my head :rolleyes: , is there any way to show which one is larger, I don't see that it is obvious.
SumThePrimes said:
... I know tetration starts at the top, ...
[tex]2^{3^2} **\ is \ not \ ambiguous.[/tex]
It is equal to [tex]2^{(3^2)} \ = \ 2^9.[/tex] So having the parentheses is
redundant in this case.
But, the grouping symbols in [tex](2^3)^2[/tex]are necessary to convey [tex]8^2.[/tex]
** But this contrasts to the "different animal" of expressions typed out on one line,
which are not necessarily treated the same.
Agreed, to me it is not "obvious," and I don't use that word in mathematics anyway.
I don't even know if it's true.
i wasnt happy with how grahams number looked and i didnt understand why it was as it is (ends on g64) and i felt to prove a number most logically as possible which would make sense, also motivation was to this is that i have personal issues with numbers, i wanted to publish it long ago. I am numerologist not mathematician thus i use maybe wrong terminology http://youtube.com/watch?v=rC_po1PMRWA here (video is aimed at average audience). there is also a text form of it if u don't want to watch the video, the problem to be solved is at the end of it.
im aware of notation problem, i was already in another forum to solve this, google calculator sums it up as 2^(3^4) and calculator (2^3)^4, i didnt know why google/calculator have it different and i wanted to get the highest value of it but because i didnt want to mess with 2^3^4... and make it more complicated(because it wouldn't be logical why it ( ) had to be there and not somewhere else) thus i just let them be as it is(which has value like in calculator)http://simple.wikipedia.org/wiki/Graham's_number
and this version is different from
http://en.wikipedia.org/wiki/Graham's_number
which one is actually right?
what i found out in wolfram alpha is that the more 9999999999(or how much ever)^ are added the more there will be 9 as last digits
ex: 99999999999999999^9999999999999999^99999999999999^999999999999999^999999999999999999^9999999999999999^9999999999
one can think that it aims to fill whole number(result) in 9s because the more 99...9^99...99 are added the more it will have 9s(ending on 9 from the last digit)
but soon it becomes obvious that result gets higher and higher with every time more 999^999 are added to it compared to the 9s which will result as of this 99...9^99...9 pattern
if it would bring over 50,0%(even 50,000001% would be beneficial) of 9s in the final result then it will sometime fill whole number with 9s and leave no space for other number thus "completing" it
but it looks like it will go on forever in hope of sometime filling whole result in 9s and thus never will reach its goal, is this how concept of infinity is trying to represent itself mathematically? its like unending 0.999999999 which never gets any other number than 9 because if it would it would bring chaos because 9 as in decimal, is transparent(ignores other numbers or doesn't affect their digit sum nature) and will not change its way in computing as long as a 9 will follow itthere r other problems than to watch how others can't write english, like this problem which states that highest assummed number should consist of 9s but method of achieving it, what is it?
i should also note that 9 doesn't add anything up in the result so that 1/9(because 10 doesn't count here) or 1,2,3,4,5,6,7,8 can be counted except 9 + all other 9s which result from that 99...999^9999...99 thing, but it still wouldn't reach above 50% to make it sometime come to an endim sure you see what i mean (id also would like to see the ratio from these 9s in the result to the adding up of 999999999^999999999s (this time its exact 9 digits), does ratio change very time with every new adding up?)
this is actually ******** what's highlighted in magenta as i now found out, don't know why this 8 is stuck there(probably because 1 can't be exponentiated thus only 8 digits remain = 8 or 2+3+4+5+6+7+8+9=8, also needs to be solved)
but anyways, is classical-infinity at least bigger than graham's?
Examples:
Tier(googolplex) is MUCH less than Graham's number. For a good description of Graham's number, look here: http://frothygirlz.com/2010/01/14/big-numbers-part-2/
To understand Graham's number, you need to understand Knuth's up-arrow notation. Basically,
a^^b = a^a^a...^a with b a's
a^^^b = a^^a^^a...^^a with b a's
a^^^^b = a^^^a^^^a...^^^a with b a's
and so on. Note that operations are taken from left to right.
So Tier(googolplex) is googolplex^^googolplex. Tier(googolplex) is much less than 3^^^4, as
3^^^2 = 3^^3 = 3^3^3 = 3^27 = 7,625,597,484,987
3^^^3 = 3^^3^^3 = 3^^7,625,597,484,987 > Tier (7.6 trillion)
3^^^4 = 3^^3^^3^^3 = 3^^3^^7,625,597,484,987 > Tier(Tier(7.6 trillion))
and since Tier(7.6 trillion) much larger than googolplex, 3^^^4 > Tier (Tier (7.6 trillion)) is much larger than Tier(googolplex)
3^^^^3 = 3^^^(3^^^3) is MUCH larger than 3^^^4, and hence MUCH larger than Tier(googolplex). And yet this is just G1, the first stage in constructing Graham's number.
G2 = 3^^^...^^^3 where there are G1 arrows.
G3 = 3^^^...^^^3 where there are G2 arrows.
G64 = 3^^^...^^^3 where there are G63 arrows.
Graham's number is G64.
It ends after 64 stages because that was how many stages Graham needed to yield a sufficiently large enough number of dimensions in his proof of the Graham-Leeb-Rothschild theorem. In other words, he was actually picking the smallest number that he needed, not the largest. Still, Graham's number is far larger than most people's attempts at creating large numbers.
It's not the biggest number ever, as you can just add one a create a bigger number. In fact, it's MUCH smaller than Graham's number. I don't know what you mean by the largest "logical" number.
Unsurprisingly, the regular wikipedia version is the accurate one, and the more thorough one at that. The simple wikipedia version has several errors, but the basic description is the same.
Nope. Recall the definition of ^^ and ^^^ from my previous post:
So i0 = 2^3^4^5^6^7^8^9 < 9^9^9^9^9^9^9^9^9 = 9^^9. (In fact, i0 < 9^(9^9) if you do the operations in calculator order.)
You then take i0 to the power of itself i0 times. This is similar to taking an exponential tower of i0 i0's; to be precise, classical-infinity will be between i0^^(i0+1) and i0^^(i0+2). So we have
classical-infinity < 9^^(9^^9) = 9^^^3.
9^^^3 is less than 3^^^4, which is MUCH less than 3^^^^3 = 3^^^(3^^^3). This last number is just G1, the first stage in constructing Graham's number.
So classical infinity is much less than G1, to say nothing of G64.
it had something to do with hypercube or something, therefore it was a 3
i said there also that it isn't the biggest number,but its the biggest number which made sense until now, in the sense of trying to find out the biggest number among numbers from 1-9
i started to doubt the result already while i tried to compare my number with g64, thus i got a problem to which i haven't found answer yet because its about finding a perfect formula in the mysteries system of numbers which will then answer and without doubt will be the biggest number which will be used as an evidence and will make sense(in same sense as that number which i invented or discovered), its just that i don't know where to start finding the formula, its a precise formula which makes sense that i didnt discover yet, i know its mostly about 1 number because other numbers arent mysterious as the highest number in decimal system(it would cause problems if other systems will be considered but decimal system is more accepted as standard)
i couldn't let it stand that some retard made out of necessity the biggest number which i met although he doesn't respect numbers as i, i consider numbers mysteriously, mostly the 9(or only the 9) because i found out by myself the nature of this number, due to its nature it became my favorite number and the most special number out of all(except that 1 has also special nature to it), i consider numbers as something like tools of god, i wouldn't stand it if people would consider g64 as biggest number forever or that graham sometime just made this number and its considered until now by all people as the number, i could beat this number just by changing 3 to 9(and it would be legitimate in some sense) but it would be cheap and wouldn't prove anything as i also could 3 to value of 9^9^9^9^9^9^9^9^9, it has no reason which number there should be, i search for this mysterious formula which would make perfect sense, he had knowledge but he didnt understand numbers and he had time to study it all, i have no knowledge and I am not mathematician, I am numerologist and graham isn't in my category and I am not in his(because i neither understand the problem for which he invented this number, but it looks like it was unimportant boring problem(not that it would be worldshaking the solution))
is 3^^^^3 = 7,625,597,484,987^7,625,597,484,987 ? or result of 3^7,625,597,484,987 ^ 3^7,625,597,484,987 ?
and why did he stop at 3^^^^3 and didnt made 3^^^^^3?
and i addressed a problem:
this is actually ******** what's highlighted in magenta as i now found out, dont know why this 8 is stuck there(probably because 1 can't be exponentiated thus only 8 digits remain = 8 or 2+3+4+5+6+7+8+9=8, also needs to be solved)
I'm new to the Forum and have always been interested in large numbers. I recently became aware of Graham's number and have seen various descriptions of it so I have a cloudy appreciation of how truly large it is (I emphasize 'cloudy'). I also recently came upon the website http://users.skynet.be/nizgorur/very_big_numbers.htm where it describes very large numbers with formal names attached (not sure of the naming validity but they seem legitimate). Near the bottom, it describes "fugagargantugoogolplex" as: gargantugoogolplex raised to the gargantugoogolplex power a gargantugoogolplex times.
Question... assuming Graham's number is larger (?) than fugagargantugoogolplex, can anyone state at approximately which number (Gsub3, Gsub10, or whatever point along that path to Gsub64) Graham's number EXCEEDS fugagargantugoogolplex?
I hope I've stated my question correctly, and I'm hoping to put both numbers in relative context with each other in order to better appreciate both.
Thank you!
A gargantugoogolplex is googolplexplexplex, or 10^10^10^10^100. (Apparently, there is some question about this, according to http://sites.google.com/site/largenumbers/home/3-2/2, which cites the original source and suggests that it should be smaller. But we will assume the larger value.)
fuga(n) = (...((n^n)^n)...^n)^n with n n's = n^(n^(n-1)) < n^(n^n).
So fugagargantugoogolplex < gargantugoogolplex ^ (gargantugoogolplex ^ gargantugoogolplex)
= 10^10^10^10^100^(10^10^10^10^100^(10^10^10^10^100))
= 10^10^10^10^100^(10^10^(10^10^100 + 10^10^10^100))
= 10^10^(10^10^100 + 10^(10^10^100 + 10^10^10^100))
< 10^10^10^(1 + 10^10^100 + 10^10^10^100))
< 10^10^10^10^10^10^101
< 3^3^3^3^3^3^3^3^3
= 3^^9,
where a^^b = a^(a^(a^...(a^a)...)) with b a's. See Knuth's_up-arrow_notation.[/PLAIN]
3^^^3 = 3^^(3^^3) = 3^^7625597484987, which is MUCH more than 3^^9, and therefore much more than fugagargantugoogolplex. And 3^^^3 is nothing compared to G(1), which is 3^^^^3. So G(1) is already much bigger than fugagargantugoogolplex.
@FAT f:
If you read this, sorry for not responding to you. Neither of those numbers are anywhere near 3^^^^3. (This should be clear, as I showed previously that 3^^^^3 was greater than your classical-infinity and progressive-infinity numbers.) 3^7,625,597,484,987 ^ 3^7,625,597,484,987 = (3^3^3^3)^(3^3^3^3) < 3^3^3^3^3^3 = 3^^6, and 3^^^3 is already 3^^7,625,597,484,987, which is 3^3^3...3^3 with 7,625,597,484,987 3's. 3^^^^3 is much bigger, too big to be described as an exponential tower. The most we can simplify it is
3^^^^3 = 3^^^(3^^^3) = 3^^^(3^^7,625,597,484,987)
= 3^^3^^3^^3...3^^3 with 3^^7,625,597,484,987 3's
where each "3^^" means "take the previous number n and create an exponential tower with n 3's".
As to why Graham used 3^^^^3 instead of 3^^^^^3, he simply when as far as he needed to create an upper bound. Note that he doesn't stop at 3^^^^3; that is just G(1). He goes on to G(2), which is 3^^^...^^^3 with 3^^^^3 ^'s, and so on up to G(64).
I don't understand what you are saying with you "don't know why 8 is stuck in there".
Well it would be nice if he actually defined everything properly.
According to the Googology Wiki, a gargantugoogolplex is [tex]10^{10^{10^{10^100}}}[/tex]
So this is less than [itex]10^^5[/itex] and our fugagargantugoogolplex is less than
[itex](10^^5)^^(10^^5) < 10^^10^^10^^10 = 10^^^4 < 3^^^^3[/itex]
which is G1.
I hope I got that right.
Thanks Deedlit and pwsnafu for your great replies! My appreciation for how truly large Graham's number is has now become (a bit) less cloudy. Also, thanks Deedlit for the link. That really helped to explain it in a very informative and entertaining way. Thanks again..
what about googleplexian octated (same as tetrated w/4, but instead with 8)
Stop it. You're absolutely unimaginably nowhere near Graham's number, and it's pointless to try and come up with a larger number.
Octation is a binary function - assuming you meant googolplexian octated to the googolplexian, that is larger than G1, but smaller than G2.
G1 is 3^^^^3, i.e. 3 hexated to the 3.
G2 is 3^^^...^3 with G1 ^'s, so it is 3 "G1 + 2"ated to the 3. Note that even 3 nonated to the 3 is larger than googolplexian octated to the googolplexian, so G2 is MUCH larger than your number.
G3 is 3^^^...^3 with G2 ^'s, so it is 3 "G2 + 2"ated to the 3.
and so on.
Really? Surely you can't mean *exactly* what you said. :)
It seems trivial to come up with a number larger than Graham's Number. Of course, I understand what you mean, though.
I got some numbers way bigger than Grahams puny number done with Conway's arrows.
10^100→10^100→... a Googol times over which = 1 HyperGoogol and each HyperGoogol is like the number before it inside each bit of the chain that many times over on the Conway chain.
This my friends is the place where you find numbers which can only be described by us mere mortals as silly numbers.
A Googol Hypergoogol's Is like flashing up the digits of this number part by part with the whole visible universe with transistors working at the plank length until the whole visible Universe around this visible universe you've turned into a computer is one big elephant simply because of the probability that it could become that and still having more digits to count.
It's just plain silly.
It is easy if you use notations with a similar power (e. g. G65 is larger than G64, of course, and GG64 is even larger) or even more powerful notations (Conway chained arrows).
It is not easy if you try to come up with something similar yourself.
Every tower of exponents (without more powerful definitions inside) is tiny compared to G1, and it is completely pointless to use those towers once you have Gn or conway arrows. G64G64 < G65, and that holds even if you build some large tower of exponents on the left side.
< 3^3^3^3^3^3^3^3^3
= 3^^9,
This is wrong because you assumed "a gargantugoogolplex raised to a gargantugoogolplex a gargantugoogolplex times" to be "a gargantugoogolplex raised to the power of a gargantugoogolplex, raised to the power of a gargantugoogolplex". A gargantugoogolplex raised to the power of a gargantugoogolplex a gargantugoogolplex times = gargantugoogolplex^^gargantugoogolplex, = (10^10^10^10^100)^^(10^10^10^10^100) = (10^10^10^10^100)^((10^10^10^10^100)^(10^10^10^10^100)). MUCH larger than your 3^^9. however, it is still absolutely incomprehensibly smaller than Graham's number.
I just want to say that the amazing thing about Graham's number is that it actually serves a use, other numbers of that immense magnitude are simply trivial. I just thought I would mention this because it seems to be largely ignored on this thread.
Also, for anyone that wants to see a bigger number, although it is arguably less useful, check out the Kruskal Tree Theorem. There are a few other numbers like this that are bigger than Graham's number and serve a purpose, but they aren't as possible and usually considered more trivial.
  • · Replies 32 ·
