This is way easy if you are smart
  • Thread starter Thread starter emerica86
The discussion revolves around calculating the minimum speed required for a rock tied to a string to complete a vertical circle without the string going slack. Participants clarify that at the top of the circle, the only force acting on the rock is gravity, which must equal the centripetal force required for circular motion. The relevant equation, f=mv^2/r, is highlighted, emphasizing that mass cancels out when equating weight and centripetal force. Despite initial confusion about the role of mass, it is established that the problem can be solved without knowing the rock's mass. The conversation concludes with encouragement to visualize the problem through a free body diagram for better understanding.
emerica86
circle question its easy (still need help)
Suppose you tie a rock to the end of a 1.5 m long string and spin it in a vertical circle. What is the minimum speed it can travel and "just" get around the top? (Hint: The rope will just start to go "slack" and the only force acting on the rock, downward, is gravity.)
-------m/s
here is my work:
so i thought it would be 9.9 since 9.8 is gravity or something i am completely lost. if someone could help that would be great
Okay, at the top of the circle what forces are acting on the rock?
gravity ...?
emerica86 said:
gravity ...?
Yes (assuming the string is slack as the hint suggests), so since the rock is traveling in a circle what must the weight of the rock be equal to?
gravity i think but i tried 9.8m/s and it was wrong...
9.81 [m/s^2] is gravitational acceleration, and Hootenanny asked you about a force.
Any object undergoing circular motion must experience a C########## Force.
i don't know what forces are acting on it i am so confused
oh a centriipugal force?
Draw a free body diagram, 2 forces, centrifigal force and gravity, they are equal at the critical point. f=ma for gravity, i can't remember the centrifigal force eqn off the top of my head but mass should cancel and you can solve for velocity.
Its been awhile since intro physics so I'm a bit rusty.
No, centrifugal forces only arise when we consider the circular motion from an non-inertial reference frame (i.e. the rocks), the correct term would be centripetal force. Now, what equations do you know that deal with the centripetal force?
f=mv^2/r ?
emerica86 said:
f=mv^2/r ?
That's the one :smile:, so since weight is the only force acting when the rock is at the minimum velocity, it follows that the weight of the rock must be providing all the required centripetal force at this point. Do you follow?
yes i follow i just don't get what the weight is because the problem says nothign to do with weight.
I'm sure you know that the weight of an object is the product of it's mass and the gravitational field strength (W=m\cdot g)
yes i know that equation I am just saying the origional problem dosent tell you the mass of the rock. so how do you get it?
The question is do you really need it? Equate the weight of the rock with your equation for the centripetal force and see what happens to the mass...
omg i give up unless someone just gives me the answer lol
Okay, I'll give you a hint (but don't be too quick to abandon hope). If we equate the weight of the rock with the centripetal force we obtain;
mg = \frac{mv^2}{r}
Can you go from here?
oh duhh
ok thank you very much
emerica86 said:
oh duhh
My pleasure :smile:
Always start with a FBD and just look at the situation, often times the picture will make it easier to understand. Sum the forcs in the x and y directions, this will tell you what the forces must be, then all you have to do is find the rigth formulas and solve.
13K
9K
