Three equal charges held by equal length strings
11 replies · 3K views
mr_sparxx
Three particles with the same charge q are hold together by three strings of the same length l forming an equilateral triangle. The tension in each string is:
a) ## \frac {K q^2 cos 60º}{l^2}##
b)## \frac {K q^2 cos 30º}{l^2}##
c)## \frac {K q^2 sin 60º}{l^2}## or
d)## \frac {K q^2 sin 30º}{l^2}##
It is a multiple choice question.
Coulomb's law for electrostatic force: ## F = \frac {K q_1 q_2}{d_{12}^2} ##
Well, numbering the charges from 1 to 3, we get that the total force acting on the third charge is the sum of the tensions plus the sum of the elecrostatic forces:
$$ \vec F = \vec T_{13} + \vec T_{23} + \vec F_{13} + \vec F_{23} = 0 $$
Furthermore, the symmetry of the problem implies that:
$$ T_{13} = T_{23} = T_{12} $$
$$ F_{13} = F_{23} = F_{12} $$
So, in the two directions where forces lie
$$ \vec T_{13} = - \vec F_{13} $$
$$ \vec T_{23} = - \vec F_{23} $$
And, therefore
$$ T_{13} = F_{13} = \frac {K q^2}{l^2} $$
The tension in the other strings is exactly the same.
I am unable to see my mistake, simple as it may be...
Part 1 has me a little confused, there are three strings and 4 components are given but not associated with a particular string.
What exactly is the question? Parts 2 and 3 look correct.
Thanks for your answer.
I am sorry, I should have said it is a multiple choice question: a, b, c, or d are the answer options. I'll update the post.
Could it be possible that the question is wrongly formulated or the answers wrong? This is the exact text of the question...
I think you are headed in the right direction. Please state the exact question you are to answer :woot:
The exact question is the one stated in part 1. I have to write a, b, c or d in the answer sheet and my result I am getting is different to all four choices: that's why I am so confused.
Sorry, I am confused as well, it looks to me like you have the correct answer in part 3 above. I did the problem the same way you did.
Maybe it is like this with the three strings attached at a common point,
I think we both read it the wrong way? If like above you can figure it out. I thought the strings formed the sides of an equilateral triangle and my mind was locked into that as the only possibility. A Google image search allowed me to see the other possibility.
https://www.google.com/search?q=ten...bAhUFk1kKHZ0FDt44ChD8BQgLKAI&biw=1164&bih=537
Good thought. But it doesn't appear that this interpretation would give one of the choices either (unless I'm messing up somewhere).
Edit: Note that answers (a) and (d) are the same. Also, (b) and (c) are the same. @mr_sparxx please check that you have written the choices correctly.
Thank you for your answers and thoughts. I posted it here because I thought it was the most relevant place but, in fact, this problem comes from a past access exam paper one of my students brought to me. I was unable to give him an answer. Tomorrow I'll take a picture of it to be sure .
@Spinnor I am quite sure there was a diagram... but that turn you proposed was quite inspiring. However I think there is a ##\sqrt 2## factor discrepancy with the b/c choices.
@TSny I didn't notice!
Anyway, I was not confident enough to think the question was wrong (it is a quite prestigeous university access exam), but I am beginning to think this is the case.
If the picture in @Spinnor 's post #7 is correct, then I believe any of the answers (a) through (d) would be correct if the trig function factor is replaced by ##\tan 30^0##.
Actually what was wrong was my handwritten copy of the answer choices! :H I am so embarrased! :eek::sorry:
Choices were:
a) ##\frac {K q^2 sin 60º}{l^2}##
b)##\frac {K q^2 cos 60º}{l^2}##
c)##\frac {2 K q^2 sin 30º}{l^2}##
d)##\frac {2 K q^2 cos 30º}{l^2}##
And it is obviously c)...
Sorry for wasting your time!
Edit: in the end strings were the sides of the triangle, each holding two charges together...
OK. No problem. Glad it got cleared up.
