Three equal charges held by equal length strings
The problem involves three equal charges arranged in an equilateral triangle, connected by strings of equal length. Participants are tasked with determining the tension in the strings based on provided multiple-choice options.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants discuss the forces acting on the charges, including tensions and electrostatic forces, and explore the implications of symmetry in the problem. Some express confusion regarding the formulation of the question and the provided answer choices.
The discussion has revealed differing interpretations of the problem setup, with some participants questioning the accuracy of the answer choices. Clarifications about the arrangement of the strings and charges have been suggested, leading to further exploration of potential discrepancies in the problem statement.
Participants note that the problem originates from a past exam paper, and there is uncertainty regarding the presence of a diagram that may clarify the setup. Some mention a possible error in the transcription of answer choices, which has contributed to confusion.
mr_sparxx
Three particles with the same charge q are hold together by three strings of the same length l forming an equilateral triangle. The tension in each string is:
a) ## \frac {K q^2 cos 60º}{l^2}##
b)## \frac {K q^2 cos 30º}{l^2}##
c)## \frac {K q^2 sin 60º}{l^2}## or
d)## \frac {K q^2 sin 30º}{l^2}##
It is a multiple choice question.
Coulomb's law for electrostatic force: ## F = \frac {K q_1 q_2}{d_{12}^2} ##
Well, numbering the charges from 1 to 3, we get that the total force acting on the third charge is the sum of the tensions plus the sum of the elecrostatic forces:
$$ \vec F = \vec T_{13} + \vec T_{23} + \vec F_{13} + \vec F_{23} = 0 $$
Furthermore, the symmetry of the problem implies that:
$$ T_{13} = T_{23} = T_{12} $$
$$ F_{13} = F_{23} = F_{12} $$
So, in the two directions where forces lie
$$ \vec T_{13} = - \vec F_{13} $$
$$ \vec T_{23} = - \vec F_{23} $$
And, therefore
$$ T_{13} = F_{13} = \frac {K q^2}{l^2} $$
The tension in the other strings is exactly the same.
I am unable to see my mistake, simple as it may be...
Part 1 has me a little confused, there are three strings and 4 components are given but not associated with a particular string.
What exactly is the question? Parts 2 and 3 look correct.
Thanks for your answer.
I am sorry, I should have said it is a multiple choice question: a, b, c, or d are the answer options. I'll update the post.
Could it be possible that the question is wrongly formulated or the answers wrong? This is the exact text of the question...
I think you are headed in the right direction. Please state the exact question you are to answer :woot:
The exact question is the one stated in part 1. I have to write a, b, c or d in the answer sheet and my result I am getting is different to all four choices: that's why I am so confused.
Sorry, I am confused as well, it looks to me like you have the correct answer in part 3 above. I did the problem the same way you did.
Maybe it is like this with the three strings attached at a common point,
I think we both read it the wrong way? If like above you can figure it out. I thought the strings formed the sides of an equilateral triangle and my mind was locked into that as the only possibility. A Google image search allowed me to see the other possibility.
https://www.google.com/search?q=ten...bAhUFk1kKHZ0FDt44ChD8BQgLKAI&biw=1164&bih=537
Good thought. But it doesn't appear that this interpretation would give one of the choices either (unless I'm messing up somewhere).
Edit: Note that answers (a) and (d) are the same. Also, (b) and (c) are the same. @mr_sparxx please check that you have written the choices correctly.
Thank you for your answers and thoughts. I posted it here because I thought it was the most relevant place but, in fact, this problem comes from a past access exam paper one of my students brought to me. I was unable to give him an answer. Tomorrow I'll take a picture of it to be sure .
@Spinnor I am quite sure there was a diagram... but that turn you proposed was quite inspiring. However I think there is a ##\sqrt 2## factor discrepancy with the b/c choices.
@TSny I didn't notice!
Anyway, I was not confident enough to think the question was wrong (it is a quite prestigeous university access exam), but I am beginning to think this is the case.
If the picture in @Spinnor 's post #7 is correct, then I believe any of the answers (a) through (d) would be correct if the trig function factor is replaced by ##\tan 30^0##.
Actually what was wrong was my handwritten copy of the answer choices! :H I am so embarrased! :eek::sorry:
Choices were:
a) ##\frac {K q^2 sin 60º}{l^2}##
b)##\frac {K q^2 cos 60º}{l^2}##
c)##\frac {2 K q^2 sin 30º}{l^2}##
d)##\frac {2 K q^2 cos 30º}{l^2}##
And it is obviously c)...
Sorry for wasting your time!
Edit: in the end strings were the sides of the triangle, each holding two charges together...
OK. No problem. Glad it got cleared up.
