Time as an objective entity is invalid as an actual object
  • Context: Graduate
  • Thread starter Thread starter HeavensWarFire
    Time
The discussion revolves around the nature of time, questioning whether it is an objective entity or merely a human construct. Participants explore various perspectives on time as a dimension, its relationship to measurement, and its implications for understanding change and motion. The conversation includes theoretical considerations and philosophical implications, with no consensus reached on the validity of time as an actual object.
  • Some participants argue that time is a human construct and does not pertain to anything outside human perception.
  • Others propose that time may be a dimension distinct from space, suggesting that time connects different dimensions or "branes."
  • One participant questions the assertion that time is a construct by pointing out that events do not occur simultaneously, implying a need for a framework to understand temporal order.
  • Another participant suggests that time serves as a system of measurement similar to other units, emphasizing its role in describing change and duration.
  • A later reply challenges the idea that time is merely an illusion, asking for clarification on why events happen at different times if time does not exist.
Participants express multiple competing views on the nature of time, with no consensus on whether it is an objective reality or a subjective construct. The discussion remains unresolved, with ongoing questions about the implications of each perspective.
Participants highlight various assumptions regarding the nature of time, measurement, and the relationship between motion and temporal perception. The discussion reflects differing interpretations of how time is understood across different contexts and frameworks.
  • #61
My point is simple if it isn't all arbitrary then it has a physical component that would lead me to believe that it was existent, since there isn't one, the "arbitrariness" of it all leads me to see that there is a reason(s) why there is no physical proof, and helps me to know that it is simply the application of an "Ideal" hence no "physically existent" component to it.
Location/location/location?
(this planet! (Earth) at, roughly the center of the Universe, the Universe's Luminous 'sphere') :smile: :smile:
As to your last statement, HUH?
P.S. case you hadn't notice I haven't tried to disprove time as "A useful thing", as "An ability to meter motion", especially relative motions as that it what 'timing' is about, the act of it, but in the 'Largesse' of nessecary knowledge of the construct of the Cosmos it is requisite that the conundrum of how an infinity could have "No time", and our universe "Have time", must be "resolvable" by anyone who proposes tackling those kinds of questions...so perhaps it is you who should be more careful...HUH! whatdayathink?
  • #62
A cesium atom does not oscillate at an arbitrary rate.
  • #63
(Sorry!) So you mean that if you heat it, chill it, electrocute it, magnetise it (or all of the space around it) it still keeps that oscillation rate? even in the center of the Sun at the Gravitational pressure(s) achievable there? Ya sure 'bout that?
  • #64
I said nothing of those effects. But they are not arbitrary either.
  • #65
Humm, I did, and it renders the 'oscillations of the Cesium atom' as arbitrary, AKA not fixed, not "physically attached", no "Objective entity"...just the application of an 'Ideal' to a reality..
After all russ, all a clock is is a secodary counter/measure that permits us to measure 'relative' measurements...when a 4 inch dia. clock, cycles once, we have a 'foot' of time, we use that measure to relitivize the other measures of space that we took in the distance traveled and then apply the entirely arbitrary secondary measure as to allow us a baseline of comparision, but the baseline is not derived from anything that qualifies as "objective entity", but simply the observation of the distance traveled, by the Earth, in respect of the Sun...No time russ, not as an "object existent in reality".
(even though we can create the 'objects' to do this kind of cyclic counting for us)
  • #66
Hello. I'm new here and found this thread interesting. I'll state up front that I have no formal education in physics above an associates degree in electronic egineering technology. Anything I say may be taken with a grain of salt. I should say, rather, I won't be offended if someone tells me to get lost. :)
I've often thought about time as it relates to physics (SR) and how we perceive the 'flow' of time or alternately, our motion through time. Don't worry, this isn't the beginning of some cranky theory.
Consider the three spatial dimensions. 3D-Space has three axes which are mutually perpindicular. These three axes define the degrees of freedom of motion which we can experience in that space. We can move forward, backward, left, right, up and down. We can also rotate around each of these axes in two different directions.
There are two other degrees of freedom that I have not mentioned: Faster and slower. On the surface, they seem to be completely unlike the other motions I've listed above.
Consider Space-time. When an object is plotted on a space-time diagram, acceleration (a change in speed) appears to be a change in direction or a rotation around a fourth axes. I realize that this isn't evidence that time is a physical dimension but wouldn't a fourth physical dimension be necessary to accommodate the extra degree of freedom that acceleration entails? This is not a rhetorical question and I am interested in everyone's thoughts on this.
If we consider the three spatial dimensions as physical and time as just an abstraction, does that leave any room physically for acceleration? It seems to me, and I freely admit that I could be wrong, that a fourth 'physical' dimension is needed to go faster and slower. The physical sensation of a change in speed is curiously similar as that of a spatial rotation. Again, I realize that this isn't proof but it is compelling for me.
Of course, there are definite asymmetries bewteen spatial rotations and acceleration (change in speed). An object can rotate indefinately in space but we certainly can't 'rotate' indefinitely around this fourth axis. There is a definite limit on how fast we can go or how much we can rotate around this fourth axis. Can acceleration in this sense be considered a hyperbolic rotation? I'm not sure of the details but wouldn't you have to use the hyperbolic functions to describe acceleration in a 4D context?
When considering time to be a physical property of the universe, as in SR and GR, the physical implications such as time dilation, length contraction, etc, seem to be confirmed to a high degree of accuracy eperimentally.
Like I said above, I'm not a physicist and I am curious as to whether my thinking is correct if even partially.
  • #67
The problem seems to relate to the SPACE itself that is dynamic, ie:Contracting Frames and Expanding Frames.
If one was to know that the spacetime you occupy is in Expansion, then say you move to another part within this spacetime, then it is obvious that the space you trancend is scale dependent. From one location to another the space that surrounds you will be moving away from you in all directions (expansion) what you experience is the dilation of movement 'in-between', from loaction to location.
Now if one was to move from a 'contracting' frame to an Expanding frame, then you would have to move from Galaxy to Galaxy, with the intervening space being the 'Expanding frame', upon arrival you would have to agree that the Galaxy that arrive at would appear to be in Contraction.
It seems counter-intuitive that we exist inside spacetime (Galaxy) that is steady, the space we have all around us is expanding by a different process that of the intervening space between Galaxies, namely Galaxies have Stars that produce Photon Pressure, this gives Spacetime its own steady-state of Spacetime.
Quote:It seems to me, and I freely admit that I could be wrong, that a fourth 'physical' dimension is needed to go faster and slower. The physical sensation of a change in speed is curiously similar as that of a spatial rotation. Again, I realize that this isn't proof but it is compelling for me.
But this cannot have another dimension hidden within?..this is what Galaxies are, they are fused space(the intervening expanding space) with another space (photon-space around matter) into a dimensional area we call Spacetime. Any motion within Galaxies is along 3-dimensional routes that are equivilent, not until you leave a Galaxy would you be able to determine the space you are moving in(intervening space) has no Time componant, and is completely 2-dimensional, and all routes are now restricted to just motions along these dimensional routes, fixed and have constant restrictions such non-rotational motions.
The straightest path through spacetime(Galaxies-the more matter the more curved space) is along the curves caused by Matter.
The straightest path through space is always fixed as there is no Matter, no 'Time-curves', and is therefore instant and direct.
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 21 ·
  • · Replies 17 ·
