Philjhinson
- 5
- 0
Does time go slower on the hemisphere of Earth that is currently rotating counter to Earth's orbit than the side the side that is rotating with Earth's orbit
The speed between them is zero. By the way, you don't have to say "relative" because there is no other kind.Philjhinson said:I get that but if you we're stood on the equator and could look through the Earth to clocks on the other side, presumably their relative speed and clocks would be different to your own...
Philjhinson said:if you stood on the equator and could look through the Earth to clocks on the other side, presumably their relative speed and clocks would be different to your own
I can't parse that. Are you creating an earth-centered, non-rotating frame for one and having the other move with respect to it? Why one and not both? Why would you do that? When I say the speed is zero, I mean nothing more or less than that the distance between them is not changing with time.A.T. said:What is "speed between them"? In the instantaneous inertial frame of each clock the other clock has non-zero speed.
What am I missing here: are you saying that if I watch his clock over a very long period of time, they will accumulate different elapsed times? How is that possible?Nugatory said:Yes. Because the guy on the other side of the Earth is moving relative to you, you will find that his clocks are running a bit slow (time dilation) and his meter sticks will be a bit short (length contraction) compared with yours.
But please do remember that as far as he's concerned, he's the one who is at rest and you're the one who is moving; he finds that you're the one whose clocks are running slow and and whose lengths are contracted. You're both right.
The velocity of the second clock is zero in the earth-centered rotating frame in which the first clock is constantly at rest. It is non-zero in the inertial frame in which the first clock is instantaneously at rest.russ_watters said:What am I missing here: are you saying that if I watch his clock over a very long period of time, they will accumulate different elapsed times? How is that possible?
OK...so if I drill a hole through the Earth and watch the other clock with a telescope, what do I see? Are our clocks deviating in elapsed time/tick rate or not? I don't think they are.jbriggs444 said:The velocity of the second clock is zero in the earth-centered rotating frame in which the first clock is constantly at rest. It is non-zero in the inertial frame in which the first clock is instantaneously at rest.
In the instantaneous co-moving inertial frame in which the first clock is at rest, the second clock is running slow. And vice versa. In the earth-centered rotating frame (and using an earth-centered inertial synchronization convention) it is clear that both clocks tick at the same rate.
Philjhinson said:Does time go slower on the hemisphere of Earth that is currently rotating counter to Earth's orbit than the side the side that is rotating with Earth's orbit
Ibix said:It depends where you are watching from. Time dilation isn't an absolute - it's something that is measured by an observer in motion relative to the thing being observed. So, an observer hovering above the Earth (not orbiting, just hovering) would see Earth's clocks ticking at the same rate at all times of day because they are always traveling at the same speed relative to him. An observer hovering above the Sun (i.e. not orbiting the Sun) would see clock rates varying depending on the local time, yes.
Philjhinson said:I get that but if you we're stood on the equator and could look through the Earth to clocks on the other side, presumably their relative speed and clocks would be different to your own, sorry if I'm asking a dum question just starting to get my head round this
1977ub said:This is an interesting question to me - I realize that in the simplified version where we treat both my location and the opposite point as inertial frames we can look through across at each other and see in the moment that the other guy's clock is slow. But over time this would not make sense, we have to see each other's clocks as moving at the same rate - and this must have something to do with the fact that in the long run we are *not* moving in inertial frames, and so regular SR questions & answers don't apply...
Nugatory said:It's not that regular SR doesn't apply - SR works just fine in accelerated and non-inertial frames (although the math gets more complicated without bringing in any fundamental new insights so you seldom see these cases covered in introductory texts).
1977ub said:I meant only in the specific sense of comparing tick rates with the other side of the rotating Earth. SR might suggest that these opposite-moving frames will find the other guy's clock to tick more slowly, but it would take extended time spent on these IF trajectories for these measurements to occur and make sense.
russ_watters said:Guys, I think this is being over-complicated and as a result, the OP is walking away with a wrong answer. The way I read the OP's question is that he is asking if the rotation speed and orbit speed with respect to the fixed stars add/subtract to generate time dilation between observers on opposite sides of the earth. In other words, if you are on the equator at sea level on Earth and you drill a hole through the Earth and watch someone else's clock who is also on the equator at sea level and compare it to yours, over the course of days, would you see the other person's clock speed-up and slow down compared to yours as you each move faster and slower with respect to the fixed stars?
If that is indeed the OP's question, it doesn't "depend". The answer is just no. Right?
See means observe. You of course could not use your eyes, you'd have to use electronic means such, like GPS satellites do. One device sends a continuous stream of time signals, the other device compares them to a local clock.1977ub said:What does "see" mean here?
For now I'd like to set aside the every increasingly complexity reference frame choices and just answer the question of what the result of this experiment would be.If we accept that neither location is moving in an inertial frame, then any calculation of faster or slower clock susing SR principles would be incorrect, right?
russ_watters said:See means observe. You of course could not use your eyes, you'd have to use electronic means such, like GPS satellites do. One device sends a continuous stream of time signals, the other device compares them to a local clock.
It's simpler than that. The tick rate that is "seen" will be exactly regular, always. All inertial reference frames will agree that the "seen" tick rate will match the proper time of the [non-inertial] observer.1977ub said:So you don't mean "determine" then way SR normally compares the signals between frames, using Einstein synch etc. You are asking if they sit there with their eye to their telescope and record the ticks, are they slowed down. If that is what you mean, then I think that the ticks will not be regular, but on average they will come at the same rate. I mean, if the observer and source are both speeding up and slowing down wrt an IF, and the light from the source to the observer only travels reliably at C in an IF, then there are small complications to the overall regular rate (accepting that the average speed wrt IF of both ends is the same).
jbriggs444 said:It's simpler than that. The tick rate that is "seen" will be exactly regular, always. All inertial reference frames will agree that the "seen" tick rate will match the proper time of the [non-inertial] observer.
This is clear from symmetry. If you picture the Earth rotating in the middle of nowhere, no one time is more special than the next. There is no particular time when the seen clock rate will be slower than average and no particular time when it will be faster. If the laws of physics predict a "seen" tick rate at all, that rate must be constant.
First, there is no such thing as being "in an inertial frame". There is such a thing as being "at rest in an inertial frame".1977ub said:If someone is in an IF writing down the time of light pulses as they are seen from a regularly emitting beacon, and that beacon is *not* in an IF, the ticks will be received at irregular intervals. Right? Then doubly so if observer is not in an IF.
As long as the Earth is moving in free fall, those complex motions are, at least to first order, irrelevant. And way way above the level of OP's concern.But in idealized Earth spinning by itself, with photons coming through an optical fiber through the middle, then no irregularity. But OP had asked about impact of the complex motions of points of the earth.
jbriggs444 said:Second, it is not true that an inertial observer will necessarily see irregular ticks when observing a non-inertial beacon. Take, for instance, the case of an observer sitting inertially in a hole in the center of a transparent earth. The tick rate that he "sees" from an object in orbit may be slowed down. But it will be regular.
jbriggs444 said:First, there is no such thing as being "in an inertial frame". There is such a thing as being "at rest in an inertial frame".
Third, it is not true that a non-inertial observer will necessarily see irregular ticks when observing an inertial beacon. For instance, put the beacon at the center of a transparent Earth and put the observer in orbit.
Fourth, it is not true that two irregularities must add to produce an increased irregularity. They can cancel.As long as the Earth is moving in free fall, those complex motions are, at least to first order, irrelevant. And way way above the level of OP's concern.
