- 13,929
- 16,821
The events are fixed, but observers do not in general agree on the place or time at which those events occur. This has consequences for their interpretation of what follows.Grimble said:Yes, the light sources will be moving, but the events where the light is emitted from those source, being events are fixed, regardless of where those sources go subsequently.
By that definition, the pulses do not meet halfway between, in general. Why would they? They were emitted at different times in most frames.Grimble said:'Halfway between' means the midpoint of a line drawn between those events.
I really don't understand this sentence.Grimble said:But it is not the centre of the rod that it is observers who are at rest at the midpoint between the Events where the lights were emitted, the centre of the rod may no longer be at that point, it will have moved away.
Let's draw this out, working with the setup where a light pulse is emitted from the center of the rod, reflected from mirrors at each end, and returned to the middle. Here is a Minkowski diagram of the setup in its rest frame:
This is a graph of the position of the various parts of the experiment as a function of time, with some key points marked. The red line represents the middle of the rod. It is not moving, so its position (place on the horizontal axis) is the same at all times. The two blue lines represent the mirrors. Again, these are not moving, so their position is also the same at all times. Note that the middle of the rod and the two mirrors are not events (which are points in 4-d space-time). Rather, they are lines which are what points in 3-d space look like in 4d space-time.
At the bottom of the diagram, a red square marks the event where the light pulses are emitted. I have drawn the lines traced out by the light pulses in yellow. Since the pulses are moving (their position is changing with time), their lines are sloped. They are sloped in opposite directions because they are moving in opposite directions. The pulses strike the mirrors at the events marked in blue squares and return, meeting again at the middle of the rod at the event marked with an open square.
I want to draw your attention to something - the mirrors are not at the reflection events most of the time. They do always share a spatial coordinate with the reflection event, but only share a time coordinate at the instants that their respective light pulses strike.
Now let's look at this from a different frame. In this one, the rod is doing 0.6c, which gives a nice round γ factor of 1.25:
The symbols on the diagram are the same as before. In this frame, however, all of the lines are sloped since the rod is moving - changing its position with time. You can see that the reflection events are not simultaneous, and you can see why - one of the pulses meets a mirror coming towards it while the other has to chase after its mirror. The first one has a shorter distance to travel. You can also see that the pulses meet again at the center of the rod (which is in a different place from where it was when it emitted the pulses). You can also see why they meet there - the pulse that met the mirror coming towards it (has a short journey) has to chase after the center of the rod (and has a long journey), while the opposite is true of the other pulse. This is how simultaneous emission and simultaneous reception do not imply simultaneous reflection - the total journey time for each pulse is the same, but the lengths of the legs are swapped round.
Finally, you can see what is wrong with your "'Halfway between' means the midpoint of a line drawn between those events". The midpoint of the line is an event on the worldline of the center of the rod, but it is not (in either frame) the same event as the reception of the reflected pulses. Interpreting your definition a bit more loosely as "the line of constant position through the event half way between the reflection events", then this is a vertical line through the event half way between the reflection events. You can see that this is still wrong - only in the special case of the rest frame of the rod is this where the pulses meet up.
The reflected pulses meet up at the center of the rod in all frames, because there would be self-contradiction if they did not. However, the center of the rod does not, in general, occupy the same spatial coordinates at the time of emission and the time of reception.
