Time dilation to go a specific distance
6 replies · 2K views
sparks97
Traveling on a spaceship to Alpha Centauri A, 4.37 light years away, at a velocity of 0.92 c,
if you just calculate the time by dividing the distance by the velocity:
[itex]t = \frac{d}{v} = 1.496 x 10^8 sec = 4.74 years[/itex]
Is this the time from the Earth reference frame?
Then the time on the spaceship is:
[itex]t' = t \sqrt{ 1 - \frac{v^2}{c^2}} = 1.86 years[/itex]
This is less than the time it takes light to reach Earth. Using length contraction on the spaceship, then determining the time to travel the shorter distance results in this same time.
OR, the time of 4.74 years is the time onboard the spaceship and the time on Earth is 12.09 years.
I'm confused!
Hi, change the backslash in the \tex to a forward slash and it will display properly.
Thanks! I figured that out.
welcome to pf!
hi sparks97! welcome to pf! :smile:
yes :smile:
the spaceship regards both alpha centauri and Earth as moving, so the length is contracted
since the spaceship clock reading is also lower, by the same amount, that means the spaceship measures the speed of the Earth as the same, v :wink:
or just type two #s before and after: ##\sqrt{ 1 - \frac{v^2}{c^2}}##
There's an ongoing thread with almost the same scenario. The astronaut is coming back from a star almost 4 light-years away, taking 2 years of his time to be here. But the principles are the same and might help you understand.
I posted a Thanks to Tiny Tim. I'm not sure where it went.
Thanks for posting this link to the other thread. Great forum here!
it goes into the recipient's "MY PF" :wink:
