Time to travel through Earth between surface points
Pushoam
Handwritten red R at left and a circle diagram with a straight tunnel chord between two surface points, radius R marked from centre; multiple-choice options (a) 21.1 min, (b) 84.4 min, (c) 42.2 min, (d) 63.3 sec.
[/B]
The thing to remember is that inside the Earth surface, the gravitational field does not remain inversely proportional to ##r^2##.
The equation of motion is
## \ddot r = \frac { -gr} R## ....(1)
This means that the particle will oscillate between the two points on the surface with angular frquency ## \omega = \sqrt{ \frac { g} R}##. ...(2)
## T= \frac { 2\pi } {\omega }##...(3)
The required time is ## \frac { T} 2 = 42.3 ~ min##...(4)
Hence, the correct option is (c).
The time taken for going from one point to another point of the Earth surface is independent of the distance between the two points.
Then, when I go into an underground room, I need to move for going from one point to another. Is it because of friction force?
  • Handwritten red R at left and a circle diagram with a straight tunnel chord between two surface points, radius R marked from centre; multiple-choice options (a) 21.1 min, (b) 84.4 min, (c) 42.2 min, (d) 63.3 sec.
Pushoam said:
[/B]
This means that the particle will oscillate between the two points on the surface with angular frquency ## \omega = \sqrt{ \frac { g} R##.
If the tunnel was thru the centre, then that formula comes out immediately. How do you justify the SHM for a tunnel near the surface?
Otherwise, what's your question?
I don't know about which formula are you talking?
In writing the following equation,
## \ddot r = \frac { -gr} R ##....(1)
I din't assume that the tunnel is passing through the center.
Even for the tunnel not passing through the center, I think the eqn (1) is valid. Is this wrong?
In writing the following equation,I din't assume that the tunnel is passing through the center.
What does ##r## represent? For SHM it should be the displacement along the tunnel.
Only when the tunnel is thru the centre does this displacement coincide with the displacement from the centre.
PeroK said:
What does rrr represent? For SHM it should be the displacement along the tunnel.
I took it as the displacement from the center.
I am not getting why it should be so.
It seems as if I assumed that the tunnel is passing through the center unknowingly while writing equation (1).
When the object is at the midpoint of the tunnel, according to SHM, the force and acceleration should be zero.
But, at the midpoint of the tunnel ##r \ne 0##, so the formula cannot be correct in the form you have.
Also, for SHM, the displacement at the midpoint should be 0. In your equation ##r## is always positive, so additionally the force would not change sign.
But, at the midpoint of the tunnel r≠0r≠0r \ne 0, so the formula cannot be correct in the form you have.
Also, for SHM, the displacement at the midpoint should be 0. In your equation rrr is always positive, so additionally the force would not change sign.
I will reply to you after digesting it. Thanks for it.
