Today Special Relativity dies
529 replies · 43K views
Train2
just look at the gif
ram1024 said:
Train2
you look at the modified gif
http://www.imagedump.com/index.cgi?pick=get&tp=87816
the green dots you added are the point of events which are stationary.
This gif is not the same as Einstein's gedanken.
http://www.bartleby.com/173/9.html
In this gif, the observer detects the photons at the same time, but doesn't conclude the events were simultaneous in his frame, because he is not at the midpoint (of the green dots). In Einstein's gedanken, observer starts at the midpoint (and remains there in his frame), doesn't detect photons at the same time, therefore concludes events were not simultaneous.
The two train gifs just demonstrate how things look different in different frames.
no, read your Einstein Gedanken again.
he was at the center of point of emissions WHEN the lights flashed <and the embankment is used as the "stationary" point of simultaneity. BUT the train is moving with velocity V -> and "Now in reality (considered with reference to the railway embankment) he is hastening towards the beam of light coming from B, whilst he is riding on ahead of the beam of light coming from A. Hence the observer will see the beam of light emitted from B earlier than he will see that emitted from A"
that is standard movement, I'm guessing Newtonian.
The gif does NOT describe Einstein's Gedanken, as you said. but the Gif does display a pretty convincing argument as to why simultaneity is not at fault, just faulty calculations
ram1024 said:
no,
No to what? Quote please.
No
just kidding :D
it was in reference to that. in the Einstein Gedanken the observer moves towards an emitter <lightning> and away from another, starting at the midpoint.
the "remains there in his frame" is wrong. As per Case #7.
i can elaborate with gifs if need be...
Let me clarify.
The "moving" observer in Einstein Gedanken is M'. When the lightenings strike, M' is at the midpoint according to the embankement. M' then moves to the right, according to the embankement.
Now, according to M', the lightenings don't strike simultaneously. So, when looking from M' frame, we can't actually say "M' was at the midpoint when the lightenings stroke", because that's not a single instant. But we can say "M' was at the midpoint of the locations where the lightenings stroke". Those locations are where the burning marks are made on the train (not the embankement, we are in the train frame now). Then, M' does not move anywhere (in his own frame, according to himself), thus remains at the midpoint of the events the whole time.
About your case #7 (post#249, took some time to find), all observers remain at the same distance from the location of any emitted photons (in accordance to what I wrote above). In other words, the location any event never changes *within a frame*. The event has happened at an instant and its location cannot be carried with the source of the event or whatever.
if he was at the midpoint of the "events" and light speed is constant relative to him, it stands to reason that HE views the light as striking simultaneously as well, does it not? he would not lose simultaneity in this case...
but the law cannot be frame inviolate as i have outlined, the times for light to reach an observer from "an event" is different if the observer is moving than if the emitter is moving. the emitter does not impart relative change in motion of an "event" but the observer DOES.
in other words, the light is NOT tied to it's SOURCE in an event, it IS however tied to an Observer.
Make it so Observers are both Observers AND Emitters. Make one of them move and the other one stationary. ping the emitters simultaneously in a "midpoint" frame. One of them <the moving one> will be hit with the opposing emitter's photon first <by virtue of closing a distance towards the emitter>
now switch "frames" make the moving one stationary. all of a sudden the OTHER emitter (now the moving one) gets hit by the opposing photon first.
Holy Rusted Metal, Batman
Paradox
still working on the gif for this one... but i figured the explanation should be good enough to get the point across for the time being
stupid animated gif programs not being free :O
Yes "he was at the midpoint of the events" and yes, "light speed is constant relative to him". Therefore, yes, IF he saw lights striking simultaneously, he would rightfully conclude the events occurred simultaneously. But he does NOT see them simultaneously, therefore concludes they were not simultaneous events in his own frame. You may think "why not change the observation rather than the conclusion. How are we sure he does not see them at the same time?". Because that's what the stationary frame sees: that the moving observer meets the lights at different points so he can't have possibly seen them at the same time. I could think of a paradox if this was not the case.
I have stated my objection to that above so let's not continue until that's clear.
:confused: Einstein's Gedanken right? observer moving FROM the center of the light points AT THE INSTANT that lights are fired simultaneously in the stationary frame. Make that observer stationary. Lights are STILL fired in the first instant of the experiment when the distance between observers and is equal on both sides, light does not move with sources (in this case lightning doesn't leave a "source" to move with anyways). observer does not move either. midpoint DOES move.
conclusion? observer receives light simultaneously.
and my continuation should prove beyond a doubt that my reasoning in case #7 holds true. Postulate: "Motion of light is independent of the motion of the source, but independent on the motion of the observer"
Paradox
Oh, I get what you mean now. No, that's not right. They actually do go the same distance... here allow me to explain:
Observer 1 is stationary relative to the emitter, observer 2 is moving towards it.
The Emitter releases a photon at 0.
Observer 1 receives this photon at t (in M), after Observer 2. Observer 2 receives it at t' (in M'), before Observer 1.
Now, what distances have these photons travelled? Well, they've traveled the same distance in each frame (t in M and t' in M') because you don't measure the distance between the emitter and the observer when he receives the light, because the speed of the emitter doesn't affect the photon's speed!
This means you need to use the emitter's original location >IN THAT FRAME<.
In M' (the moving frame) the emitter's original location is behind the emitter's location in M. So the distances are equal.
i have no idea what you mean by that. But i just woke up so I'm slow starting :D
according to SR, both frames are equally valid. we KNOW from experimentation <i'm going to assume SOMEONE did Einstein's Gedanken before> that an observer moving towards a light receives photons before a person stationary at the same start location.
but it doesn't work in this case. if you switch frames so that the moving observer is "the stationary one" then the stationary observer in reality (now the moving one) gets hit by photon first. How can you determine who gets hit first in this case?
No if you switch frames ram the observer who was stationary in the frame in your first paragraphy is now moving away from the light source in the frame in your second parargraph, consequently in this frame also it is this obsrever who receives the light last.
nah we've moved on to Case #8 now, jcsd
lemme diagram it for you
Case #8
Code:
     [u](o)                    |                    (o)[/u]
     [u](o)                    |                  (o)[/u]
     [u](o)                    |                (o)[/u]
     [u](o)                    |              (o)[/u]
The observers in this case are both Observers AND Emitters. at the onset of the experiment, ObserverA and ObserverB shine a light towards each other. Simultaneity is verified by an observer at the midpoint of the starting locations of both observers. ObserverB then moves towards ObserverA. Predict who receives a photon first.
Code:
     [u](o)                    |                    (o)[/u]
       [u](o)                    |                  (o)[/u]
         [u](o)                    |                (o)[/u]
           [u](o)                    |              (o)[/u]
now all we've done is taken that same experiment from ObserverB's point of view AS IF he was the stationary one. in this case the reverse result is shown, ObserverA receives his photon first. It is also interesting to note that the midpoint observer no longer receives photons simultaneously in this view, further proving that frame shifting is wrong for this type of experiment. How can something absolute such as simultaneity AT A POINT be violated by merely changing how you view a situation?
Case #8
Code:
     [u](o)                    |                    (o)[/u]
     [u](o)                    |                  (o)[/u]
     [u](o)                    |                (o)[/u]
     [u](o)                    |              (o)[/u]
Code:
     [u](o)                    |                    (o)[/u]
       [u](o)                    |                  (o)[/u]
         [u](o)                    |                (o)[/u]
           [u](o)                    |              (o)[/u]
They don't agree on the order because the two events are separated by distance. :rolleyes:
I told you you weren't reading my posts.
Einstein's gedanken corresponds to your case#3. The moving observer does not see the lightenings at the same time (since they occurred simultaneously in the stationary frame, they can't have occurred simultaneously in the train frame). I am 100% sure this is SR's prediction. Plus, if he saw them at the same time, there would be a paradox, because the non-moving midpoint observer sees them at the same time at another point in space.
But if you make the moving observer stationary, of course he sees the lightenings at the same time, because he would be in the stationary frame now. That would correspond to case#1.
I don't understand why you say "midpoint DOES move". The midpoint of events never move within any frame, because the location of events never move within a frame. Location of an event in a frame may look like moving from another frame (like burning marks on the train as seen from the embankement), but they would move at the same speed as the train.
For the hundreth time, there is no motion of the observer in the observer's frame, observer is at rest wrt itself. Of course separation speed changes when looked from another frame, but that's irrelevant. What changes in a frame is the simultaneity of events, not how light moves. That's the whole point you are missing.
Janus said:
Yes it does matter, if he is at the midpoint he will detect both simultaneously, if he's not he won't.
Example: the two following gifs show what happens according to the frame the emitters are in and the frame the man is in for the same situation. (the actual animation deals with a railway car moving along a track, but we will just assume that the track represents the platform. In this situation we have to men, one that stays stationary to the platform and one that moves with it.
We further stipulate that the moving man is next to the stationary man when the light is first detected by either.
The first animation shows things from the perspective of the emitters and the stationary man:
http://home.teleport.com/~parvey/train1.gif
The photons expand at c in two spherical fronts that reach the mid point at the same time by the observation of both men (both men see the photons arrive at the same time.)
The second animation shows what happens according to the man movig relative to the platform/track.
Since the speed of light is invarient for all observers, he also must see photons exapand outward from the point of emmission as a sphere in his frame. But from his perspective, the emitters do not stay at the the point of emmission. Therefore, in order for him to detect the emissions from both emitters at the same time, and at the same time as the man stationary to the platform, in his frame, the emiiters do not emit simultaneously, but one emits after the other.
http://home.teleport.com/~parvey/train2.gif
The reason things have to be this way is that the two men, being at the same point at the same time according to both of them, and both seeing the flash from the emitters arrive simultaneously is a spacetime event that is invarient and must be agreed upon by everyone.
I guess you dropped the football a lot in high school huh? . When a quarterback throws a ball to a "stationary" receiver and the football is intercepted by a running safety as they collide, you must think the ball was thrown at a different time for the receiver than the safety, that's why one guy misses it right?
read the case. simultaneity is verified by a midpoint observer. in one "view" the midpoint observer DOES see the events simultaneously. in the other "view" he doesn't. but it's the SAME CASE. we're not doing the experiment twice.
simultaneity at a point is INVIOLATE.
you're obviously not reading MY posts. I'll let you ruminate on that subject for a while.
you seem to be dodging case #8, wespe. please give it a try
Oh, sorry, I forgot to tell you AGAIN that the photons aren't emitted simultaneously in the moving frame, making the middle observer receive them at the same time. :smile:
And this is because the two events (the emitions) are separated BY DISTANCE.
You have dodged cases #1 to #7 and some 400 replies. Please go back and read all the thread again.
OK, case #8, involves acceleration. ObserverB first shines light and then starts moving, therefore switching to a different frame. So he can't declare himself stationary all the time (or a pseudo gravity field must be added). Similarly to the Twins Paradox, see:
http://math.ucr.edu/home/baez/physics/Relativity/SR/TwinParadox/twin_paradox.html
So, explaining case #8 as is requires invoking General relativity, which I can't. To avoid this, assume ObserverB never moves but an inertial ObserverC was passing near ObserverB as the light was shined. Then, midpoint always receives the lights at the same time. Only for ObserverC they were not emitted simultaneously, just as with the previous cases.
i'm the one making the cases, i don't have to answer them. I'm finding out what SR thinks of the situations. i already KNOW what I think of the situations...
fine make ObserverB an inertial viewer. don't need to add more observers into the mess.
ObserverB moving towards ObserverA shines a light in such a fashion that the light he shines and the light ObserverA shines hits the midpoint viewer simultaneously.
switch view frames so ObserverB is NOT a moving observer.
Midpoint Observer and ObserverA have to move in this frame. Midpoint viewer AND ObserverA both do not receive photons in the correct time frame in this "view"
please resolve this paradox.
what was once simultaneous interception for the midpoint viewer is no longer such. just by changing "views"
the obvious conclusion is changing views does NOT work when dealing with light BECAUSE light is observer motion dependent
QED
In Janus's animated presentation, she argues (and you agreed) that the moving observer observes the lightning flashes simultaneously (at M')because they were not emitted simultaneously in the moving frame. If I read you correctly, you are saying here that the moving observer does not receive the lightning flashes simultaneously (at M') because they were not emitted simultaneously in the moving frame. Sounds like a contradiction here- care to explain?
In particular, I'd like to address your statement here : "The moving observer does not see the lightenings at the same time (since they occurred simultaneously in the stationary frame, they can't have occurred simultaneously in the train frame)." : Only if you are silly enough to use the front and rear of the train as the distance the two photons from events A and B traveled to the moving observer in lieu of the actual places where the events occurred as marked by the burned wood on the tracks to deduce the time of events. And only if you are naive enough to think the sequence of actual events happening is equivalent to the sequence of detection of light signals from those events.
Eyesaw: they define simultaneity at a distance different from normal people. For them something at a distance only happens "at the same time" if it can be witnessed by an observer in the center of "the events" "at the same time"
thus the source of 30 pages of confusion :D
finally have the whole thing nailed down as a simple postulate error involving frame changes. pretty sure all "relative light speed to the observer" calculations were done as observer stationary frame, which is wrong.
I think you are right.
well thank you, it's nice to have a favorable vote once in a while :D
Well you aren't just asking questions. You are presenting arguments and drawing conclusions. When you are answered with a counter argument and you don't have anything left to say, you simply change the case while you should be accepting that your initial argument was incorrect. Therefore you aren't learning anything. That's what I meant by dodging. Please do read http://www.ephilosopher.com/Sections-article36-page1.html
It's fine up to this point.
You draw this conclusion without showing me the reasoning. It is a wrong conclusion. The setup is that midpoint receives both photons at the same time. Switching the view won't change this fact. Why did you think so? Please explain.
No paradox. From observerB's perspective, ObserverA doesn't shine light simultaneously with ObserverB. ObserverB shines light at a certain time such that the midpoint receives the photons at the same time. I could show you how this is so (requires adding another observer in ObserverB frame), but first tell me what made you think:
My guess is that you didn't think; you just used your intuition.
Well, there were different cases discussed in this thread. One of them is an animated gif which shows the moving observer seeing the flashes at the same time. In that gif, the observer is not at the midpoint. The one you quoted is different; the observer is at the midpoint and does not see the flashes at the same time.
So your suggestion is :the train observer must prefer the burned wood on the tracks over the burn marks on the train, as the location of events. Why? What is special about the tracks?
Speed of light is constant relative to all observers (do you disagree at this point?). Then, if light from both events travel the same distance (that is, the observer is at the midpoint), the order of detection of light signals can be used to conclude about the sequence of events. Why do you think not?
Fine, you want my observations this time, you can have them
1. before the frame shift, ObserverA is stationary and the Midpoint Observer is stationary. ObserverB is moving towards ObserverA <and the Midpoint Observer>
2. In this "Frame" Lights are emitted and progress is made by ObserverB Towards the opposing source of light. no progress is made by ObserverA towards HIS opposing light source. Light for ObserverB will be intercepted before ObserverA. the midpoint observer being stationary and at the midpoint of the emission sources will receive the emissions simultaneously.
3. Frames are switched. ObserverB is now stationary. ObserverA and Midpoint Observer move to preserve "reality" and "relative movements". in this frame, ObserverB makes no motion towards the light sources. ObserverA and Midpoint Observer DO make progress. The Midpoint Observer now progressing in a direction towards a light source will no longer receive photons simultaneously in this case, as he is no longer stationary at the midpoint of the two light sources at the time of emission and reception.
please do show me how the midpoint observer can still receive photons simultaneously in this case. i can almost guarantee you'll come to the same conclusion / revelation that I've been holding out of your reach for 30 pages.
oh and remember to preserve the speed of light relative to the midpoint observer ;D
3. Frames are switched. ObserverB is now stationary. ObserverA and Midpoint Observer move to preserve "reality" and "relative movements". in this frame, ObserverB makes no motion towards the light sources. ObserverA and Midpoint Observer DO make progress.The Midpoint Observer now progressing in a direction towards a light source
this is your wrong conclusion. your reasoning is:
true, no longer at the midpoint, but you also assume that in ObserverB frame, ObserverA emitted light simultaneously with ObserverB. Not true. According to ObserverB, ObserverA emitted light before ObserverB, such that the moved mid-observer received the lights at the same time.
I explained above how midpoint observer still receives photons simultaneously in ObserverB frame. Now I am expecting you to present your counter-argument. No more cases, enough is enough.
From ObserverB's perspective, the SEPARATION speed between two light signals and mid-observer are of course different than c. But from mid-observer's perspective, relative speed of light signals are still c.
