Discrete Subrings of Complex Numbers: Topology of Rings
  • Context: Undergrad
  • Thread starter Thread starter Paul Colby
    Rings Topology
The discussion focuses on the properties of discrete subrings of complex numbers, particularly those containing 1, and their relationship to the real numbers. It establishes that a subring, such as ##R = \langle 1, \sqrt{2} \rangle##, is dense in the reals if it contains an element with absolute value less than 1. The participants confirm that all discrete subrings of the reals are contained within the integers, and they explore the implications of this finding, including the construction of sequences that accumulate at zero. The conversation also addresses potential counterexamples and clarifies the distinction between submodules and subrings.
  • Understanding of discrete subrings and their properties
  • Familiarity with the concepts of density in topology
  • Knowledge of sequences and limits in real analysis
  • Basic algebraic structures, specifically rings and their operations
  • Study the properties of discrete subrings in algebraic structures
  • Explore the concept of density in metric spaces
  • Learn about the construction of sequences and their convergence
  • Investigate the differences between submodules and subrings in algebra
Mathematicians, algebraists, and students studying ring theory, particularly those interested in the topology of rings and their applications in real analysis.
Paul Colby
Insights Author
Hi,
I've[1] recently become interested in discrete subrings containing 1 of the complex numbers. Being complex numbers these rings have all sorts of properties but my question may be formed in terms of the reals. The question is; when does a subring, say of the reals, ##\mathbb{R}##, becomes dense in the reals? I think the answer is when it contains an element, ##|x|<1##. Let's look at the ring generated by 1 and ##\sqrt{2}##, ##R=\langle 1,\sqrt{2}\rangle##. Any member of this ring, ##r\in R##, may be written,
##r = n+m\sqrt{2}##​
where ##n,m\in \mathbb{Z}##. Okay, consider ##x = \sqrt{2}-1##. We have that ##|x| < 1## so the sequence, ##x_n = x^n## where ##n\in\mathbb{N}## accumulates at ##x=0##. Since the ring is closed under addition, every element of the ring is an accumulation point. The next step is showing that any real ##y## is also an accumulation point of some sequence in the ring. My thought was given ##y\notin R## there is always an ##r\in R## such that ##|y-r| < 1##. Given this ##r## we may always find a small ##x\in R## about 0 we can add so that, ##|y - r - x| < |y - r|##. So there is no smallest ##x## we can always find more ring elements near ##y##.
[1] My training is in physics.
Yes that works. In fact we don't even need the axiom of choice, since the ring is countable. Assume an index mapping of the positive integers to the ring. We then use the fact that the ring accumulates at 0.
Given ##y\notin R##, define a sequence ##s_n## with ##s_0=0## and ##s_{n+1}## calculated as follows.
We assume wlog that ##y>0##, since if the ring accumulates at ##y## it must also accumulate at ##-y## by just taking the negative of any sequence that accumulates at ##y##.
Assume ##s_n\in R \wedge s_n\ge 0##.
Let ##x## be the least-indexed, positive ring element that is less than ##y-s_n##. Then define:
$$s_{n+1} = s_n + \left\lfloor \frac{y-s_n}{x} \right\rfloor x$$
which we see must be in ##R## being an integer combination of ring elements.
Consideration of cases based on whether ##x## is greater or less than ##\tfrac12 (y-s_n)## (it cannot equal it, else ##y## would be in ##R##) shows us that ##s_{n+1}\ge s_n + \tfrac12(y - s_n)## so that the distance remaining from ##y## at least halves at every step of the sequence.
Hence for any ##\epsilon>0## we can find ##M## such that ##n\ge M\Rightarrow |y-s_n|<\epsilon##.
The rational numbers are dense i ℝ.
Thanks. I've known for years that the rationals are dense in ##\mathbb{R}## but never expected ##n+m\sqrt{2}## to be so. I know this must be very well known but it was kind of startling. Made me doubt the proof I was constructing. So, if ##R\subset \mathbb{R}## is a ring and ##\mathbb{Z}\subset R## is a proper subset, then ##R## is dense in ##\mathbb{R}##. This is actually quite useful in attacking the discrete subrings of ##\mathbb{C}##. Really limits what one may do.
Actually, after some reflection a much stronger statement is true. All discrete sub rings, ##R\subset\mathbb{R}##, of the reals are contained in the integers, ##R\subset\mathbb{Z}##.
proof: Let ##R\subset\mathbb{R}## which we assume discrete. If ##R-\mathbb{Z}## is empty, we’re done. So assume we’re not done and pick ##a## from this set. We may construct sequences in ##R## of the form $$r_n(a,m)=a(a-m)^n$$ where, ##n\in\mathbb{N}## and ##m\in\mathbb{Z}##. Clearly, ##a-m## need not be in ##R##, however, expanding ##(a-m)^n## yields only a single integer term, ##m^n##, which may lie outside of ##R##. The overall factor of ##a## assures, ##r_n(a,m)\in R##.
Okay, we may choose ##m## such that ##0 < \epsilon= a-m <1##. The sequence $$|r_n(a-m)| = |a||\epsilon|^n$$ accumulates at zero for large ##n## which contradicts ##R## being discrete. Therefore, all discrete sub rings of the reals are contained in the integers.
I don't understand the proof. Since the ring contains the integers, ##a-m\in R##. Also there is no reason for ##R## to be an ideal of the reals, so the a factor is not sufficient (nor necessary, since ##R## contains 1, and hence all integers)
And if you did not intend to restrict to rings with 1, I think the set of even numbers is a counterexample.
The even numbers[1] are discrete and therefore contained in the integers which is the conclusion obtained in #5.
I think you’re confused by the posts prior to #5 which did assume ##1\in R## and hence contain the integers. The proof in #5 does not make this assumption. As, I said in #5, it’s a much stronger statement.
[1] I assume by number you mean integers.
Sorry I misread your post as claiming the ring must equal the integers.
I reread your proof and it makes more sense to me now - ##a(a-m)^n## is a sum of terms of the form ##a^k n## for some integer ##n## and ##k>0##, so all must lie in ##R##.
Cool proof!
nice observation. I initially thought this was wrong, but you are absolutely correct. I was confused as to the difference between a submodule and a subring of the reals. Does this work?: If S is discrete and has a non zero element, then it has a least positive element a. Then S consists precisely of the reals of form am where m is an integer. But then a^2 = ak for some integer k, whence a=k.
I think this may hinge on ##S## being a Euclidian ring[1]. For ##S## to be Euclidian one needs ##d(a)=|a|## to be an integer which is quite an assumption.
[1] "Topics in Algebra" Herstein 1964 - pages 104-105
I think it works without any assumption. In fact it is essentially your argument in line -4 of post #5, i.e. if there is any element of S that is not of form ma, then some element x of S lies between say ma and (m+1)a. But ma < x < (m+1)a implies that 0 < x-ma < a, a contradiction to a being the smallest positive element of S. is this ok?
  • · Replies 20 ·
