Toss coin probabilities (Bino vs Gauss approx)
  • Context: Graduate
  • Thread starter Thread starter ChrisVer
    Gauss Probabilities
3 replies · 1K views
Hi, I calculated the probability to this scenario:
getting between 3 and 6 Heads after tossing a coin for n=10 trials...
The binomial probability for this is:
[itex]P(3 \le k \le 6) = \sum_{k=3}^6 Bi(k;p,n)= \sum_{k=3}^6 \frac{n!}{k!(n-k)!} p^k (1-p)^{n-k} =\sum_{k=3}^6 \frac{10!}{k!(10-k)!} (0.5)^{10} = 0.7734375[/itex]
Whereas for the Gaussian approximation to the binomial:
[itex]G(x) = \frac{1}{\sqrt{2 \pi n p (1-p) }} \exp\Big( - \frac{ (x-np)^2}{2np(1-p)} \Big)[/itex]
I get:
[itex]P(3 \le x \le 6) = \int_3^6 dx~ G(x) = ... = 0.633505[/itex]
My question is why are the two probabilities so off from each other? Is it because [itex]n[/itex] cannot be considered as "large" ? I think when extracting the Gauss approximation, the additional higher orders go as [itex]\frac{1}{n}= 0.1[/itex] but that's for the gaussian distribution ##G## and not the integral of it.
Any feedback?
Simon Bridge said:
n=10 p=0.5 gives [np, n(1-p)] = [5,5] and you really want them both bigger than 5.
So the difference is mainly due to the fact that [itex]np= n(1-p)=5[/itex] is not large enoguh? So Gauss can go a bit off in its predictions (here ~10%)...
The strange thing is that this is the only rule the approximation break, whereas the other two rules give:
[itex]\Big| \frac{1}{\sqrt{n}} \Big( \sqrt{\frac{q}{p}} -\sqrt{\frac{p}{q}} \Big) \Big| = 0 <0.3[/itex]
and
[itex]np \pm 3 \sqrt{npq} \in [0.26 , 9.74 ][/itex] which is in [0,n=10]...
Simon Bridge said:
There are online calculators that will help you check your answers.
i.e. http://stattrek.com/online-calculator/normal.aspx
For the calculations I try to build my own source codes just for a practice :smile: (or check with the formulas in wolframalpha), and so far my numerical methods work fine.
