Transcription AQA Question (incorrect MS?)
  • Thread starter Thread starter jsmith613
    Aqa
5 replies · 3K views
jsmith613
http://www.xtremepapers.com/AQA/Human%20Biology/2004%20Jun/AQA-BYA2-W-QP-JUN04.pdf
Look at Q1bii)
"Give the DNA base sequence that codes for threonine"
So the DNA base sequence that CODES is on the sense strand
mRNA is complementary to the anti-sense strand and identical to the sense strand (except T is replaced by U)
So the codons on mRNA should be the same as the coding DNA strand
hence the answer SHOULD BE ACC
BUT the answer given is TGG
why?
thanks
Look at Q1bii)
why?
thanks
You're right, the codon for threonine is ACC. TGG codes for tryptophan. Best explanation is an error in the key. Good job!
but this was a real A-level paper
and there was no erratum notice
the MS said "TGG"
are you sure I am not missing anything?
the MS said "TGG"
Was the answer key you got "official" or did someone else independent of the testing agency provide it.
The only other possibility is they meant the antisense strand that's translated to the mRNA, not the codon. If that's what they meant, the question is written too ambiguously to answer correctly since they use the word "codes" and don't specify which DNA strand, nor give any indication they're talking about the strand being translated while leaving it to the student to understand the antisense is being translated into mRNA.
It was the official key.
http://en.wikipedia.org/wiki/Sense_(molecular_biology)#Antisense_DNA
Read this and it makes sense (although it was DEFINITLEY ambiguous. i think the point is that the DNA base sequence that codes for any amino acid would be the bases on the antisense strand as this is the strand that is used for protein synthesis (the sense strand plays NO ROLE in protein synthesis)
would you agree with this?
Yes, that is the only way to interpret it, but you shouldn't have to work backward from an answer to understand an exam question. The sense strand is the one usually referred to as the coding strand, so asking what DNA sequence "codes" for threonine was completely ambiguous if they wanted the antisense (noncoding) strand complementary to the RNA. I don't know if there is a mechanism to contest questions on that exam, but if there is, the exam writers should be made aware of the ambiguity in the question.
On the plus side, you've clearly demonstrated you understand the material enough to catch the ambiguity.
