Transmitting link for overspeed trip.
  • Thread starter Thread starter xandro101
    Link
The discussion focuses on mechanical mechanisms for transmitting force from a centrifugal sensing device to a stop valve for plant shutdown. A strong metal chain or wire connected to a mechanical governor is proposed as a reliable solution, similar to safety devices in jet engines. Alternatives include using a centrifugal sensing device to control a solenoid valve or a motor-controlled valve, with emphasis on the simplicity and reliability of mechanical solutions. The discussion highlights the importance of considering distance and mechanical complexity when implementing these systems.
  • Understanding of centrifugal sensing devices
  • Knowledge of mechanical governors
  • Familiarity with solenoid and motor-controlled valves
  • Basic principles of mechanical linkages and force transmission
  • Research mechanical governor designs and applications
  • Explore solenoid valve operation and control circuits
  • Investigate centrifugal switch mechanisms in induction motors
  • Study the design and implementation of mechanical linkages for force transmission
Mechanical engineers, plant operators, safety system designers, and anyone involved in the design of mechanical shutdown systems for industrial applications.
xandro101
I am a newly graduated mechanical engineer and I have difficulty conceptualizing what sort of strictly mechanical mechanism I could use to transmit the force available from a centrifugal sensing device at the main shaft of a prime mover all the way to a stop valve to shutdown the plant. I need a little assistance from experts in this forum.
Think of something that is so simple it can't possibly fail.
A nice strong metal chain or wire, with one end attached to a mechanical governor and the other end pulling a fuel shiutoff valve closed, would be one option. Some jet engines have exactly that as the "ultimate" safety device, in case the electronic systems that control normal engine operation fail.
If the stop valve is a solenoid valve, then having the centrifugal sensing device open a contact in the valve's solenoid circuit is the simple means, assuming the valve is a normally closed valve (energize to open).
If it is a motor controlled valve, tripping a contact would still work, except the resulting action would be to command the motor to close the valve.
If the stop valve is more than a short distance away from the cf device, a purely mechanical means would probably become a questionable solution.
Take apart a typical single-phase fractional-horsepower induction motor (e.g., 1840 RPM in the USA) and look at the centrifugal switch to disconnect the starting coil. This an electrical contact.
Now look at the starting circuit for a single phase repulsion-start induction motor, which mechanically disconnects the stationary brushes from the rotating radial commutator above a set RPM. The mechanism is a centrifugally-actuated hollow tube that slides axially on the motor axle. See picture thumbnail of radial commutator on a pre WW I induction motor.
motor.
[added] Manufactured by Century Electric about 1914. See also http://www.flickr.com/photos/47938537@N02/5118932181/
Bob S
  • Sticky
  • · Replies 48 ·
68K
9K
  • Sticky
503K
