Trebuchet energy conservation equation for angular velocity
  • Thread starter Thread starter timetraveller123
    Physics Trebuchet
26 replies · 5K views
timetraveller123
The trebuchet is a siege engine that was employed in the Middle Ages to smash castle walls or to lob projectiles over them. A simplified version of a trebuchet is shown in the following figure. A heavy weight of mass M falls under gravity, and thereby lifts a lighter weight of mass m. The motion of the mass M is blocked as shown in the figure, which launches the lighter mass m; the blockade forms an angle θ with the vertical. The mass of the blockade is much larger than all other masses. The shorter arm of the trebuchet is of length H , whereas the longer arm is of length l; the whole beam (both arms) are of mass µ.
conservation of energy
ok i did the solution but i got a super complicated expression for omega i will is it supposed to be that way? and is it possible to get a numerical value for omega from the given information? i have just described my solution in words if you want my actual equations i would gladly post thanks
x y a b are heights above ground
I moment of inertia
v translational velocity of masses
Ei = Ef
Mgx + μ(L+H)gy = Mga + μ(L+H)gb + 1/2 I ω2 + 1/2 Mv2 + 1/2 m v2
y = (L+H)/2 sin tan-1(H/L)
x = (L+H) sin tan-1(H/L)
a = H(1 - cosθ)
b = H + (L-H)/2 cosθ
I = 1/12 μ(L+H)3 + μ(L+H)(L-H)2/4
v of M : ω* H
v of m : ω * L
is this correct?
μ is given as mass of the beam, you shouldn't multiply it by (L+H) to get the mass.
The expressions can get a bit lengthy, yes.
I haven't worked out the problem (yet), but this item in your attempt attracted my attention. Expressions such as ##\sin \left [ \tan^{-1}(H/L) \right ]## are ugly and can be simplified. You are looking for ##\sin \theta## where ##\tan \theta = H/L = opp/adj.## Well,
$$\sin \theta = \frac{opp}{hyp}=\frac{H}{\sqrt{H^2+L^2}}.$$
Also,
$$\cos \theta = \frac{adj}{hyp}=\frac{L}{\sqrt{H^2+L^2}}.$$
On edit: Your expression for Ef does not include the potential energy of mass m.
On second edit: Angle ##\theta## mentioned in this post is not the same as angle ##\theta## given by the problem. It is the angle formed w.r.t. the horizontal by the arm in its initial position.
@mfb
oh yah got confused with mass and linear mass density sorry about that
@kuruman
oh you i forgot about potential energy of small mass
and simplification too
i don't understand what you mean by they are different θ they are the same in my working
because for a it is the height above the ground which H(1-cosθ) like a pendulum)
and for b it can be calculated similarly
and finally for small mass m the final height above ground is H + L cosθ
i don't get what you mean by they are different angles
I moment of inertia
The heights of what and when are x, y, a, b?
I is moment of inertia about what axis?
v is linear velocity, but it is different for m and M. Use different symbol for them.
@ehild
sorry for the ambiguity was in a rush that day let me explain myself
x is the initial height of mass M above the ground
y is the initial height of centre of mass of rod above the ground
a is the final height of mass M above the ground
b is the final height of centre of mass of rod above the ground
new variable i forgot to include
c is the final height of mass m above the ground
I is the moment of inertia about where the rod is pivotted i had used the parallel axis theorem
vm = ωL
vM = ωH
am i right now?
H/L=sin(φ), x=(L+H)sin(φ) and y=sin(φ)(L+H)/2. What are the initial and final potential energies?
Initial state:
Final state
initial potential energy :
μ sinφ (L+H)/2 g + M g (L+H) sinφ
final potential energy
μ (H + (L-H)/2 )cosθ g + M g ( H - H cosθ) + mg(H + Lcosθ)
final kinetic energy
I ω2 + 1/2 M (ω H)2 + 1/2 m (ωL)2
is this correct ?
edit :
what did you use to draw that thanks next time it would be helpful for me to post diagrams thanks.
vishnu 73 said:
is this correct ?
What is your zero of potential energy? If it is the ground, then the initial PE is correct. The final PE is not. You need to add distance a (see the diagram posted by @ehild) to all the final vertical distances.
vishnu 73 said:
edit :
It is "Paint" drawing program of Windows.
@kuruman
yes my zero potential energy is ground
but i don't see what height i need to add as far as i know i have accounted for all the heights
please point out to me
@ehild
thanks
vishnu 73 said:
@kuruman
See figure, and check your heights.
I did in post #9.
a = H - Hcosθ
M is a above ground
centre of rod is
H + (L-H)/2 above the ground
the small m is Lcosθ + H above the ground
i still don't see why you need to add another a to the heights
vishnu 73 said:
a = H - Hcosθ
M is a above ground
centre of rod is
a and c are correct, but b is not. The angle is missing.
oh you forgot the cosθ
but isn't this the heights i have i been saying since the start so is it correct? thanks!
just for clarification i drew this please don't mind my ugly drawing skills thanks!
is this corrects?
The drawing is all right. So what is b? Where is cos(theta)?
cos theta is the vertical height from edge of blockade to b
that is b is
H + (L-H)/2 cosθ
that is b is
H + (L-H)/2 cosθ
correct at last.
thanks i will do the problem now and post result for ω soon
this is the final expression i am getting for omega is it correct please don't mind because i am not good with latex don't how to type such a long expression in latex
The kinetic energy of the beam is 1/2 I ω2. It seems to me that you forgot the factor 1/2.
oh you other than is the rest correct i just multiply the numerator by 2
No, the kinetic energy of m and M were correct.
And express sinΦ with the given quantities H and L.
omg yes so careless i will just put 2 in the denominator of the first two terms in the denominator
and
sin φ as you said is H/L
Correct!
