Triangle problem - Evaluating the given expression
11 replies · 3K views
Saitama
In a triangle ABC, with usual notation, if ##a^2b^2c^2 (\sin 2A + \sin 2B + \sin 2C) = λ(∆)^x## where ∆ is the area of the triangle and x ##\in## Q, find (λx).
The usual notation is:
a,b,c are three sides of the triangle opposite to the angles A,B and C respectively.
I remember a formula relating ∆ and the three sides i.e
$$\Delta=\frac{abc}{4R} \Rightarrow abc=4R \Delta$$
Also, from the law of sines,
$$\frac{a}{\sin A}=\frac{b}{\sin B}=\frac{c}{\sin C}=2R$$
where R is the circumradius of triangle.
The given expression can be written as:
$$2a^2b^2c^2 (\sin A \cos A + \sin B \cos B + \sin C \cos C)$$
I can substitute abc and sines from the above two relations but what should I replace cosines with? Law of cosines doesn't seem to be of much help.
Any help is appreciated. Thanks!
Do you remember that sin(2θ)= 2 sinθ cosθ??
ehild
Hi ehild! :smile:
ehild
Yes, and I have even used it. I wrote ##\sin(2A)=2\sin A\cos A## and similarly the others to get the final expression I wrote.
Sorry, it was stupid of me. How can you get the area of the triangle, using R and the central angles?
ehild
ehild
Only this comes to my mind:
$$\Delta = 2R^2\sin A \sin B \sin C$$
How do I use this?
Do you remember that the area is 0.5absin(C)? See the coloured triangles in the picture. How do you get their area in terms of R and the central angles? How are the central angles related to the angles of the big triangle? ehild
ehild
Yes, I remember that. I misunderstood what you meant by the central angle, sorry. :redface:
The areas of three triangles formed are 0.5R2sin(2A), 0.5R2sin(2B) and 0.5R2sin(2C). Am I correct?
Yes, it is correct. So what is the area of the big triangle?
ehild
ehild
$$\Delta = \frac{1}{2}R^2\sin 2A +\frac{1}{2}R^2\sin(2B) +\frac{1}{2}R^2\sin(2C)$$
Also,
$$R=\frac{abc}{4\Delta}$$
$$\Rightarrow \Delta=\frac{1}{2}R^2(\sin 2A+\sin 2B+\sin 2C) \Rightarrow \Delta=\frac{1}{2}\frac{a^2b^2c^2}{16\Delta^2}(\sin 2A+\sin 2B+\sin 2C)$$
$$\Rightarrow a^2b^2c^2(\sin 2A+\sin 2B+\sin 2C)=32\Delta^3$$
Hence, ##\lambda=32## and ##x=3## and therefore ##\lambda x=96##.
Thanks a lot ehild! :smile:
How did you think of those triangles?
I just drew a picture with triangle and circumcircle. It is obvious, is it not, seeing the double angles in the equation. The central angle is twice the inscribed angle... ehild
It wasn't for me at least. :redface:
Thank you once again ehild! :smile:
I forgot to tell you that you gave the idea of using circumcircle... I have never seen the equation ##\Delta=\frac{abc}{4R}##. So thank you, Pranav:smile:
ehild
