ArjenB said:
Transform the following equation:
X2sin(3x)
1. Stretch vertically by a factor 9
2. Stretch horizontally by a factor 3
3. Shift to the left by a value of 1.2. The attempt at a solution
1. Stretching vertically by a factor 9 gives:
9x2sin(3x)
2. Stretching vertically by factor 3 is done by dividing 3x by 3, so I get
9x2sin(x)3. Shifting one to the left gives (I think I am going wrong here):
9(x+1)2sin(x+1)
Which can be simplified into:
(9x2+18x+9)sin(x+1)But this answer is wrong. Where did I go wrong?
You do not have an equation; an equation has an "=" sign in it, and your expression does not. What you have is a function of x.
I think the problem should be restated as follows. For the graph ##y = x^2 \sin 3x##:
1. Stretch the graph vertically by a factor of 9.
2. Stretch the graph horizontally by a factor of 3.
3. Shift the graph to the left by 1 unit.
Your solution of 1 is correct: the stretched graph is ##y = 9 x^2 \sin 3x.##
For 2: think about it: a point such as ##(k,y(k))## moves to ##(3k,y(k))## in the stretched graph, so if the old graph is ##y = f(x)## and the new graph is ##y = F(x)##, you can see how ##F(x)## must be related to the function ##f(x)##. You have it partly right, but not completely right.
For 3: a point ##(k,f(k)## in the old graph moves to ##(k-1, f(k)## in the new graph. From that, you can get the equation ##y = F(x)## of the new graph in terms of the old graph ##y = f(x).##
