Turning water into plasma and back in order to purify it
The discussion explores the concept of using plasma arcs to purify water by heating contaminated water to a plasma state, effectively breaking down all chemical bonds. It raises questions about the cooling process, specifically whether heavy atoms will solidify and if ionized hydrogen and oxygen will recombine into water or remain as gases. The benefits of this method include the complete destruction of contaminants and the potential production of a solid byproduct, termed Plasmarock, which can be utilized in construction. Additionally, the process could generate electricity through the combustion of hydrogen and oxygen or via steam turbines if water is recombined. Overall, the feasibility of this method is questioned, particularly regarding the control of atomic recombination after plasma cooling.
shanebird1001
This really isn't a HW problem, but this seemed like the best place to post my question.
Imagine a modern city's water cycle. Clean water is obtained from a river or from groundwater, and this water is used for drinking, bathing and industrial uses. Afterwards the water is fouled biologically and chemically. Next this very dirty water is sealed in a chamber, and a plasma arc (temp of 25,000° C) inside heats it until all of the water and contaminants turn into plasma (all chemical bonds broken).
Question: If the plasma is allowed to cool, will the heavy atoms form a solid at the bottom of the chamber?
Question: Will the ionized Hydrogen and Oxygen atoms immediately turn back into water when cooled, or will they be separate gases?
There are cheaper, easier and less energy-intensive ways to purify water than heating it to 25,000 C.
I didnt mean to imply that the water would be heated all the way to 25,000 C. The water would only have to be heated until it becomes plasma at 3,000 C or so.
While I am sure your right about cheaper ways to clean water, that's not the whole picture. Cleaning the water is only one benefit of this process. Another benefit is that the contaminants are destroyed. So for example, suppose that we were considering desalinization to produce clean water. The desalinization process concentrates the brine, and then dumps it back into the ocean. At such a concentrated level the contaminants are toxic to ocean life - even though they came out of the sea to begin with. So the area around the plant becomes a dead zone. Heating the dirty water into plasma eradicates all of the biological and chemical residues. Advanced Plasma Power is a company that uses a plasma arc to eradicate solid waste, their process results in a solid leftover that they term Plasmarock. This material can be used in construction. I don't know if a liquid waste process would also produce Plasmarock, that's my first question above.
Thats also not the end of the process. IF the cooling plasma results in disassociated hydrogen and oxygen gases, then they can be piped into another chamber and ignited. The explosion can be used to move a magnetic piston head, thereby producing electricity (and clean water, because burning the hydrogen and oxygen will cause them to recombine). IF the cooling plasma recombines the water and hydrogen, then the steam can be used to drive a steam turbine/steam generator, which will also produce electricity. So the overall process would look like this:
Inputs:
Dirty Water
Energy (Plasma Arc)
Outputs:
Pure Water
Plasmarock
Energy (Electricity)
Note that no wastes or contaminants are released, the Plasmarock can be sold, and the energy produced by the process will lower the overall cost. Finally, my process can use the same water indefinitely, so that the city would never run out of water.
I am interested in feedback, so please let me know if you think the whole process is feasible or not. Thanks.
There is no trivial way to separate the individual atomic species from the plasma in bulk. When the plasma cools you won't be able to control how the atomic soup recombines. Shades of the Miller-Urey experiments!
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
