Twin paradox: who decided who is the younger one
In summary: While orbiting the Earth at 0.99c, A is undergoing a very high radial acceleration towards the Earth.Fair enough. Thanks.
Passiday
Hello,
Still puzzled about the twin paradox (one guy stays on the ground, the other goes travelling). If we see the two twins as points in 3D space, the only thing that changes, is the distance between two. That is, the two guys are in totally symmetrical positions, and there should be no reason one is ageing slower than the other. If we take into account the Earth, the 1st twins distance from the Earth is fixed, and the others — varies. Is it the presence of Earth (ie, energy of the planet matter that bends the spacetime) that causes the difference in ageing for each twin?
This confuses me, because the special relativity doesn't speak about the way how matter bends the spacetime, and the twin paradox is typically used for explaining the special relativity.
Passiday
No, we ignore any real attributes of Earth when discussing the Special Relativity aspects of the Twin Paradox.
You are correct, if the twins remain symmetrical, then each thinks the other one is aging more slowly. But if one of them accelerates to join up with his twin, when they get back together, that is the one who will be younger.
One of the twins must change direction, and therefore go into a different inertial frame than the one he started from, this is the a-symmetrical part of the twin paradox. There is no twin paradox if the situation remained perfectly symmetrical (e.g. if both twins moved away from Earth, traveling at the same speed, turning back at the same time etc).
I'm not an expert on this but I think I have an issue w/ that ghwellsjr ... that is the statement "if one of them accelerates to join up ... "
Tell me if I have something wrong with this thought experiment. Twin A travels in a magical thought-experiment spaceship in orbit around the Earth and accelerates up to .99c and then decelerates down to non-relativistic speeds and lands. I think that is a situation in which twin A did NOT accelerate back to meet his brother but he's still younger when he gets there.
Is my analysis of this situation perhaps wrong because I am failing to take into account the fact that twin A spends half his time getting farther away from his brother and half getting closer?
But they would both be younger than those they left behind so if one of them had a son, there would be the "father/son paradox". :smile:
Let's do some math.
Assume we have two twins located at (t,x) = (0,0) in one specific coordinate system. They will meet again at a later time T but at the same location x=0, i.e. at (T,0). The question now is "what are T and T' prime in which coordinate system?".
Now let's avoid coordinates.
Assume one twin is traveling along a curve C from point A to point B in spacetime. The second twin is traveling along a different curve C' from point A to point B in spacetime. Of course we could introduce the coordinates for A and B, but that is not necessary.
Now you have to believe me that the proper time tau of a twin along his curve between A and B is given by the "length" of the curve through spacetime.
[tex]\tau = \int_C d\tau[/tex]
Here the "length" and therefore the proper time is calculated according to the strange 4-dim. relativistic Pythagoras t² - x².
As the two curves C and C' through spacetime are different for the two twins their proper times will differ.
[tex]\Delta\tau_{A\to B} = \int_{C_{A\to B}} d\tau - \int_{C^\prime_{A\to B}} d\tau[/tex]
Fair enought. Thanks.
tom.stoer said:
Let's do some math.
Assume we have two twins located at (t,x) = (0,0) on one specific coordinate system. They will meet again at a later time T but at the same location x, i.e. at (T,x). The question now is 'what is T and T' prime in which coordinate system?'.
Now you have to believe me that the proper time tau of a twin along his curve between A and B is given by the 'length' of the curve through spacetime.
Here the 'length' and therefore the proper time is calculated according to the strange 4-dim. relativistic Pythagoras t² - x².
I think yours is the clearest explanation. Here is a space-time diagram illustrating your point. The red guy in the diagram stays home and sees his twin return after 13 red years. But it's only ten years on the blue guy's calendar. The blue guy who made the trip took a short cut through space-time. Each observer moves along his X4 at the speed of light (and T = X4/c), but the blue guy in the diagram took the shorter path as you showed with your integral.
It's the "strange 4-dimensional relativistic Pythagoras..." -- that's the point. Excellent post. Thanks.
Thanks for the drawing - and one caveat: it's not possible to measure the length directly in such a coordinate system b/c one must not use cartesian coordinates in Minkowski space.
Yes. You are right about that. But look closely and you will see that I included that hyberbolic calibration curves so that we could make comparisons between the two coordinate systems. I used the 5 year calibration curves for each of the two inertial start events for the traveling twin.
bobc2 said:
You are right about that. But look closely and you will see that I included that hyberbolic calibration curves ...
Of course the caveat was not meant for you :-)
bobc2 said:
What do the diagonal red lines represent?
Thanks for the explanations, however, I am talking about a point of confusion before we get to the Minkowski space. Ok, one guy takes a shortcut in spacetime, thus ages a bit slower. But my question is, what is he doing to use that shortcut? At this moment, educated layman would shout to me, you stupid, he is achieving speed close to c, while the other guy is not. But, I am asking, against what entity his superior speed is measured? If we ignore the presence of the field of gravity of the Earth/Sun/Galaxy, then all we are left with, is two points on a line, whose distance changes in time. Is it the extraordinary acceleration experience that makes the guy age slower? Then that would be involving the general rather special relativity in the explanation (which is fine with me, but perhaps not fine for all those books explaining the special relativity using this paradox).
Special Relativity is all about choosing an arbitrary inertial (non-accelerating) Frame of Reference from which all speeds are referenced. Any object/observer moving in that frame will experience time dilation. The faster they go, the more time dilation or the slower their clocks run. Special Relativity has no problem with an object/observer accelerating but the FoR must remain inertial (non-accelerating).
You don't have to have any other material objects besides the two twins in your chosen Frame of Reference. If you pick your FoR so that one of the twins remains stationary in it throughout the entire scenario so that neither he nor the FoR are accelerated, then he will never experience time dilation. The other twin travels away and back and experiences time dilation for the entire trip. He has to accelerate in order to do this. It's not his acceleration that causes him to experience time dilation, it's his acceleration that causes him to travel at a high speed in the FoR and it's his high speed in the FoR that causes his time dilation. When he gets back to the first twin, he will have aged less than the one that never experienced acceleration or speed according to the FoR.
As I said in my first post, if both twins are moving with respect to each other, then you could choose a FoR in which either of them was at rest and the other one would be experiencing time dilation. In this case, the jury is out, the issue of which one is really aging less is meaningless. You could also pick a FoR in which they were both traveling at the same speed but in opposite directions and although they would both be experiencing time dilation, it would be the same for both of them so they would age at the same rate. But unless at least one of them accelerates so that he can rejoin his brother they won't be able to get back together and it is only when they are together that they can compare accumulated aging.
Now you might ask why you can't pick a FoR in which the traveling twin is at rest and the answer is that you could for one half of the trip but then on the way back, he will be traveling at an even higher speed and experiencing even more time dilation than his brother.
The salient point when dealing with issues like this is that unless you can get the same answer to a problem with any arbitrary FoR that you select, then the problem can't be solved. But if it is a solvable problem, and we know the Twin Paradox is, then you can pick the simplest FoR to analyze the problem and you'll get the correct answer.
My mathematical explanation does not use any reference frame, but only two curves C and C' through spacetime with different 'length'. Along C and C' speed and acceleration may differ which leads to different curves and therefore different proper time along these curves.
There is no shortcut, but simply two different curves. It's like going from A to B on a sheet of paper; you can do that along different curves with different length. In SR (or GR) you have to take into account that spacelike and timelike directions will differ and that you are therefore not able to 'measure' proper time on a sheet of paper using a ruler.
Regarding the 'entity' against which this difference of proper time is measured: there is no such entity, proper time along C is measured against proper time along C' - nothing else.
I think this is what I have problem with understanding. Since we don't take the presence of Earth into account, I imagine starting the thought experiment far away in space, where there's no any heavenly body to mess with the speeds and accelerations. Pretty much the environment with no matter other than the two twins and spacecraft with loads of fuel. If one guy gets into the rocket and travels, while the other stays hanging in void, the only thing that differentiates the traveling guy is that he's using reactive force to accelerate. He feels the acceleration and thus knows that he is changing the speed. If he has gyroscope on the board then he can even know when ship turns 180 degrees to travel back. I guess it's the mystery of why there should be any acceleration whatsoever in totally empty space what escapes my understanding.
1) You can tell when you're accelerating by the seat of your pants - literally. If you accelerate, you, or an accelerometer, can feel it or measure the forces. It doesn't matter if you are in empty space or not. This is in contrast to velocity, which you can't feel.
2) The first twin does not have to turn around for the two twins to meet. This was mentioned, though you got distracted by the other issue, I gather.
For the two twins to meet without twin #1 turning around and going back, all that has to happen is that twin #2 waits a bit, then accelerates even harder to catch up. In this scenario, it's twin #1 that ages the most.
According to SR, acceleration has "absolute" effects: it matters who accelerates. Even in deep space. One explanation is that "totally empty space" isn't truly totally empty. The first full presentation of the twin paradox scenario was even given in support of that view - see from p.47 of http://en.wikisource.org/wiki/The_Evolution_of_Space_and_Time
Passiday, as ghwellsjr pointed out, it is not the acceleration that causes time dilation ... the acceleration is a necessary side effect of the process because it's needed to get the moving twin up to a high speed.
Time dilation is ONLY due to high speed of one FoR relative to another (non-accelerating) FoR , and the two FoR have to meet up again in order for it to have any meaning (again, this is as ghwellsjr pointed out).
So consider this scenario: Twin B sits on the ground of a non-accelerating planet and according to his FoR, his Twin A goes accelerating off, travels at a very high speed for a while, decellerates, and at the end of the process ends up back at Twin A's side.
WHILE he was traveling at high speed, here's what happens:
http://www.phinds.com/time%20dilation/
It's just this simple.
Your explanation used the class of inertial reference frames, just as all the other explanations have done, and this is precisely what the OP is challenging. To define the 'lengths' of the curves you said "Here the "length" and therefore the proper time is calculated according to the strange 4-dim. relativistic Pythagoras t² - x²." The variables "t" and "x" in that expression are not arbitrary, they must be inertial coordinates, so you are referring to an inertial frame. Otherwise the expression doesn't give the proper time. Of course, as others have pointed out, it doesn't matter which system of inertial coordinates you use, but they must be inertial coordinates. Your explanation did not circumvent this requirement.
Basically the OP is asking about the origin of inertia. Ernst Mach (for example) argued that ultimately inertia must be defined by the relations of an object to every other object in the universe. It happens to be a fact that the inertial coordinate systems are those at rest or in uniform motion relative to the frame in which all the matter of the universe (that we can see) is isotropic, i.e., the same Doppler shift spectrum in all directions. Whether this is cause or effect is debatable. Einstein originally thought general relativity fulfilled Mach's prediction, but later he realized that it (probably) doesn't. The origin of inertia remains mysterious, even in general relativity and quantum field theory. (Note that the Higgs has not been found at the LHC.)
You should consider what is not symmetrical. When one of the twins returns there must be acceleration which breaks the symmetry. Also consider the proper time. The twin that is accelerated back should have a spatial displacement in all reference frames or you simply cannot find a inertial reference frame that sees the twin traveling at rest. Therefore, I think that dτ2=dt2-dx2 would make him younger.
I did point out what you said in the first paragraph but I did not say anything like what you are saying in the second paragraph. This is totally false.
Here is the truth: Time dilation is only due to the speed of each object/observer relative to an inertial (non-accelerating) Frame of Reference. There's only one FoR considered at a time. It has nothing to do with the relationship between two FoR's or two FoR's meeting up again, whatever that means. Every FoR extends out in all directions, here, there and everywhere, and includes all time, past, present and future, and every object/observer that you want to consider is in any FoR you want to consider. So every FoR already "meets" every other FoR at all locations and at all times.
But each object/observer can experience a different time dilation in each different FoR. You have to pick a FoR, do your analysis to get an answer and then pick another one and see if you get the same answer. If you do, then the answer is legitimate, if you don't, then the question is meaningless.
So if you have two twins traveling away from each other and you ask how each one ages in the rest frame of one of them, you will determine that only the other one is experiencing time dilation. If you then do the same thing for the rest frame of the other one, you will determine that only the first one is experiencing time dilation. If you then pick a FoR in which they are both traveling at the same speed in opposite directions, you will determine that they both age at the same time dilated rate but neither is getting older than the other. You get three different answers to the question of which one is really experiencing time dilation (or which one is younger) which means the question itself is meaningless. And you can get an infinite number of other answers by merely picking an infinite number of FoR's in which both twins are moving at different speeds.
But if the two twins get back together, then the question can be answered using any FoR. They all yield the same answer. But you should use just one FoR at a time. Work it out, see what the two clocks say after they come back together. Pick another FoR, work it out again, you get the same answer.
Interesting you should ask. The slanted lines are there to show the relative progress of each observer as they move along their respective 4th dimensions at the speed of light. When the traveling twin meets up with the black stay-at-home twin, the home twin is 13 years while the twin guy is 10 years. But wait--the home twin really couldn't be there could he -- if he has so far moved at the speed of light along his X4 to just his own proper time 10 yr point on X4?
If you think of observers moving at light speed along their 4th dimension, the home twin hasn't really arrived yet. But this is one reason why many physicists have concluded that objects in 4-dimensional space are 4-dimensional themselves. Thus the travel twin is meeting up with a different cross-section view of home twins 4-dimensional body. And the physical bodies really aren't doing any traveling anyway, because they are four-dimensional objects fixed --frozen in a 4-D universe.
It's ugly, I know. My subjective self does not want to accept that picture at all, but as I've said before, there is no alternative external objective picture out there that contradicts the 4-dimensional universe populated by 4-dimensional objects. I think many just abandon the idea of an external objective reality.
Here's another example. The hyperbolic calibration curves were computed in MatLab. Notice that when the home twin is 20 yrs old his view of the universe includes the travel twin with his (red's) clock showing 10 yrs. Red (travel twin) is about 17.5 light-years away from home (along the black X1 axis, going about 0.875c) at this point. That's the usual time dilation.
bobc2 said:
Interesting you should ask. The slanted lines are there to show the relative progress of each observer as they move along their respective 4th dimensions at the speed of light. When the traveling twin meets up with the black stay-at-home twin, the home twin is 13 years while the twin guy is 13 years. But wait--the home twin really couldn't be there could he -- if he has so far moved at the speed of light along his X4 to just his own proper time 10 yr point on X4?
Shouldn't one of these be 10 years? But I still can't make any sense out of what you are saying. Do you really think this kind of explanation helps someone learn Special Relativity?
You don't seem to be a very good promoter of the Block Universe idea when you make comments like this. Why do you continue to promote it?
Don't you mean length contraction?
And your example would fit better if you used a speed of 0.866c with a distance according to the traveling twin of 17.32 light-years away at his turn-around point. This would make the traveling twin 20 years old when he met up with his 40 year-old stay-at-home twin as you graphic depicts.
These discrepancies make it very difficult to follow what you are presenting.
But is this another example of a usual Twin Paradox explanation or of a Block Universe explanation?
If you want to put in diagonal lines to show how each twin watches the aging of the other twin, why don't you just do the normal pair of graphics like is shown half way down this page?
http://en.wikipedia.org/wiki/Twin_paradox
You are right of course. It was a typo. The travel twin is 10 yrs and the home twin is 13 yrs when they meet.
It is simply the special relativity picture of the twin paradox. Sorry I was unable to communicate it in a way that you could comprehend the 4-dimensional description of Minkowski space-time.
It's always difficult for someone new to the subject to learn special relativity. Others have been doing a pretty good job of presenting the transformations and the frame-of-reference concepts, so I didn't think I could add much there. However, sometimes it is useful to visualize the paradoxes in the context of the 4-dimensional Minkowski space.
I'm not trying to promote Block Universe. I'm trying to Minkowski 4-D space-time in the context of external physical reality. The idea of an external physical reality is distasteful to some on a philosophical basis. I mean no offense to those and am quite sympathetic to the view. I just happen to be in the realist camp, but at the same time am frustrated with the implications of the 4-dimensional space of special relativity.
The concept of a 4-dimensional universe is very much a part of the subject of special relativity and should not be hidden from newcomers to the subject. Nor should space-time diagrams.
Your tone seems a little confrontational, and I have no interest in participating in confrontational discussions and don't think it's good for the forum.
No. I was specifically referring to the time of 10yrs on the travel twin clock as seen in the the black's world at the black 20 yr point.
That's why I said "approcximately 17.5 yrs. But, you're right. Thanks for giving us the exact numbers.
I don't care what you wish to call it. It's just an attempt to present the Twin Paradox using a space-time diagram and noticing obvious implications.
You are missing the whole point of the diagonal lines. My lines definitely do not represent the instantaneous cross-section views of the 4-dimensional space as depicted in your link (I've done that in several other sketches). This was to emphasize the comparative progress through 4-dimensional space along their respective X4 coordinates. The twins each move at light speed.
The slanted lines call attention to the home twin arriving at his 10-yr point (proper time) in 4-dimensional space when the travel twin has arrived at his 10-yr point (lproper time) and it coincides with the home twin's future point of 13 years (they each travel a speed c along their respective X4 coordinate). This leads one to ponder how the stay home twin can be present to greet his travel twin if he has only moved to his own (black time coordinate) 10-yr point
I already comprehend the 4-dimensional description of Minkowski space-time. I didn't ask about that. I asked about the diagonal lines. I have never seen diagonal lines like that going at different angles on any Minkowski space-time diagram except yours. Can you point to an example of anyone else drawing them like that with an explanation of why they are slanted differently?
It would be useful if the visualization would explain why there is no paradox rather than just add to the confusion. Please look at your answer in post #24 and tell me why I should have understood your explanation or taken it any more seriously than you seem to have.
Then why did you label your axes X1 and X4 instead of x and ct like everyone else does? Can you show me an example of a Minkowski space-time diagram not promoting Block Universe Theory that is labeled like you did yours?
Yes, 3 dimensions of space and one dimension of time is what makes 4-dimensional space-time, not 4 dimensions of space.
I'm frustrated, just like you. When I'm trying to help someone understand what I'm saying, I welcome their confused questions and requests for clarification. I don't blame the questioner for being confrontational and threaten to end the conversation.
So please answer my questions above.
  • #31
Thanks for your reply, ghwellsjr. I guess I was getting the wrong impression for a minute there. I understand now that you were responding out of frustraion. I was thinking that maybe you were not so much interested in following the logic of a 4-D spatial universe as you were as painting me as some kind of crackpot. Actually, I've always respected your posts. You always seem to present accurate information and have been quite helpful to the newcomers.
I'll be glad to respond to each of your questions. Right now I'm still at the office with a little deadline. I'll get back on as soon as I can this evening.
  • #32
Yes, you are right, I am missing the whole point of your diagonal lines. And you are missing the whole point of the diagonal lines in the http://en.wikipedia.org/wiki/Twin_paradox" They do not have anything to do with anything instantaneous or a cross-section view of 4-dimensional space (which is three dimensions of space and one dimension of time). The diagonal lines depict on a normal graph with t on the vertical axis and x on the horizontal axis the progress of signals (or images) emitted at the same repetitive interval by each twin as those signals travel at the speed of light from each twin to the other twin and very clearly show how each twin sees the aging of the other twin so that at the moment they reunite, they both agree that the traveling twin has accumulated less time. These diagrams depict Relativistic Doppler very clearly and without confusion or lingering questions.
All I have gotten out of your diagonal lines is that when the twins reunite, one of them still hasn't arrived yet. Don't you see that as pure nonsense? If not, I welcome further clarification.
  • #33
We had a misunderstanding. I was referring to the following space-time diagram in the wiki link:This shows the planes of simultanaeity for the travel twin, which are exactly the diagonal lines I mentioned in earlier posts (yes, they represent 3-D cross-sections of a 4-dimensional space, x2 and x3 being supressed).
It's not at all nonsense in the context I was presenting it. But I'm trying to understand where we miss each other in following the logic of my comments about the slanted lines. My slanted lines were not meant to represent some standard space-time configuration. And, again, they were certainly not intended to be the planes of simultaneity shown in the sketch above (we had already discussed those more than once in this thread). Again, I just added them to the space-time diagram so you could follow the synchronous proper times of the twins. Maybe you are not accepting the concept of observers moving along their own world lines at the speed of light. What do you make of the often mentioned comment in special relativity discussions, "The observer moves along his own 4th dimension at the speed of light?" And what do you make of x4 = ct?
When taken at face value, the synchronous proper times indicated with my slanted lines lead to nonsense without the full 4-dimensional space and 4-dimensional objects. That was what I was trying to emphasize by pointing out the absurdity you have without the 4-dimensional objects available over all world lines so that twins can share the same event even though their lapsed proper times are not the same.
Perhaps you have a better explanation as to how the twins can share a common event when their lapsed proper times (from the time of their previous shared event, i.e., the common coordinates origin) are not the same.
  • #34
Then do you agree with the identification of the hyperbolic curves in my diagram as correctly representing a locus of points having the same lapsed proper times measured from the origin of both twins' coordinates? And do you agree that each observer moves along his world line at speed c? Do you agree that implies X4 = ct (distance traveled along the X4 axis)?
I have never seen a diagram that includes those slanted lines. Again, it was not meant to represent any standard convention. I don't claim them to be any sort of standard space-time diagram convention. However, I thought it would help in the understanding of the use of the hyperbolic calibration curves.
Do you agree that the slanted lines connect corresponding proper times from the home twin world line to the travel twin world line? I was simply attempting to call your attention to those synchronous proper times. Do you understand this now? I could explain further.
Again, the point of my calling attention to the synchronous proper times is to show that there is a paradox, which can be resolved if you apply the understanding of a 4-dimensional space with 4-dimensional objects. I can discuss that point more if it is not clear by now.
I'm never sure whether my presentation of a concept is good or adequate. Evidently it was not adequate in your case. If you could ask a more specific question, maybe I could do a better job of explaining.
It is not true that I'm the only physicist to label axes as x1, x2, x3, x4. Einstein has done that. I picked up the habit during a grad school special relativity course (my prof did it quite often-- sometimes ct and sometimes x4). Besides, the notation convention is a rather trivial issue. I like to emphasize the spatial character of the 4th dimension.
You could use a time convention with markers along the interstate from point A to point B if everyone drove at the same speed. Going 60 mph you could use one minute markers. It's not practical if everyone drives at different speeds. But, everyone drives at speed, c, along X4, and clocks are a very practical method of measurement. And you can always get the distance: X4 = ct. But, remember that a mechanical clock is just a 4-dimensional object with repetitive physical markers along X4. The 4-D clock and space are much more easily imagined than time as a physical dimension. And the idea of a "mixture of space and time" sounds appealing, but no one can really make sense out of such an idea (other than mathematically).
Why is that even relevant? If the problem as you see it is that a 4-dimensional external objective space is a concept out of mainline physics, then perhaps that should be the subject of another thread. We could start a thread, "Is the concept of a 4-dimensional external objective universe outside of mainline physics?" Many physicists pay no attention to that topic, because it has no effect on the way they are doing their physics. The 4-dimensional space is fully consistent with special relativity. If you do not agree with this, perhaps you could present information to the contrary.
How do you know? Can you present the logic that would lead to such a conclusion?
  • #35
bobc2 said:
[..] there is no alternative external objective picture out there that contradicts the 4-dimensional universe populated by 4-dimensional objects. I think many just abandon the idea of an external objective reality.
As a matter of fact, I presented a well-known alternative objective picture in an earlier thread* and again referred to it in my post #19 here; it seemed to directly answer the OP's question. So, what did I miss (or what did you miss)?
*https://www.physicsforums.com/showthread.php?t=539826&page=2 ; see also p.3
