Two blocks stacked centripetal motion
The problem involves two blocks with given masses, where one block is on top of the other, and they are being swung in a horizontal circle. The scenario includes considerations of static friction and centripetal force, with specific parameters such as mass values and the coefficient of static friction provided.
  • Participants discuss the role of static friction as a centripetal force and question the direction of friction in relation to the motion of the blocks. There is also confusion regarding the calculation of tension in the string and the implications of mass values.
The discussion is ongoing, with participants exploring different interpretations of the forces acting on the blocks. Some have provided clarifications about the direction of forces and the role of friction, while others express uncertainty about the calculations involved.
Participants are working within the constraints of the problem statement, which includes specific mass values and a coefficient of static friction. There is an acknowledgment of the assumption that the surface is frictionless, which impacts the analysis of forces.
thatoneguy6531
Mass 1(2.0kg) sits on top of mass 2(5 kg), which rests on a frictionless surface. The coefficient of static friction between mass 1 and 2 is 0.30. A string of length 5.0m is tied to mass 2, and both masses are swung around in a horizontal circle. Calculate a) the max speed of the masses and b) the tension in the string.
Fc=mv^2/r
I got the correct answer to a) by assuming static friction was the centripetal force but I don't understand why it is. Wouldn't the direction of the static friction be perpendicular to the rope to oppose mass 1 from falling of mass 2 as they're swung? And for b) I don't know what to do because if I just use T as the centripetal force for mass 2 I don't have its mass so I can't calculate it.
In this scenario, envision that the blocks' speed around the circle increases very gradually,
so that the rope pulls "essentially" toward the center of the circular path; ignore air drag!
a) What ELSE might deflect the top block from straight-line path to circular path?
(nothing else touching it but bottom block, only gravity as field Force)
b) block #2 has 5kg mass. the rope is the only thing pulling the 2 blocks inward.
Wow. I feel like an idiot now... I didn't realize the masses were given even after typing that out. Thanks though.
by the way, recall that ropes always pull inward along their length;
a rope pulling bottom block in a straight line would also need friction applied to top block, pointing along the rope.
and in the same strength ratio.
By pointing along the rope do you mean in the outward direction?
same direction that the rope pulls:
the rope pulls the bottom block inward, right?
what pulls the top block inward? nothing touching it except bottom block, by friction.
Ok thanks.
  • · Replies 17 ·
  • · Replies 18 ·
