Two difficult problems any hints?
  • Thread starter bcjochim07
In summary, the problem involves finding the resonant frequency of a car with additional passengers and the oscillation period of a uniform rod attached to a spring. For the car, the resonant frequency can be found by dividing the speed by the distance between bumps. For the rod, the resonant frequency can be found by combining the angular frequency of the physical pendulum with the tangential acceleration caused by the spring. The formula at=alpha*r can be used to find the new tangential acceleration.
bcjochim07
374
A 1000kg car carrying two 100 kg football players travels over a bumpy road with the bumps spaced 3 m apart. The driver finds that the car bounces up and down with maximum amplitude when he drives at a speed of 5 m/s. The car then stops and picks up three more 100 kg passengers. By how much does the car body sag on its suspension when these three aditional passengers get in?
A 200g uniform rod is pivoted at one end. The other end is attached to a horizontal spring. The spring is neither stretched nor compressed when the rod hangs straight down. What is the rod's oscillation period? You can assume that the rod's angle from the vertical is always small.
#1 I have stared at this problem for awhile, trying to figure out what "maximum amplitude should tell me. vmax= omega* A But that doesn't really lead me anywhere.
Hmmm... w= sqrt k/m and I don't know the k. Any hints would be greatly appreciated.
#2 If the rod weren't attached to the spring
I=(1/3)*(.200kg)(.20m)^2 I= .0027 kgm^2
so omega= sqrt [(.200kg*9.80*.10m)/.0027kgm^2] and from there I could find the period. However, I cannot visualize how the spring would affect this physical pendulum other than decreasing its amplitude possibly.
any ideas for these problems? they are driving me crazy
please?
Hi bcjochim07;! :smile:
Hint: You're not being asked for anything involving maximum amplitude.
You're being asked for the resonant frequency, which you can work out from the speed and from the humpitude. :smile:
so f0=fext
this frequency is 1 bump/3m* 5m/s = 1.67 bumps/sec
so to solve for k
1.67= (1/2pi)*sqrt[k/1200]
k= 132120 N/m
then I can use the same formula with the new mass to calculate the new frequency
Hi bcjochim07! :smile:
Looks good!
(except … I can never remember … is frequency = bumps/second, or half of bumps/second? :smile:)
ok … #2
This question is designed to test whther you can only apply the formula for frequency of a pendulum, or whether you actually understand where the formula comes from.
A pendulum has a harmonic movement because, loosely speaking, the horizontal "restoring force" is a (negative) constant times the displacement.
So … what is that constant? :smile:
(Then add it to the spring constant.)
frequency is oscillations per sec
This acts as a pendulum also??
Sorry … not following you. :confused:
Are you still on #1? I was on #2 (the uniform rod behaving like a pendulum).
oohh... ok sorry I didn't see your "ok"#2"
Frestoring=-(mg/L)s
so this constant is -mg/L
k= 9.8 so I add this to the spring constant to get a new constant
Then do I use the formula for frequency of spring with this new constant plugged in?
What about the mass--since it is an extented object how will I take that into account in the formula?
Do you remember someone saying this … :rolleyes:
ok … that gives you an restoring acceleration … combine it with the spring. :smile:
I don't understand what you mean by combining it with the spring. Do you mean I'm supposed to combined the forces?
angular acceleration= omega^2*r
Nooo … radial acceleration = omega^2*r.
You want the tangential acceleration (of the pendulum). :smile:
"combining the accelerations" makes more sense …
this is because the force of gravity acts all over the rod, but you only want to consider the movement of the tip of the rod.
Frestoring=-kx=ma a=-kx/m
omega= sqrt[Mgl/I] for a physical pendulum so from getting omega, could I find the angular acceleration and then go to tangential of the tip of the rod?
Then I would combine these accelerations, but then how do I get back frequency?
I don't think I can say -(mg/L)s=ma since this isn't a simple pendulum. Right?
I
bcjochim07 said:
… so from getting omega, could I find the angular acceleration and then go to tangential of the tip of the rod?
Yes … multiply the angular acceleration by length to get the tangential acceleration.
… how do I get back frequency?
You tell me … if acceleration is -k (a constant) times displacement, what is the frequency? :smile:
k=ma/x? I am really getting frustrated because I don't where I'm going with this
I'm not going to do it for you!
Show us what you've done so far …
the period without the spring,
the tangential acceleration without the spring,
the tangential acceleration only from the spring …
and then how you think you might combine them (make a guess if necessary!) :smile:
Ok, so from the I can find the angular frequency of the physical pendulum, then I will go to angular acceleration and then to tangential acceleration. The acceleration caused by the spring is a=-kx/m. So if I add those accelerations together, then I have a new tangential acceleration. There is a formula at=alpha*r and so maybe I could do something with that but I don't know what the r would be. I am I even remotely on the right track?
How do I relate the angular acceleration to the angular frequency?
1. What are the two difficult problems?
The two difficult problems refer to any two complex or challenging issues that require a significant amount of effort and thought to solve.
2. Can you provide any hints for solving these problems?
Unfortunately, without knowing the specific problems, it is difficult to provide specific hints. However, some general tips for problem-solving include breaking the problem down into smaller, more manageable parts, seeking advice or input from others, and thinking creatively.
3. How should I approach these difficult problems?
Each problem may require a different approach, but some general strategies include analyzing the problem, researching potential solutions, and testing different methods to see what works best.
4. Are there any resources or tools that can help with solving these problems?
There are many resources and tools available, such as textbooks, online articles, and problem-solving techniques. It may also be helpful to collaborate with others who have expertise in the topic or similar experiences.
5. How long does it usually take to solve these problems?
The time it takes to solve these problems can vary greatly depending on the complexity of the issues and the approach taken. Some problems may be solved quickly, while others may take weeks, months, or even years to fully resolve.
