Two particles moving in x-y plane with vector velocities
4 replies · 2K views · last reply
FaraDazed
the unit vectors i and j are parallel to the cordinate axey Ox and Oy. Two particles A and B each have a mass of 0.4kg, they both leave the origin O at the same time, and move in the x-y plane. The velocity vectors at t time for A and B are [itex](4t\hat{i} + 6t\hat{j})m/s[/itex] and [itex](3t^2\hat{i}-2\hat{j})m/s[/itex] respectively.
A: calculate in Joules the kinetic energy of B when t=2
B: Find the acceleration vector of A and prove the force acting on A is constant
C: calculate to the nearest 0.1N the magntiude of F and find to the nearest degree the angly between Oy and the line of action of F.
D:Find the distance between A and B when t=2.
I am unsure on all of them to be honest, I am not sure if I am using the vectors correctly and especially my integration as I can't see where any integration constants are.
KE=0.5mv^2
F=ma
Part A:
First I find the magnitude of the velocity of B
[tex] \dot{r_b}= 3(2)^2\hat{i} - 2\hat{j} \\<br /> \dot{r_b} = 12\hat{i} - 2\hat{j} \\<br /> |\dot{r_b}|= \sqrt{12^2 + 2^2} = 12.17m/s[/tex]
and then use that in the KE formula
[tex] KE=\frac{1}{2}mv^2 \\<br /> KE=\frac{1}{2}0.4(12.17)^2 \\<br /> KE=0.2 \times 148.11 = 29.62J \\[/tex]
Part B:
I differentiate to get the acceleration vector
[tex] \ddot{r_a}=4\hat{i}+6\hat{j}[/tex]
and as the I and J components are not functions of time that means the force must be constant as the acceleration is constant. Is that correct?
Part C:
I use Newtons second law to find F
[tex] F=0.4(4\hat{i}+6\hat{j}) \\<br /> F=1.6\hat{i}+2.4\hat{j} \\<br /> |F|=\sqrt{1.6^2+2.4^2}=2.9N [/tex]
And then to get the angle i did..
[tex] arctan(\frac{2.4}{1.6})=56.31 \\<br /> 90-56.31=34° [/tex]
to the nearest degree, I took the 56.31 from 90 as the question wants the angle between F and the y-axis, i hope I done it correct.
Part D:
To find the distance I first found both of the position vectors by integrating.
[tex] r_a=∫(4t\hat{i}+6t\hat{j}) \ dt = 2t^2\hat{i}+3t^2\hat{j} \\<br /> r_b=∫(3t^2\hat{i}+2\hat{j}) \ dt = t^3\hat{i}+2t\hat{j} \\[/tex]
And it asks when t is 2 so then i found the position vectors for both when t=2
[tex] r_a=2(2)^2\hat{i}+3(2)^2\hat{j} = 8\hat{i}+12\hat{j} \\<br /> r_b=(2)^3\hat{i}+2(2)\hat{j} = 8\hat{i}+4\hat{j}[/tex]
And then taking b from a
[tex] (8\hat{i}+12\hat{j})-(8\hat{i}+4\hat{j})=8\hat{j}[/tex]
and then the magnitude
[tex] \sqrt{8^2}=8m[/tex]
Any help is appreciated. :)
your answers to parts A,B,C all look correct. But in part D, you use
[tex]r_b=∫(3t^2\hat{i}+2\hat{j}) \ dt = t^3\hat{i}+2t\hat{j} \\[/tex]
But I don't think this is right, because the velocity vector that was given is:
[tex](3t^2\hat{i}-2\hat{j})m/s[/tex]
Maybe you accidentally forgot the minus sign?
p.s. excellent name :)
Ah thanks for point that out!
So should it be...
[tex]r_b=∫(3t^2\hat{i}-2\hat{j}) \ dt = t^3\hat{i}-2t\hat{j} \\[/tex]
and then taking the difference and magnitude then becomes..
[tex] (8\hat{i}+12\hat{j})-(8\hat{i}-4\hat{j})=16\hat{j} \\<br /> \sqrt{16^2}=16m[/tex]
yep. looks good, nice work! pretty neat too. it makes it easy to read, so thanks!
Thanks for your help :)
