Two projectiles shot toward each other: when do they collide?
9 replies · 3K views · last reply
FaraDazed
Points P and Q are in the same horizontal plane at a distance d metres apart. A projectile is shot from P in the vertical plane through PQ towards Q with a speed v m/s at an angle θ. Simultaneously another particle is shot from Q in the same vertical plane towards P with a speed of 2m/s at an angle of elevation α .
Find an expression for the distance between the two particles when one is vertically above the other one and hence prove that they collide if [itex]sin \alpha = \frac{1}{2} sin\theta.[/itex]
If [itex]\theta= \frac{1}{3}\pi[/itex] prove that they collide at a point above the level of PQ if...
[tex]v^2 > \frac{gd(\sqrt{13}-1)}{6\sqrt{3}}[/tex]
equations of motion
I just don't know how to approach this one at all. I don't want to just be given the answer, just some advice or help in how to approach the problem and any assumptions would be very very much appreciated.
I cannot understand the setup. Is PQ the line joining P and Q ? Also, if P and Q are in a horizontal plane, how can P or Q be vertically above the other ?
I think that's what it means when it says PQ - being the line/distance joining the two. And, sorry about the second bit that was my fault copying the question down; P and Q are points on the plane, its the particles that are fired from P and Q that are/will be above each other.
Thanks
OK. You can find the the time when the projectiles are above each other by solving xP=xQ where
xP= vt cos(θ) and xQ= d-vt cos(α)
Does this help ?
[edit] I made a mistake, I've corrected it.
Thanks, isn't the x cordinate of a projectile in this situation generally speed*t as in [itex]v\cos(\theta) t[/itex] though?
If i set them both to equal each other though I would get stuck as there is nothing I can do to manipulate it, is there?
[tex]v\cos(\theta)=d-v\cos(\alpha)[/tex]
I'm sorry you got caught by my mistake. I've edited my post so you can find the time now, and plug it into the equations for y to get the heights.
You get the time from ##vt\cos(\theta)=d-vt\cos(\alpha)##
OK thank you.
I am stuck with the algebra side of it then I think as I cannot see how to extract t from that. Plus not knowing either of the angles is confusing the hell out of me, I suppose if t is found then the alpha angle could be found as it states the speed for that one (2m/s).
The value of t when the projectiles are at the same x is
##vt\cos(\theta)=d-2t\cos(\alpha)\ \ \rightarrow\ vt\cos(\theta)+2t\cos(\alpha)=d\ \ \rightarrow t_s=\frac{d}{v\cos(\theta)+2\cos(\alpha)}##
The y values are
##y_P=vt\sin(\theta),\ y_Q=2t\sin(\alpha)## put ##t_s## into these and then subtract them.
corrected in my next post
You need to do the algebra.
##vt\cos(\theta)=d-2t\cos(\alpha)\ \ \rightarrow\ vt\cos(\theta)+2t\cos(\alpha)=d\ \ \rightarrow t_s=\frac{d}{\cos(v\theta)+2\cos(\alpha)}##
The y values are
Thanks for your help. :)
With the y values, doesn't gravity need to be accounted for?
Yes. Sorry I'm making a lot of mistakes. The y equations (assuming that the initial height is 0) are
##y_P=\int(v\sin(\theta)-gt) dt=vt\sin(\theta)-(1/2)gt^2## and ##y_Q=\int(2\sin(\alpha)-gt)dt=2t\sin(\alpha)-(1/2)gt^2##
So the difference in height is ##vt\sin(\theta)-2t\sin(\alpha)## and the Y-values are equal (for t>0) only if ##v\sin\left( \theta\right) \,=2\,\sin\left( \alpha\right)## which is *not* what is given for this condition.
