Two similar Bayesian problems. Did I get them right?
  • Context: Graduate
  • Thread starter Thread starter Fredrik
    Bayesian
The discussion revolves around two Bayesian probability problems involving conditional probabilities. Participants explore the calculations and reasoning behind determining the probabilities in each scenario, focusing on understanding the application of Bayesian principles.
  • One participant expresses uncertainty about their understanding of Bayesian problems and seeks help to approach the problems correctly.
  • Another participant clarifies the pronunciation of "Bayesian" and introduces the formula for conditional probability, emphasizing the relationship between events A and B.
  • A participant questions the meaning of P(A and B) when A and B are not independent, indicating a lack of clarity on the concept.
  • One participant presents their reasoning for Problem 1, calculating the probability that the box chosen contained 10 balls as 10/11, based on the outcomes of picking a ball numbered 9.
  • For Problem 2, the same participant calculates the probability of being in building A given the room number is 9 as 1/2, using a similar reasoning approach.
  • Another participant suggests using a different formula for conditional probability, providing specific values for P(B), P(B|A), and P(A) in the context of Problem 1.
  • There is a clarification regarding the formula for conditional probability, with participants confirming the correct expression.
  • A later reply asserts that the answer to both problems is 10/11, arguing that the first problem is straightforward while the second requires consideration of the occupied rooms.
Participants express differing levels of confidence in their solutions, with some agreeing on the probability of 10/11 for Problem 1, while the second problem's probability remains contested. There is no clear consensus on the solutions to both problems.
Some participants express uncertainty about the application of conditional probability, particularly regarding the independence of events and the interpretation of the probabilities involved. The discussion reflects varying levels of understanding and confidence in Bayesian reasoning.
Fredrik
Staff Emeritus
Homework Helper
Insights Author
I would appreciate if someone could help me solve and understand these two problems. The first version of this post contained my attempts to solve them, but I have deleted those parts because I saw that I had messed up badly. I really suck at this type of problems, but perhaps someone can show me a good way to approach them.
Edit: OK, now I think I get it. If I still think I'm right in 20 minutes I'll probably edit this post again and add my new attempts to solve the problems.
Another edit: I have to go to bed, so I don't have time to post the explanations, but the results I get are 10/11 for the first problem and 1/2 for the second. Does that sound right?
This is not homework by the way. Oh, and since I'm asking about "Bayesian" probabilities, I would also appreciate if someone could tell me how that word is supposed to be pronounced. Baysian? Buy-eeshan? Buy-eezian? Bay-eezian? I've been wondering about that for years. :smile:
Problem 1 Two identical boxes. One of them contains 10 balls numbered 1-10. The other one contains 100 balls numbered 1-100. You don't know if the box on the left contains 10 or 100. You use a coin flip to choose one of the boxes and ask a friend to pick a ball at random from it. The ball he picks has the number 9 written on it. What is the probability that the box you chose contained 10 balls?
Problem 2 Two identical buildings. Both of them contain 100 rooms numbered 1-100. 110 people are blindfolded and randomly put into rooms 1-10 of building A, and rooms 1-100 of building B. You're one of those people, and you're told that your room number is 9. What's the probability that you're in building A?
"Bayesian" comes from a guy named "Bayes", which would be pronounced like "Bays". So "Bayesian" is pronounced like "Bays-Ian". You can actually here it here. Anyways, the idea is to use the idea of conditional probability:
[tex]P(A | B) = \frac{P(A \cap B)}{P(B)}[/tex]
So the probability of A, given that B has occurred, is equal to the probability that both A and B occur, divided by the probability that B occurs. In problem 1, you want to calculate the probability that the box chosen had 10 balls, given that the ball that was picked had 9 written on it.
Thanks AKG. At least now I know how pronounce Bayesian. I'm not sure I understand the formula for the conditional probability though. A and B are obviously not independent in the formula. If they were, the formula would be kind of pointless, since we would have P(A|B)=P(A) and P(A and B)=P(A)*P(B). What I don't understand is what P(A and B) means when A and B are not independent.
Anyway, that doesn't matter much right now, since I believe my solutions are correct. If I'm wrong, I hope someone will tell me.
These are my solutions:
Problem 1
There was a 1/2 probability that you picked the box with 10 balls and a 1/2 probability that you picked the box with 100 balls. If you picked the box with 10 balls, it was certain that the ball your friend picked would have a number less than 11. If you picked the box with 100 balls, there was only a 1/10 chance that he would pick a ball with a number less than 11, and a 9/10 chance that he would not. From this we get the probabilities for each possibility:
. . . . . . . . . . . . . Small number . . . . . . . . . Large number
Box with 10 . . . . . 1/2 * 1 = 1/2 . . . . . . . . 1/2 * 0 = 0
Box with 100 . . . . 1/2 * 1/10 = 1/20 . . . . . . 1/2 * 9/10 = 9/20
If we do this a large number of times, we will get a ball with a small number from the box with 10 balls 1/2 the times and we will get a small number 1/2 + 1/20 = 11/20 times. The probability we seek is the first of those numbers divided by the second: (1/2)/(11/20)=10/11.
Problem 2
You were assigned a room that was chosen at random from a set of 110 rooms, 10 of which is in building A, so there was a 1/11 probability that you ended up in building A and a 10/11 probability that you ended up in building B. If you ended up in building A, it was certain that you would get a low room number. If you ended up in building B, there was a 1/10 probability that you would get a low room number and a 9/10 probability that you would get a high room number. From this we get the probabilities for each possibility:
Building A . . . . . . 1/11 * 1 = 1/11 . . . . . . . 1/11 * 0 = 0
Building B . . . . . . 10/11 * 1/10 = 1/11 . . . . 10/11 * 9/10 = 9/11
If you do this a large number of times, you will find yourself in a room with a small number in building A 1/11 times, and you will find yourself in a room with a small number 2/11 times. The probability we seek is the first of those numbers divided by the second: (1/11)/(2/11)=1/2.
I would suggest that you use the formula:
[tex]P(A|B)= \frac{P(B)P(B|A)}{P(A)}[/tex]
instead. In the first example [tex]A[/tex] is "the box contains 10 balls" and [tex]B[/tex] is "You pick ball number 9", we get [tex]P(B)= \frac{1}{2}(\frac{1}{10}+\frac{1}{100})[/tex], [tex]P(B|A)= \frac{1}{10}[/tex], and [tex]P(A)=\frac{1}{2}[/tex]. Hence [tex]P(A|B)= \frac{10}{11}[/tex].
Did you mean P(A|B) = P(A)P(B|A)/P(B)?
Yes I did :blushing:
Fredrik said:
I believe the answer to both the problem is 10/11. I think its straightforward in the first case, whereas in the second one the probability of picking room no. 9 given that the person is in bldg A is 1/10 only bcos only 10 rooms were occupied and since we chose an occupied room.
  • · Replies 20 ·
  • · Replies 29 ·
  • · Replies 21 ·
