Two Slit Interference Question =] Thanks
The discussion revolves around a two-slit interference problem involving monochromatic light with a specified wavelength and slit separation. Participants are analyzing the positions of intensity minima and maxima on a screen based on given parameters.
  • Participants discuss the calculation of the first and third intensity minima using the formula for dark fringes. There is an attempt to relate the positions of the maxima and minima of two different beams, questioning the correct application of the interference equations.
Some participants have provided insights into the definitions of maxima and minima, while others express confusion regarding the calculations and relationships between the two beams. There is an ongoing exploration of how to correctly set up the equations for the second beam's wavelength.
Participants are working under the constraints of specific wavelengths and distances, with some uncertainty about the correct application of interference conditions. The original poster mentions a discrepancy in their calculated wavelength for the second beam, indicating potential misunderstandings in the problem setup.
chipmunk951
Monochromatic light of wavelength 656 nm is normally incident on a vertical plate with two slits at positions +-d/2 where d=.25mm, the resultant interference pattern is observed on a screen at distance D= 3.4m away, let y denote vertical position on the screen with y=0 at the same height as the midpoint between the two slits. Picture attached
http://img66.imageshack.us/img66/5378/showmeplmx4.gif
a) What is the location y1 of the first intensity minimum on the screen, measured up from the central maximum?
b) what is the location y3 of the third intensity minimum on the screen?
c) A Second monochromatic beam is normally incident on the same slits. The second maximum pof the second beam occurs at y3, the third minimum of hte first beam. What is the wavelength of the second beam?
y=L tan theta
d*sin theta = m lambda
d*sin theta = (m-1/2) lambda
Part a) It's a dark fringe so dsin theta = (m-1/2) lambda and m=1 because it's the first one, and solve for theta, use y= L tan theta, take the difference which is y-0 and you get y1, whihc in my case is 4.4608 mm
b) Same thing except m is now 3, ends up being 22.3045 mm
c) here's where I got stuck, It said the second max of the second beam occurs at y3, the third minimum of the first beam, here's what I thought I Could do,
d*sin theta = (3-1/2)lambda1 This is for the y3, third minimum
d*sin theta = 2lambda2 This is for the second beam, set them equal to each other
(3-1/2)lambda1 = 2 lambda2
And solve for lambda2, but this didn't work, i got a value of 8.2e-7 and it's not correct :(, I also tried going backwards with my location y3, solving for the angle and doing (d*sin theta)/2 but i go the same answer.
Second maximum is for m=1 (first maximum is in the center, at m=0)
So it will be like
(3-1/2)lambda1 = lambda2
chipmunk951 said:
So it will be like
+1 Bump
chipmunk951 said:
+1 Bump
Bump, that still didn't work and I'm kind of out of ideas >.<
9K
