What Are the Possible Wavelengths of the Second Light in a Two-Slit Experiment?
  • Thread starter Thread starter mneox
    Interference
The discussion focuses on determining the possible wavelengths of a second visible light in a two-slit interference experiment, where one bright fringe (m=2) is solely attributed to a light with a wavelength of 300 micrometers. The key equations involved are y = (R)(m)(lambda)/(d) and dsin(theta) = m(lambda). The conclusion is that for the second color to not appear at the m=2 fringe, it must undergo destructive interference at that specific point, allowing for the calculation of its wavelength based on the conditions of interference.
  • Understanding of two-slit interference principles
  • Familiarity with the equations of wave interference
  • Knowledge of wavelength and fringe patterns
  • Basic trigonometry for calculating angles in interference
  • Study the conditions for destructive interference in wave optics
  • Learn how to calculate fringe positions using the two-slit interference formula
  • Explore the relationship between wavelength and interference patterns
  • Investigate the effects of varying wavelengths on interference results
Students studying wave optics, physics educators, and anyone interested in understanding interference patterns in light experiments.
mneox
Suppose I have two different visible lights of different wavelengths passing through in a two-slit interference experiment. What appears on the screen is mostly a mixture of the two colours. However, one of the bright fringes, say m=2 is purely 1 of the colours (this light has say, 300 micrometers in wavelength), and none of the other.
What are the possible wavelengths of the second visible light?
How do I figure this out? If none of the second colour appeared, it would mean that somehow there was interference and therefore only the first colour showed? How would I find the wavelengths of the second colour though.
Sorry I can't really give a better attempt or answer, I'm just so lost on this that it's discouraging. Thanks for your help/explanations in advance.
See, for a mixture of colours to appear, both the colours can never undergo destructive interference as in that case there would be zero intensity(ideally) at the point where it happens.Now a bright fringe will have one color only if the light ray having the other color undergoes destructive interference at that point. So now you can apply the condition for destructive interference of the light of second wavelength and find it out.But of course before that you will have to find the distance of the point from the central maximum by using the values given for the light of 300 micro meter wavelength
  • · Replies 23 ·
12K
