Two-Step Mechanism: A + B -> D
  • Thread starter Thread starter nothing123
    Mechanism
The discussion centers on a two-step reaction mechanism: A + B -> C followed by C -> D, where the second step is the rate-determining step. The reaction rate is defined as r = k2[C], and while A and B are zero order, their concentrations influence the intermediate C, thus affecting the overall rate. Adding or decreasing A or B alters the concentration of C, which is crucial for determining the reaction rate, despite A and B not being part of the rate-determining step. The equilibrium constant Kc = [C]/[A][B] is also discussed, emphasizing that adding A at equilibrium concentration does not shift the reaction to the right.
  • Understanding of reaction mechanisms and rate-determining steps
  • Knowledge of equilibrium constants and their significance
  • Familiarity with zero-order and first-order reaction kinetics
  • Basic concepts of concentration and its effects in chemical reactions
  • Study the impact of zero-order kinetics on reaction rates
  • Learn about equilibrium shifts and Le Chatelier's principle
  • Explore the derivation of rate laws from reaction mechanisms
  • Investigate the role of intermediates in multi-step reactions
Chemistry students, researchers in chemical kinetics, and professionals involved in reaction mechanism studies will benefit from this discussion.
nothing123
Hi,
So if we have a two-step mechanism that goes something like this:
1) A + B -> C
2) C -> D
A + B -> D
and the second step is the slow step, the reaction rate would be r = k2[C] correct? Well, seeing as reactants A and B are zero order, varying their concentrations wouldn't affect the rate. However, one of the questions I encountered said if you ADD A or B or DECREASE A or B, the rate subsequently increases and decreases respectively. I understand the reasoning for this since more A or B would drive the reaction to the right and thus increasing the concentration of intermediate C, which is important in determining the rate. But really, what's the difference between varying the concentration of A or B and adding A or B; if we add A, are we not effectively increasing its concentration?
I got to second question kind of related to this. We have a reaction A + B -> C with equilibrium constant: Kc = [C]/[A]. Now, if we add reactant A, BUT at the same concentration as the equilibrium concentration, then according to the equation, the reaction does not shift to the right, correct?
Thanks.
if A and B are solids, then, adding either of them to the reacting solution would increase their concentration, and shift the equilibrium more to the right. you are increasing the number of moles of A or B, but keeping the volume fixed.
if A and B are solutions, then the concentration does not change. if you add 10 cm3 of 1 M HCl to 30cm3 of 1 M HCl, then you get 40cm3 1 M HCl. the concentration does not change. there is no change in reaction rate.if the concentration of A at equilibrium is x M, and the concentration of the additional A you add is also x M, then the concentration of A in the solution does not change.
The thing is though, A and B are not part of the rate-determining step so technically even increasing either of their concentrations should not affect the rate 9ince they are zero order no?
The concentration dependence on A and B are not zero order as they affect the concentration of [C]. In other words, [C] is a function of [A] and [ B]. For example, if you assume that step 1 reaches equilibrium much more quickly than a turnover of step 2, then [C] = K1[A][ B], where K1 = k1/k-1 is the equilibrium constant for reaction 1. In this case, your rate equation becomes:
rate = k2K1[A][ B]
and, the reaction is first order in both A and B.
9K
