Two Teflon pucks colliding on frictionless table
8 replies · 2K views · last reply
Vraj Patel
Two pucks (5 kg each) made of Teflon are on a long table, also made of Teflon. Puck A is sitting at
rest on the left end of the table. Puck B is 15 m away at the right hand end of the table, and is
travelling toward Puck A with an initial speed of 0.5 m/s. A person on the left waits 1.5 seconds and
then pushes Puck A forward from rest with a force of 20 N applied at an angle of 30° to the horizontal.
If that force is maintained at a steady rate for the entire question, how far will puck A travel before it
strikes puck B? (The coefficient of friction between the Teflon and Teflon is 0.04.
2. The attempt at a solution:
Puck A
Fax = 20NSin30
Fax = 10N
Fay = 20NCos30
Fay = 17.32N
Fg = mg
Fg = (5kg)(9.8m/s^2)
Fg = 49N
Fn = Fay + Fg
Fn =17.32N + 49N
Fn = 66.32
Ff = uFn
Ff = (0.04)(66.32N)
Ff = 2.65
Fnet = Fax - Ff
Fnet = 10N - 2.65
Fnet = 7.35N
a = Fnet/m
a = 7.35N/5kg
a = 1.47m/s^2
d = v1t + 1/2at^2
15-x = 1/2(1.47)(y-1.5)^24
x = -0.74y^2 + 2.22y +13.33
Puck B
Fg = mg
Fg = 49N
Ff = uFn
Ff = (0.04)(49N)
Ff = 1.96N
Since there is no applied force Fnet = -Ff
a = Fnet/m
a = -1.96/5kg
a = -0.39m/s^2
d = v1t + 1/2at^2
x = (0.5)(y) + 1/2(-0.39)(y)^2
-0.74y^2 + 2.22y +13.33 = 0.5 - 0.195y^2
0 = 0.545y^2 - 1.72y-13.33
I then put it in the quadratic formula and got:
y = 6.77s and y = -3.61s(omited)
Puck A Distance
d = v1t + 1/2at^2
d = (0m/s)(6.77s-1.5s) + 1/2(1.47m/s^2)(6.77-1.5s)^2
d = 20.41m(This answer doesn't make sense)
Hi,
First thing that comes to mind is your decomposition of the 20 N in ##F_x## and ##F_y## ... :rolleyes:
Second thing I notice is that you deleted part 2 of the template -- not good !
Third is I miss a list of variable names. What is ##d## ? (and: are you sure that is what you think it is ? -- a drawing might help an awful lot here ! )
haruspex said:
Pushing down or pushing up?
pushing down
BvU said:
Hi,
d represents distance.
BvU said:
Hi,
I tried to upload a photo of my diagram but it wouldn't let me, but the pucks are heading toward each other.
I know. How does your expression for ##d## deal with the fact that the pucks are moving towards each other (as opposed to: moving away from each other, or moving in the same direction) ?
Hint: Puck B has no external force affecting it other than friction. So why not find out how far it can coast before coming to rest, and how long it takes to come to rest? Is it less than or greater than the 1.5 s pause before puck A starts to move?
