Uncertainty Analysis: Understanding Errors in Quantity Measurements
  • Context: Undergrad
  • Thread starter Thread starter Henryflycat
    Analysis Uncertainty
The discussion centers on uncertainty analysis in quantity measurements, specifically addressing the three types of errors: reading error, standard deviation from repeated measurements, and equipment accuracy. Participants debate the appropriate method for calculating the final error, X_error, with suggestions including error propagation using the square root of the sum of squares of the three errors and taking the maximum error when smaller errors do not significantly contribute. The consensus emphasizes that smaller errors can be ignored only if they are substantially less than the largest error, ensuring accurate reporting of uncertainty.
  • Understanding of uncertainty analysis concepts
  • Familiarity with error propagation techniques
  • Knowledge of standard deviation and its calculation
  • Awareness of equipment accuracy specifications
  • Research error propagation methods in detail
  • Study the impact of standard deviation on measurement accuracy
  • Learn how to assess equipment accuracy and its implications
  • Explore case studies on uncertainty analysis in scientific measurements
Students, researchers, and professionals in scientific fields who are involved in measurement and data analysis, particularly those focusing on uncertainty quantification and error analysis.
Henryflycat
Hey,
I have a question about uncertainty analysis. So my university told me that, usually a quantity has 3 types of errors, reading error, standard deviation (which comes from some repeated measurements of that quantity), and equipment accuracy (which is usually stated on the equipment).
My question is, if I've got these 3 errors, to report the final quantity with X_est +/- X_error, which error should I use for X_error? Some references said I need to do a propagation of all these 3, like the square root of reading_error^2 + accuracy^2 + std_dev^2. Someone said we can ignore the smaller ones, just the take maximum of these 3 errors to be the final error X_error.
Which method is actually the standard way for error analysis? I'm pretty confused.
Thanks a lot.
Ignore only if they do not significantly contribute to the overall uncertainty. It would not make a great deal of sense to include errors whose effect is less than the precision of the measure quantity.
You can only do this if the largest is much larger than the others.
