Understanding Light and Forces: Solving a Simple Laser Question as a Student
  • Thread starter timhunderwood
    Laser
timhunderwood
Hi I'm a student in school and I'm having a mental block on how to do this question. Could some give me a hint as to the principals I'm meant to consider /use.
Q) A red, 100mW, laser beam , wavelength 650nm, is incident normally on a perfectly black disk . Calculate the force on the disk.
I've never really had to relate photons to forces before. I tried consider change in momentum of photon is equal to impulse on black disk but that didn't work.
Thanks for the help
You are correct it's just the momentum of the photons ( = h / lambda )
You can treat the photons just like you were throwing tennis balls at the disc - but remember that the photons are absorbed by the black disc so it is an in-elastic collision.
i tried using change of momentum = impulse but I only need to use lambda or Power not both so i think I'm doing something wrong can someone show me a solution.
Thanks
You need both, the power tells you how many photons/sec hit the disc and the wavelength tells you how much effect they have.
