Understanding [T]_gamma and Its Purpose in Linear Transformations
  • Context: Undergrad
  • Thread starter Thread starter DhineshKumar
    Linear transformation
4 replies · 2K views
DhineshKumar
let's consider we have a linear transformation T: R^2->R^3 and alpha={ordered basis of R^2} and beta{ordered basis of R^3} and gama={v1,v2}, v1=(1,-1),v2=(2,-5). now I need to find [T]_gama(associated matrix)? When i read about it, i understood it as, first we have to find transformation of each of the vectors from gama, [T(v1) , T(v2)] and write T(v1),T(v2) as linear combination of gamma vectors. The coeff. written in column would give me [T]_gamma.
I want to know whether what i have understood is right or wrong? and moreover i want to know why we need different forms [T]_(alpha/beta/gama) ?
The matrix for the transformation, with respect to the ##\alpha## and ##\beta ## bases, will have two columns, each with three elements.
The elements of the first column will be the coordinates of ##Tv_1##, in the ##\beta## basis.
The elements of the 2nd column will be the coordinates of ##Tv_2##, in the ##\beta## basis.
where ##v_1## and ##v_2## are the two vectors in the ##\alpha## basis.
I don't know what the ##\gamma## basis is that you're referring to, though. Only two bases are needed.
Yes, to find the matrix representing a linear transformation from one vector space to another, apply the linear transformation to each basis vector in some ordered basis, then write the result as a linear combination of basis vectors in the other space. That will give a column of the matrix representation. As for "why we need different forms", linear transformations apply to vectors while matrices apply to arrays of numbers. You need to connect one with the other and bases allow you to do that.
For example, suppose our linear transformation maps (x, y), in [itex]R^2[/itex] to (x- y, x+ y, y) in [itex]R^3[/itex]. The "usual basis" for [itex]R^2[/itex] is {u1, u2}= {(1, 0), (0, 1)} and the "usual basis" for [itex]R^3[/itex] is {v1, v2, v3}= {(1, 0, 0), (0, 1, 0), (0, 0, 1)}. Apply the linear transformation to u1= (1, 0) gives (1- 0, 1+ 0, 0)= (1, 0, 0)= 1(1, 0, 0)+ 0(0, 1, 0)+ 0(0, 0, 1)= 1v_1+ 1v_2+ 0v3 so the first column of the matrix is [itex]\begin{bmatrix}1 \\ 0 \\ 0 \end{bmatrix}[/itex]. Applying it to u2= (0, 1) gives (0- 1, 0+ 1, 1)= (-1, 1, 1)= -1(1, 0, 0)+ 1(0, 1, 0)+ 1(0, 0, 1)= -1v1+ 1v2+ 1v3 so the second column is [itex]\begin{bmatrix} -1 \\ 1 \\ 1\end{bmatrix}[/itex]. The matrix corresponding to the linear transformation is [itex]\begin{bmatrix} 1 & -1 \\ 1 & 1 \\ 0 & 1\end{bmatrix}[/itex].
You can check that [itex]\begin{bmatrix}1 & -1 \\ 1 & 1 \\ 0 & 1 \end{bmatrix}\begin{bmatrix}x \\ y \end{bmatrix}= \begin{bmatrix}x- y \\ x+ y \\ y \end{bmatrix}[/itex]
Another basis for [itex]R^3[/itex] would be {(1, 1, 0), (1, -1, 0), (0, 0, 1)}, Applying the given linear transformation to (1, 0) and (0, 1) as before, we again get (1, 1, 0) and (-1, 1, 1). But now we want to find a, b, and c so that (1, 1, 0)= a(1, 1, 0)+ b(1, -1, 0)+ c(0, 0, 1). That gives the three equations a+ b= 1, a- b= 1, c= 0. Adding the first two equations 2a= 2 so a= 1 and then b= 0. (1, 0, 0)= 1(1, 1, 0)+ 0(1, -1, 0)+ 0(0, 0, 1). The first column is [itex]\begin{bmatrix}1 \\ 0 \\ 0 \end{bmatrix}[/itex].
Applying the given linear transformation to (0, 1) we get, as before, (-1, 1, 1) and want to find a, b, and c such that (-1, 1, 1)= a(1, 1, 0)+ b(1, -1, 0)+ c(0, 0, 1). That gives the three equations a+ b= -1, a- b= 1, c= 1. Adding the first two equations 2a= 0 so a= 0 and b= -1. c= 1. The second column is [itex]\begin{bmatrix}0 \\ -1 \\ 1 \end{bmatrix}[/itex].
The matrix is [itex]\begin{bmatrix}1 & 0 \\ 0 & -1 \\ 0 & 1\end{bmatrix}[/itex].
Thank you so much @Hallsoflvy for your explanation.
@andrewkirk gamma bases are separate bases that I define other than standard canonical bases. And it has vectors that I've mentioned in the question.
