Understanding the Role of Space as the Background for Light and Gravity"
  • Context: Graduate
  • Thread starter Thread starter wolram
The discussion revolves around the concept of space as a background for light and gravity, exploring theoretical implications and interpretations of what constitutes this background. Participants examine the role of space in physics, particularly in the context of General Relativity and the nature of the vacuum.
  • Some participants propose that space serves as the medium for light and gravity, especially in the absence of aether theories.
  • Others argue that the term "background" lacks a unique definition and can refer to different concepts, such as an assumed metric geometry or a continuum without a fixed metric.
  • A participant highlights the distinction between starting with a floppy continuum without preconceptions versus a continuum with a fixed metric in constructing models of space or spacetime.
  • There is a suggestion that the understanding of "empty space" or "vacuum" is complex and not fully understood, with references to Frank Wilczek's work on the subject.
  • Questions are raised about how geometry can be performed in a continuum that lacks particles or a defined metric.
  • Another participant emphasizes that physical fields do not need to be localized to a fixed background, aligning with the principles of General Relativity.
  • Discussion includes references to mathematical foundations of General Relativity, particularly regarding metric-free manifolds and the concept of the Lie derivative.
Participants express multiple competing views regarding the definition and implications of "background" in the context of space, light, and gravity. The discussion remains unresolved, with no consensus on the best way to conceptualize these ideas.
Limitations include the ambiguity of the term "background," the dependence on definitions of space and metric, and the unresolved nature of certain mathematical concepts related to geometry in a continuum.
wolram
Dearly Missed
This may be nieve but i have not found an explanation yet, i guess the background is the medium needed for light to travel by and for gravity to permeate, but as aether theories have been ruled out this leaves only space it's self as the background AFAIK.
In this case for some theories space must have been the first (thing) to exist?
Space news on Phys.org
The word has no one unique meaning. When people talk about background they mean different things and you have to study the context to tell what they mean.
What many people mean by it is an assumed background metric geometry. A continuum---a set of points representing space or spacetime can be either stiff or floppy. What gives a continuum a rigid shape is having a metric or distance function defined on it. Then you can measure angles and triangles and areas and volumes etc. If there is a fixed metric on a continuum you can do geometry on it.
If a continuum has no metric then it is shapeless and floppy and stretchy. You can't do geometry.
There is a BIG ISSUE in physics which is when you build a model of space or of spacetime should you
1. start with a completely floppy continuum and not assume any fixed metric at all, at the beginning. No preconceptions, just distribute some matter in your continuum and see what kind of metric evolves. (this is how General Relativity does it) Or should you
2. start with a continuum already equipped with a fixed metric----typically representing a flat zero-curvature vanilla geometry---and then add stuff bit by bit and allow slight modifications, like ripples on a basically flat pond surface.
So in the context of that ongoing argument, background is shorthand for background metric assumed at the start, in constructing a model. 1915 General Relativity manages to not need a background metric, so it is independent of background geometry.
I think you are asking about something else. You say you guess "the background is the medium needed for light to travel by and for gravity to permeate" and that is certainly one possible definition but I never heard anyone use the word background to mean that. However one says it, asking what it is is a good question. You could use a different word so as to reduce the risk of confusion.
You could say "empty space" or "vacuum" or maybe continuum. whatever light travels thru and is shaped by the gravitational field.
Calling it background would also seem like a good idea if it were not for the risk of getting mixed up in a loud discussion of something entirely different---where people mean something else by it.
Frank Wilczek has a new book (The Lightness of Being) which is entirely about the modern physics understanding of the vacuum. He never once calls it "background", though. He has various things he calls it. Sometimes he says "the entity we call empty space".
His point is that we call it empty space but we probably shouldn't think of it as empty.
I conclude from reading the book, and everything else I've seen on the subject, that we don't know. We don't know what is the [whatever light travels thru and is shaped by gravity]. We don't know what the background is (if you insist on calling it that).
We don't know the best way to think about empty space. What Wilczek says in the book is that HE sees ways in which the LHC results will help greatly to grasp empty space better. He explains how, for him, knowing how many Higgs-like particles there are and what their properties are will help figure out how empty space works.
He explains how seeing some supersymmetry would be a big help in comprehending the vacuum.
The book points out that there are immediate questions. Some things that are known about empty space---he refers to layers of knowledge. He says we know some layers but there are further layers about which he is itching with curiosity. He makes lists and some items have question marks beside them. It is in some ways it is an impatient book. He is very eager to get some LHC results.
He doesn't talk about the Big Bang, or string theory, his focus is on ordinary empty space and he takes a kind of bottom-up approach to it (based on those experiments done in the past at earlier colliders and those he expects to be done in the future.)
Thanks Marcus,
How would one perform geometry in a pointless, non particle inhabited contium?
(Marcus)
The ingredients of GR are
i) A blank manifold
ii) the gravitational and matter fields
There is no reason why the physical fields should be localized over the spacetime manifold one way or another as long as they are located with respect to one another in the same way!
So matter is located with respect to the gravitational field only but not with respect to some given apriori fixed background container.
In a review of rovelli's book I write another expalination of background independence - I hope this will be illuminating.
regards
ian
I te review rovelli's book I go by the name of ian beynon - I also contributed to background independence section of LQG of wikipedia.
I think you may be asking about the mathematical foundations of GR. A blank manifold is still a countinuum of points even though theer is no metric to define distances. Differential geometry has been developed for metric-free manifolds. An important concept is the Lie derivative which I talk about in wiki. Hope this helps
regards
ian
I the review rovelli's book I go by the name of ian beynon - I also contributed to background independence section of LQG of wikipedia.
I think you may be asking about the mathematical foundations of GR:
A blank manifold is still a countinuum of points even though there is no metric to define distances. Differential geometry has been developed for metric-free manifolds. An important concept is the Lie derivative which I talk about in wiki. Hope this helps
regards
ian
Background Independent Framework
Link:
http://en.wikipedia.org/wiki/Background_independence"
  • · Replies 27 ·
  • · Replies 25 ·
  • · Replies 25 ·
  • · Replies 28 ·
