Understanding Units: Calculations with Units
  • Thread starter tomtomtom1
    Units
4 replies · 2K views · last reply
tomtomtom1
Understanding Units
T = L^2
Hi
I am trying to figure understand what happens to the units when I perform calculations on them. For instance, given the equation:-
T = L^2
If the value of L was 78mm then what would the value of T be?
Would it be:
(78mm)^2 = 78^2 mm^2 = 6084mm^2
or would it be:-
(78mm)^2 = 78^2 = 6084mm
Can anyone shed any light?
Thank you.
tomtomtom1 said:
Problem Statement: Understanding Units
Relevant Equations: T = L^2
Hi
T = L^2
Would it be:
or would it be:-
Thank you.
You multiply the units as well as the numbers.
You should carry the units along and they get exactly the same arithmetic operations as the numerical values. So if L has units of mm, T will have units of mm^2.
Your units that you write can become confusing, in this case to the extent of ambiguous.
If you are indicating the unit for L is the METER, which you could abbreviate as M, then your expression using variable R with including the unit, becomes (L)(L)(METER)(METER), as I here include the unit, and so T=L^2(METER)^2
and then the unit for T is METER2.
Note in post #4, I spelled the word because "m" looks like could be "meter" or later "mm" could be misread as "millimeters".
