Universe finite or infinite during the first instance of inflation?
The discussion revolves around the nature of the universe during the first moments of inflation, specifically whether it was finite or infinite at that time. Participants explore implications of these conditions on the universe's current state and the theoretical frameworks surrounding inflationary cosmology.
  • Some participants question whether the universe was finite and closed during early inflation or if it was infinite from the beginning, suggesting that if it was finite then, it must be finite now.
  • Others argue that if the universe was infinite at the start, it would remain infinite, and they express skepticism about the possibility of transitioning from finite to infinite.
  • A participant expresses confusion over analogies that imply a finite universe could expand into an infinite one, questioning the implications of finite energy becoming diffused in an infinite space.
  • Some participants discuss the concept of a flat universe as a natural result of inflation, while raising concerns about the ability to measure the universe's flatness accurately.
  • There are references to mathematical concepts, such as infinite series, with some participants attempting to draw parallels between these concepts and the expansion of the universe.
  • A later reply introduces the idea that topology-changing behavior might be necessary for a finite universe to become infinite, but notes that this is generally considered impossible in the framework of general relativity.
  • One participant suggests that the universe must be infinite at its inception to remain infinite, while also acknowledging that if it is closed, it would remain so but be vastly larger than detectable limits.
  • Another participant highlights ongoing research in quantum cosmology that challenges traditional views of the big bang and suggests models that extend back before the universe's expansion began.
Participants express multiple competing views regarding the finiteness or infiniteness of the universe during inflation, and the discussion remains unresolved with no consensus reached.
Some participants note limitations in current models, such as the applicability of general relativity only after the universe has started expanding, and the potential for new theories in quantum cosmology to reshape understanding of the universe's origins.
Herbascious J
-In the first few fractions of a second after the big bang, was the universe finite and closed during early inflation, before it smoothed out and became flat and infinite? I am wondering because I would like to know if the theory implies that the universe initially inflated with a finite volume, then became infinite. Or, did the universe come into being infinite, then went through a period of rapid inflation during the first few mili-seconds. Thanks!
Space news on Phys.org
If it was finite then, it is finite now. If it was infinite then, it is infinite now. Things do not go from finite to infinite.
If you can figure out WHICH it was, I'm sure there's a Nobel Prize in it for you.
:D Thanks for the great reply. That's what I figured. I was struggling with the question because some explanations seemed to imply that the 'sphere' of the volume of the universe layed out into a flat sheet (perhaps bad analogies). Anyway, I couldn't get my mind comfortable with a finite sphere of matter, having any matter density at all after turning infinite. It seemed the finite energy would become totally diffused once infinite, and there would be no galaxies at all. Thanks!
An infinite series can either converge or diverge. By the same token, in my opinion, the universe could be considered either finite or infinite depending on how it expands. Just my 2 cents. :-p
http://en.wikipedia.org/wiki/Series_(mathematics)
I don't see the connection between the way a series converges or diverges and the expansion of the universe.
goldust said:
... the universe could be considered either finite or infinite depending on how it expands.
and in what way does that address my statement?
Be careful there. :-p
I think it is clear from the context that I am talking about physical things, so I am confident that I do not need to be careful. It is an absolutely true statement.
Ok, final question... Does anyone on this thread think a suedo-sphere universe can later (after a few seconds) layout into a flat universe??
No, a flat universe is a natural result of inflation.
Therein lies a twist. How can people ever know if the universe is flat? People once thought Earth is flat, yet Earth is round. Scientists now think the universe is flat, but how can they be sure they are right? No instrument in the world, no matter how accurate, can ever determine if something sufficiently big is perfectly flat. :-p
We are on the same page that numbers are infinite even though we can count numbers? :-p
Try counting the reals between 0 and 1. Hop back on here when you've finished...
Cosmologists don't think the universe is flat. What they've done is measured the observable universe to be flat to within less than 1%. Of course, the universe could still be closed (spherical), with the observable universe only a small patch on this larger sphere. In this case, the analogy to humans on Earth carries over quite nicely.
You would need some topology changing behavior. As far as I know, this is impossible in general relativity. There appears to be some degree of topology change permissible in speculative theories of quantum gravity (like string theory) but I don't know whether this is of the type needed for what you are asking. Unlikely, seeing as even after only a few seconds the universe is securely in the classical regime.
What does this have to do with the real world of physical objects? Go back to my original statement in post #2 and see if you can find any correspondence between your comments and my statement. I can't see any at all.
Ok... I think that's what I was wondering about. It appears that the universe MUST be infinite at the moment when it comes into being, to remain infinite. If it is closed, it will remain, although vastly enormous, more than we can detect. So if it is infinite, then it was never the size of a nutshell (forgive the cliche). Thanks everyone!
Universe finite or infinite during the first instants of inflation
bapowell said:
You would need some topology changing behavior. As far as I know, this is impossible in general relativity. ...
Sounds like you have arrived at a clear satisfactory picture. Now keeping that basic idea intact I'd like to add some minor complications, in case they might interest you.
As far as I know, it is impossible in general relativity for the universe to "come into being". GR only applies, as a model, once the U has started expanding. But GR (a vintage 1915 pre-quantum theory, after all) is not the end of the story.
There is a sizable community of researchers working on modeling the U right around the start of expansion, often times extending back BEFORE the start (so that the U does not "come into being" when we are often told in the pop literature that it "came into being"). IOW some, perhaps the majority, of current models do not have a "singularity" and instead extend back before.
That line of research would come under the general heading of quantum cosmology. You can do a keyword search of recent research paper and scan the list just to get an idea. I don't mean delving into technical detail, just glancing to get an idea of what's out there. It means that the general concept of "big bang" is changing in the minds of those whose area of research it is.
Here are the "quantum cosmology" papers since 2009, ranked by number of times cited:
http://inspirehep.net/search?ln=en&...search=Search&sf=&so=d&rm=citation&rg=25&sc=0
Of those, here are the more recent ones, 2011 through 2013:
If anyone wants the latest (Planck mission) 95% confidence intervals for Omega_k, which if negative indicates spatial finite U, but could be zero or positive which would indicate possibly infinite, they are on page 37 of this Planck report, see also pictures on page 36:
http://arxiv.org/pdf/1303.5076v1.pdf
http://arxiv.org/abs/1303.5076
Edit (afterthought) another curious bit of research: http://arxiv.org/abs/1311.3509
It's true that realistic cosmological models don't switch between being spatially infinite and spatially finite. However, you seem to be claiming that this is obvious for elementary or philosophical reasons, and I don't think it is. This is an active area of research in GR, which you can find lots of information about by googling "general relativity" "topology change". A paper that gives a fairly recent summary is Borde, "Topology Change in Classical General Relativity," http://arxiv.org/abs/gr-qc/9406053 . Essentially topology change implies both kinematic problems (CTCs) and dynamical ones (violation of the WEC). None of this is obvious; it was worked out by Geroch and Tipler in the 60's.
Interesting. I thought it was axiomatic that finite real things cannot become infinite in a finite amount of time. I still don't see how that could be possible.
There is no known way to tell if the 'universe' is finite or infinite. We can only constrain it to a minimum spatial size, which has already been done by Neil Cornish, et al. [circles in the sky], and assuredly by others. We are incapable of experimentally measuring an 'infinite' anything.
  • · Replies 20 ·
  • · Replies 33 ·
  • · Replies 37 ·
  • · Replies 17 ·
  • · Replies 47 ·
13K
