I Unravelling Structure of a Symmetric Matrix
thatboi
Hey guys,
I was wondering if anyone had any thoughts on the following symmetric matrix:
$$\begin{pmatrix}
0.6 & 0.2 & -0.2 & -0.6 & -1\\
0.2 & -0.2 & -0.2 & 0.2 & 1\\
-0.2 & -0.2 & 0.2 & 0.2 & -1\\
-0.6 & 0.2 & 0.2 & -0.6 & 1\\
-1 & 1 & -1 & 1 & -1
\end{pmatrix}
Notably, when one solves for the eigenvalues and eigenvectors of this matrix, one finds that for the largest magnitude eigenvalues, the eigenvectors demonstrate an oscillatory behavior (the elements within the eigenvector switch between positive and negative), whereas for the smallest magnitude eigenvalue, the eigenvectors have a "nicer" behavior. This most likely has to do with the alternative +/- 1 in the matrix but I can't quite figure it out.
thatboi said:
Hey guys,
$$\begin{pmatrix}
\end{pmatrix}
I think this hypothesis can be easily tested.
Right, so the last row contributes to the eigenvalue in the sense that it gives the last entry of the resultant column vector when the matrix is multiplied by the eigenvector. So if the eigenvector also has entries that alternates signs, then the dot product between the eigenvector and the last row will result in a "coherent" sum and thus produce a larger number than compared to a different eigenvector with a different configuration of signs. Is this the right way to think about it?
I meant to test it experimentally, by modifying the "suspected" elements and observing how the eigenvectors are affected.
Sure, I already did some modifications and it seemed to match what I said above (for example if I put a negative sign on only the second element of the last column and second element of the last row, then the eigenvector corresponding to the largest magnitude eigenvalue only has a negative sign on the second element as well). I was just wondering if there was any more intuition/structure in the matrix beyond what I said above.
If you described how you generated that matrix, sometimes there are underlying reasons why certain eigenvectors exist.
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
When decomposing a representation ##\rho## of a finite group ##G## into irreducible representations, we can find the number of times the representation contains a particular irrep ##\rho_0## through the character inner product $$ \langle \chi, \chi_0\rangle = \frac{1}{|G|} \sum_{g\in G} \chi(g) \chi_0(g)^*$$ where ##\chi## and ##\chi_0## are the characters of ##\rho## and ##\rho_0##, respectively. Since all group elements in the same conjugacy class have the same characters, this may be...
