Unrolling then solve for n=100
  • Thread starter scorpius1782
15 replies · 2K views · last reply
scorpius1782
Can someone check that I'm doing this correctly? Someone else got another answer entirely but I don't see where my mistake could be...
##f(1)=2##
##f(n)=1+f(n-1)+n^2##
Unrolling:
##f(n)=1+1+f(n-2)+(n-1)^2+n^2##
##f(n)=1+1+1+f(n-3)+(n-2)^2+(n-1)^2+n^2##
so ##k+f(n-k)+\sum_{i=0}^k(n-i)^2##
for n=100
##99+2+\sum_{i=0}^{99}(100-i)^2##
101+338350=338451
99, right?
also, for got to write that ##n\geq2##
Not sure I'm understanding, there is just the (n-i)^2 term in the summation.
How many things are you adding if you write ##\sum_{i=0}^{k}##? Hint: the answer is not ##k##.
scorpius1782 said:
k-1?
Now you are just guessing. Don't do that. Work it out logically, or try a few small k values to see what you get.
Okay. ##\sum_{i=0}^3 i##=0+1+2+3, means 4 terms. so k+1
Edit:
i took k-1 from wiki. As for this I only have th option of k or k-1 since it is a multiple choice question. but the n=100 isn't.
No, not really. I think I know what the answer is, but I don't really see why what I have is wrong. It seems so straightforward.
Take a look at the previous line, which is correct:
$$f(n)=1+1+1+f(n-3)+(n-2)^2+(n-1)^2+n^2$$
How many "1" terms are you summing?
How many ##(n-i)## terms are you summing?
Now compare your general formula, which is incorrect:
$$f(n) = k+f(n-k)+\sum_{i=0}^k(n-i)^2$$
3 1's and 2 (n-1)'s.
then k 1's and k(n-i)'s.
So it should be summed from 0 to k-1, then.
I counted 3 (n-i)'s: ##(n-2)^2 + (n-1)^2 + n^2##. So the number of ##1##'s and the number of ##(n-i)##'s should match.
Well, there are ##k## 1's, but didn't we just agree that the summation ##\sum_{i=0}^{k}## is adding ##k+1## things? So you are summing ##k+1## of the ##(n-i)^2## terms when it should be ##k##.
Yeah, sorry I keep not counting ##n^2##. So, I need to to go from 0 to k-1. Since, k is 1 more than the total number I need to sum.
The TA gave an answer that didn't make any sense to me. They got the summation of ##f(n) = k+f(n-k)+\sum_{i=0}^k i^2## but I don't see how that is correct at all.
Yes, that sounds right.
No, it's not correct. For example, plug in ##k=1##. Then the TA's formula gives you ##f(n) = 1 + f(n-1) + 1^2## whereas the problem statement requires ##f(n) = 1 + f(n-1) + n^2##.
