Use comparison test to see if series converges
15 replies · 2K views · last reply
kwal0203
[tex]\sum_{x=2}^{\infty } \frac{1}{(lnx)^9}[/tex]
[tex]x \geqslant 2[/tex]
[tex]0 \leqslant lnx < x[/tex]
[tex]0 < \frac{1}{x} < \frac{1}{lnx}[/tex]
From this we know that 1 / lnx diverges and I wanted to use this fact to show that 1 / [(lnx) ^ 9] diverges but at k >= 2 we have this:
[tex]0 < \frac{1}{(lnx)^9} < \frac{1}{lnx}[/tex]
So it doesn't really work.
Is there a relation between 1/x and 1/[(lnx)^9] that I can use to solve the problem?
Any help would be appreciated, thanks!
Hint: work out how to show the condition on ##x## such that ##\ln x < x## and see whether you can extend this for ##(\ln x)^9##.
Well the condition on x to make that true is x > 1 right?
To extend it, should I try and find when this is true:
[tex](lnx)^9 < x[/tex]
How do you prove that?
Well, lnx <= 0 whenever 0 < x <= 1 so that bit is obvious I guess.
Also, whenever x > 1, lnx < x because it's a monotonically increasing function with first derivative:
1 - 1/x > 0.
For that to be true x > 1.
1 - 1/x > 0.
Okay. But can you extend that idea to ##(\ln x)^2##?
Or, is there another way to do it that might be easier to extend?
I don't think you can because if you take lnx where x < 1, it's a negative result. So (lnx)^2 would be positive.
Another way to prove lnx < x?
Yes, just think of what you could do to that equation.
Oh right,
[tex]lnx < \sqrt{x}[/tex]
[tex]\sqrt{x} - lnx > 0[/tex]
[tex]\frac{\mathrm{d} }{\mathrm{d} x}(\sqrt{x}-lnx)=\frac{1}{2\sqrt{x}}-\frac{1}{x} > 0[/tex]
when x >= 2.
so if that's true then so is this:
[tex](lnx)^2 < x[/tex]
Is that right?
Let me help. It seemed obvious to me:
## \ln x < x## iff ##x < e^x##
Perhaps that's easier to extend to powers of the logarithm.
Ok, so we can say that ## \ln x < e^x## so ## (\ln x)^9 < e^9x ## and ## 1/e^9x < 1/(lnx)^9##
Is that the idea? (those x's should be in the exponent as well)
That maths is all awry!
Let me help you a bit more:
Generally, you can use the following result without proof:
For all ##n## eventually ##e^x## is greater than ##x^n##. In fact the limit ##\frac{e^x}{x^n}## is ##+\infty## as ##x \rightarrow +\infty##
That result should help in this case.
Ok, yeah I got no idea.
I'm pretty sure 1/x < 1/(lnx)^9, I just can't prove it like I can for 1/x < 1/lnx.
And since 1/x diverges so does 1/(lnx)^9.
I'm not sure how the facts that lnx < x iff x < e^x (is this ever false?) and limit of e^x / x^n -> infinity helps.
You know that ##\ln## is the inverse of ##\exp##?
Yes
