Using Power-of-a-Point Theorem in Geometric Proofs
The problem involves applying the Power of a Point theorem in a geometric context, specifically related to a circle and tangent lines. The original poster presents a scenario with points on a circle, a tangent, and segments intersecting the circle, seeking to find the radius of the circle.
  • Participants discuss the application of the Power of a Point theorem, with attempts to establish relationships between segments and the radius of the circle. Questions arise regarding the correctness of calculations and the interpretation of the theorem's application.
The discussion is active, with participants providing hints and corrections to each other's reasoning. There is a back-and-forth exchange regarding the application of the theorem and the implications of certain calculations, indicating a collaborative effort to clarify the problem.
Participants express skepticism about assumptions made in proofs and the rigor of their arguments, particularly in relation to the Power of a Point theorem. There is mention of potential typos and misinterpretations that could affect the conclusions drawn.
theJorge551
Point A is on a circle whose center is O, AB is a tangent to the circle, AB = 6, D is inside of the circle, OD = 2, DB intersects the circle at C, and BC = DC = 3. Find the radius of the circle.
Power of a point theorem (several cases found online, a few here: http://www.cut-the-knot.org/pythagoras/PPower.shtml )
I've drawn the figure, and I recognize that in drawing D, it'd have to lay on the edge of a(n) (imaginary) circle about B with a radius of 6, and that based on that, D could only have 2 possible positions inside the original circle. I've also found that the power of point B w.r.t. the original circle is 36, but I don't know how to proceed to find r (either AO or CO, as far as I can tell).
TheJorge551, this is a cool problem. I had not seen the Power of a Point theorem before, it’s amazing.
I might be able to help.
So far what you’ve done looks right to me. What I think you should do next is continue the line BD until it intersects the the circle at the far side. I called that point of intersection E. Now you have the line BE that passes through points C and D. You can find the length of the segment DE(with help from Power of the Point theorem). Once you have DE, consider how you might use the Power of a Point theorem yet again.
Hope this helps.
Thanks for your hint! I did what you suggested, and stated that 36 = BC x BE, And knowing that BC = 2, BE must be 12. Because BD = 6, BE = 6 as well...then I said that there is a diameter through OD intersecting the circle at points F and G (which are both irrelevant, directly, because I can just use "r"), and from the P.o.P. theorem, CD x DE = (r-DO) x (r). Because DO = 2, I solved the quadratic and found r to equal 1 + sqrt(19). Is this the solution you found?
We almost agree at this point.
First, you might have a typo here: "And knowing that BC = 2, BE must be 12. Because BD = 6, BE = 6 as well...". For the second BE, I think you mean DE, is that right?
And at the last, "CD x DE = (r-DO) x (r)", I think instead of r as the last term you should have (r+DO). The focal point to apply the Power of the Point theorem is D and so the line segment FG is broken at D into a segment of length r+DO and the other of r-DO. Would you agree?
You're correct for the first part; it was a typo. For the second part, you're right -- I made a mistake as to what my point of focus was, so it should be CD x DE = (r-DO) x (r+DO), simplifying to 18 = r^2 - 4, and thus r = sqrt(22). Did I make any other silly errors, or does this match what you have?
That's the answer I got.
Fantastic, thanks for your help, bacon. :D
I've got another problem, which I think I've solved, but the proof seems so utterly simple that I'm skeptical of whether or not I've overlooked some big assumption that I might have made. Could someone tell me if my proof is sufficient (if we take the Power-of-a-point theorem, from earlier, to be true)?
"Two circles intersect at distinct points P and Q, and K is on PQ. A line through K forms chord AKB in one circle, and chord CKD in the other. Prove that AK x KB = CK x KD."
I simply stated that by the P.o.P. theorem, PK x KQ = AK x KB, and PK x KQ = CK x KD, and hence AK x KB = CK x KD. Is my "proof" oversimplified? It's certainly not rigorous, but I'm certainly not going to reprove the fundamental theorem over and over again, in each one in the problem set. :P
I've got another problem that I'm trying to plow through, but I'll post it later if I can't see the solution.
  • · Replies 20 ·
  • · Replies 18 ·
