Using Trapezoid Rule Twice huh?
  • Thread starter issh
    Trapezoid
3 replies · 8K views · last reply
issh
Printed textbook problem 9: an old gravel pit with murky water is to be filled in, depths found by rowing across in straight lines and dropping a weight on a rope; use the trapezoidal rule twice to find the approximate volume of fill.
Hand-drawn lake depth map with a grid of 3 m intervals; depth readings along vertical lines, e.g. 2.6 m, 3 m, 3.2 m, 2.9 m, 2.4 m across the top, and a bottom edge labelled depth 0 m.
A=(1/2)w[E+2M]
Where w=width between each interval
E=f(a0)+f(an) is the sum of the end values
M=f(a1)+f(a2)+...f(an-1)
I found the area of the first trapezoidal rule but can't identify the other
w=(15/5)=3metres
E=2.6+2.4=5
M=3+3.2+2.9+2.4=11.5
Therefore, A=(1/2)w[E+2M]=42
I couldn't identify the 2nd one
In order to calculate the volume of water in the pit, you can calculate the area of each of the 6 cross sections using the trapezoidal rule. Make a table or plot of the resulting cross sectional areas and use the trapezoidal rule again in the direction perpendicular to the cross sections to calculate the volume of water in the pit.
You are estimating a volume, so you are doing a 2-dimensional integral of the form [tex]\int \int f(x,y) \, dx \, dy [\tex] where f(x,y) = depth at point (x,y). For each x, you do the trapezoidal rule to estimate [itex]\int f(x,y)\, dy[/itex], and you are doing that at the x-points 0, 3, 6, 9, 12 (meters). Of course, at different x you have different numbers of y-points, so rather than doing the trapezoidal rule twice, I would rather say you are doing it 5 times (once for each of the 5 x-values).<br /> <br /> RGV[/tex]
