Variable Magnetic field bound in a cylindrical region
9 replies · 3K views · last reply
Saitama
There is a uniform but variable magnetic field ##\vec{B}=(B_0 t)(-\hat{k})##, in a cylindrical region, whose boundary is described by ##x^2+y^2=a^2##. ##\displaystyle \int_P^{Q} \vec{E} \cdot \vec{dy}## is (see attachment 1)
A)0
B)##\frac{\pi}{4}(B_0 a^2)##
C)##-\frac{\pi}{8}(B_0 a^2)##
D)##\frac{\pi}{8}(B_0 a^2)##
(see attachment 2)
The electric field produced will be in anticlockwise direction. At a distance y from P, the electric field can be calculated using Gauss's law.
[tex]E \cdot 2\pi \sqrt{4a^2+y^2}=B_0 \pi a^2[/tex]
[tex]E=\frac{B_0 a^2}{2\sqrt{4a^2+y^2}}[/tex]
Since y is in the vertical direction, we need to only consider the vertical component to evaluate the integral asked in the question.
[tex]\int_{P}^{Q} \vec{E}\cdot \vec{dy}=\int_0^{2a} E\cos \theta dy[/tex]
[tex]=\int_0^{2a} \frac{B_0 a^2}{2\sqrt{4a^2+y^2}} \cdot \frac{2a}{\sqrt{4a^2+y^2}} dy[/tex]
Solving the integral, I get D which is correct.
The problem is I don't understand what the solution booklet has mentioned. The solution goes like this: (see attachment 3)
[tex]\int_{P}^Q \vec{E} \cdot \vec{dy}=\frac{1}{8}[\vec{E} \cdot \vec{dl} \text{ for square } TQRST][/tex]
[tex]=\frac{1}{8} \frac{d[\pi a^4B_0t]}{dt}[/tex]
[tex]=\frac{\pi}{8}B_0 a^2[/tex]
I don't understand how they even got the first two steps. :confused:
Any explanation on this would be helpful. Thanks!
  • Diagram of a circular region with many small circles containing crosses marking an into-page field, with a horizontal radius labelled 2a, a vertical dashed line from point P up to point Q at height 2a, and a corner of perpendicular lines at the centre.
  • Diagram of a circular region of radius a with inward-pointing crosses (into the page) and a dashed vertical line from point P to point Q at distance y along a line through the centre, with electric field E drawn at an angle theta to the vertical.
  • Diagram of a circle of radius 2a centred at the origin inside a dashed square RSTQ of side 4a, with point P on the right edge at the x-axis and point Q at the top right corner; vertical arrow marks 2a from P to Q, horizontal arrow marks radius 2a.
See the line integral from P to Q is one eight of the whole perimeter of the square...So the first line is written..It is similar like the electric flux concept which we use...In the second line...it should be a^2
Yes, it should be a^2, sorry for the typo but I am not yet able to understand why the method works. :confused:
See, if you have solved the sum of electric flux( i.e flux through one face of a cube containing a charge Q inside it.=Q/6e0) you can understand.The similar follows here...Instead of Surface integral here is the line integral..
Solve it by using Faraday's Low of Induction
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/maxeq2.html#c3.
The electric field lines are circles around the cylinder. The line integral for a whole circle is equal to the negative of the derivative of magnetic flux inside. It does not depend on the actual path. You can use symmetry to calculate the integral for the given path.
ehild
I did use the integral form to get the magnitude of electric field.
ehild
I am not sure if I get it but what about the case when the square shown in attachment 3 lies inside the circle ##x^2+y^2=a^2##? Would the same method still apply?
Thanks!
ehild said:
The enclosed flux counts.
ehild
For instance if I inscribe a square of side a/√2 in the given circular region, the line integral for that square would be ##\frac{d\phi}{dt}## where ##\phi=(B_0t)(a^2/2)##. Is this correct?
Thanks!
