Variation of Catalan Conjecture
  • Level: Graduate
  • Thread starter Thread starter e2m2a
    Conjecture Variation
22 replies · 3K views · last reply
e2m2a
TL;DR
Interested in finding if proofs exist or have been published on a Diophantine equation.
I know that it has been proven that for the expression x^a -y^b = 1, only has this one integer solution, where x = 3, a =2, y =2, b = 3. I am interested in knowing if there is a proof for this expression: 2x^a - y^a =1 in which there are integer solutions for x,a, and y or if no integer solutions exist except for the trivial case where x,y = 1. How would I find a proof for this if it existed?
Mathematics news on Phys.org
a = 0 a = 1? Not sure what you mean. Can you please expound on this?
e2m2a said:
2x^a - y^a =1
[tex]2n^0-m^0=1[/tex]
and
[tex]2n^1-(2n-1)^1=1[/tex]
satisfy it.
  • Sad
and
satisfy it.
The OP stated that he didn't want trivial solutions.
We have more solutions than he found.
@e2m2a Are you still looking for further more solutions?
  • Sad
Yes, I would be very much interested. Please show me the solutions.
Some easy observations on m and n satisfying
[tex]2m^a-n^a=1[/tex]
Say a>1, 1<m<n
m and n are coprime to each other, otherwise LHS > 1
n does not have factor 2, otherwise LHS is an even number.
n < 2^(1/a) m otherwise LHS < 0
n^a=m-1(mod m) or let n=k(mod m), k^a=m-1(mod m)
Is $$1=50-49=2\cdot25-49=2\cdot 5^2-7^2$$ considered a trivial solution?
True trivial ones follow after that as
[tex]2*(-5)^2-7^2=1[/tex]
[tex]2*5^2-(-7)^2=1[/tex]
[tex]2*(-5)^2-(-7)^2=1[/tex]
Interesting. Thanks.
Thanks.
A simple Python program finds the following:
5; 7
29; 41
169; 239
985; 1393
5,741; 8,119
33,461; 47,321
195,025; 275,807
1,136,689; 1,607,521
6,625,109; 9,369,319
We need to look for solutions with ##a > 2##.
PS here are solutions with ##y^2 - 2x^2 = 1##:
2; 3
12; 17
70; 99
408; 577
2,378; 3,363
13,860; 19,601
80,782; 114,243
470,832; 665,857
2,744,210; 3,880,899
5; 7
29; 41
169; 239
985; 1393
5,741; 8,119
33,461; 47,321
195,025; 275,807
7-5=2
41-29=12
239-169=70
1393-985=408
8119-5741=2378
I observe they coincide with first numbers of the lines of
PeroK said:
PS here are solutions with y2−2x2=1:
2; 3
12; 17
70; 99
408; 577
2,378; 3,363
13,860; 19,601
80,782; 114,243
In return
3-2=1
17-12=5
99-70=29
577-408=169
coincide with the first numbers of upper column except 1 at the top line.
There should be a simple explanation of this coincidence.
OEIS has the sequence for the y that have an integer ##y^2 - 2x^2 = 1## solution.
It can be generated using a(n) = 6*a(n-1) - a(n-2) with a(1)=1, a(2)=5.
The ratio between successive x, approaching 3 + sqrt(8), suggested such a relation.
Thanks everyone for your replies and calculations. Totally awesome! We live in an amazing day when computers can grind out solutions for us so quickly. The ancients and pre-modern mathematicians would have loved the tools we have today to test out their ideas. Thanks again.
Those are actually the ##x## values where ##2x^2 -1 = y^2##.
Your equation is a special case of Pell's equation:
https://en.wikipedia.org/wiki/Pell's_equation
There are two versions of this:
The general equation ##y^2 - nx^2 = 1## has quite a lot of solutions.
The general equation ##nx^2 - y^2 = 1## has far fewer. Let's focus on this.
I didn't find any solutions (for ##x## up to ##10^6##) for ##n = 3## or ##n = 4##. But, found these for ##n =5##:
##1, 17, 305, 5473, 98209##
This is also on OEIS:
https://oeis.org/search?q=1,+17,+305,5473,98209&sort=&language=english&go=Search
Checking for ##n## up to ##19## I got solutions for:
##n = 10##: ##1, 37, 1405, 53353##
##n = 13##: ##5, 6485 ##
##n = 17##: ##1, 65, 4289, 283009##
But, if we increase the power to ##3## and look for positive integer solutions to ##nx^3 - y^3 = 1##, then I can only find trivial solutions, such as ##9\times 1^3 - 2^3 = 1##.
Similarly, I can't find any solutions for the the fourth of fifth power. So, conjecture:
The general equation ##nx^a - y^a = 1## has no non-trivial solutions for ##a > 2## and ##n > 0##?
The case ##n^{1/a}\in \mathbb{Z}## should be restricted by Fermat's last theorem, right?
for given integer m the candidate of integer n is
[tex]\lfloor 2^{1/a} m\rfloor[/tex]
