Vector components: is vertical displacement the j or k component?
  • Thread starter Thread starter yardy_genius
    Dynamics Vector
2 replies · 2K views
yardy_genius
An air craft has an initial velocity of 90(i+ j)ms-1and a final velocity of 10(10i + 10j +3k) ms-1. The time taken for this change to occur is 100 s. Determine the:
a)average velocity for the 100 s period.
b)average speed for the period.
c)constant acceleration of the airplane in unit vector notation.
d)magnitude of the acceleration.
e)vertical height the plane has risen.
f)distance plane traveled for the 100 s period
I have calculated all the above but i am confused as to which one of the vectors to state as the variable.
using the formula S= ut + 0.5at^2
i got the unit vector form (9500i + 9500j+ 1500k) this is correct.
now the solution says the vertical height is 1500k, but i thought 9500j was the vertical component. can some please explain this to me.
my answer
I think you must be picturing the x-y-z axes as representing, let's say, x for eastward, y for up (as in altitude), and z for northward? That could feasibly be true, but for the velocity here rising to 100i + 100j + 30k it would be more like a ride on fighter plane, gaining 100m in altitude for every 104m you travel over terrain. If you instead interpret z as representing altitude, then plane passengers will be less terrified. :smile:
I'm not saying I'm correct, but it seems the question does leave this up to you to decide. Which means there is room for ambiguity.
thanks, i was kinda thinking along those lines too...
