Vector Problem finding a certain endpoint.
  • Thread starter Thread starter charmedbeauty
    Vector
2 replies · 3K views · last reply
charmedbeauty
Let A=(2,3,-1) and B=(4,-5,7). Find the midpoint of A and B. Find the point Q on the line through A and B such that B lies between A and Q and BQ is three times as long as AB
So to find the midpoint of A and B.
MA+B=(A+B)/2
RHS= (6,-2,6)/2
MA+B=(3,-1,3)
Next I said that the the midpoint of Q and A is 3 × (MA+B)
Hence MQ+A= (9,-3,9)
So now we have the midpoint and one endpoint of the line QA.
so Q+A=2(MQ+A)
so RHS= (18,-6,18)
Hence Q+2=18
Q+3=-6
Q-1=18
so Q=(16,-9,19)
But this was wrong I don't see why?
MA+B=(A+B)/2
Yes, that is correct.
RHS= (6,-2,6)/2
Why did you change from calling it "MA+B" to "RHS"?
MA+B=(3,-1,3)
Why would you think that? It certainly is NOT true. To take a simple case, suppose A= 0 and B= 1 on a number line. The distance from A to B is 1 and so the distance from B to Q must be 3. That is, Q= 1+ 3= 4. The midpoint of AB is 1/2 and the midpoint of AQ is 2. 2 is NOT 3 times 1/2.
so Q+A=2(MQ+A)
so RHS= (18,-6,18)
Hence Q+2=18
Q+3=-6
Q-1=18
so Q=(16,-9,19)
Because you entire logic is incorrect. The midpoint of AQ is NOT three times the midpoint of AB.
Instead, the length of BQ is three times the length of AB which means the length of AQ= AB+BQ is four times the length of AB. Using "similar triangles" that means that Qx= Ax+ 4(B[subx[/sub]- Ax)= 2+ 4(4- 2)= 2+ 4(2)= 10, etc.
Ohh yes it is for times the magnitude... so can I use the same method and say the midpoint of the new line is 4 times the original midpoint?
